Question about Seagate (ST3160827AS) 160 GB Hard Drive
Broken piece around SATA connection on Seagate Hard Drive
The SATA cord will not stay in place because plastic problem is missing
  • 2 more comments
  • randonewilli Jan 30, 2009
    hard drive
  • Roberta Smith
    Roberta Smith May 11, 2010
    yes i gathered that... but the tab that you plug the cord in has broken off ?
  • Roberta Smith
    the tab broke right off ?
  • Anonymous Mar 24, 2014
    The plastic frame in the sata port is missing. Therefore, connectors fall out and I can't read the data on the drive. I would like to find a temporary solution so I can quickly copy all of the data and then discard the faulty drive.
Hi. would that be on the cord or, on your harddrive?
Posted on Jan 29, 2009
Interface seagate barracuda 7200.7 200GB drive sata to usb 2 forum
Hello. You are correct that there are no jumpers, however, when you connected the SATA cable to the Internal hard drive, did you notice there were two similar connectors. One was for the SATA the other, longer one is for the POWER for the drive. If your SATA to USB has both connectors make sure they are both installed properly. Be careful you don't break those little plastic tabs because they are not warrantied. If the drive does have power and spins up then it may not be initialized (formatted) and will need to be initialized using START, Administrative Tools, Computer Management, Disk Management. or just click on start and type diskmgmt.msc in the RUN box.
Hope this helps..
Nov 04, 2012 | Seagate Barracuda 7200.7 200 GB Hard Drive
I had four broken DVRs of same type, I want to use their HDD in raid strip in PC, but they are DVR HDDs (Seagate Pipeline HD.2, ST3250312CS) and they are not initiable in PC. Is there any way to use them? ...
The SATA RAID interface needs to be compatible with SATA revision V2.0. Check the drives with the Seagate diagnostic tool (download it from Seagate) for correct operation. This will also check / test the SATA interface. Connect the drives directly to a PC with SATA interface to do this. If proven OK then use the RAID board.
Possibly there's a way to downgrade to SATA-1 using a Seagate tool.
Jul 05, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
Hard disk replace
remove the side panels to access your computers hard drive
put an earth ******** to earth yourself before proceeding
there are 4 screws 2 either side of the hrd drve
unplug the electrical lead followed by the IDE/SATA what ever applies
have a good look at the plastic jumper & the pin settings usually located at the rear of the hard drive next to IDE/SATA lead before removing anything
then place the new hard drive in rembering to look at the plastic jumper and its location
plug the electical & IDE/SATA lead in
restart your computer
hope this helps
Dec 09, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How do you connect two hard drives to a computer?
1. For SATA, you just need a second SATA cable to plug it in and a power cable from the power supply.
2. For IDE, you will need a second IDE cable to plug the second hard drive, AND you will have to set both hard drives jumpers either to cable select or one Master and the other one Slave, based on which one you have the operating system.
Nov 12, 2010 | Maxtor Hard Drive
I try to install any os to this seagate barraguda 7200rpm, 80 gb hdd don't have completed installtion successfully. many files are missed. some times do not detecting the hard drive.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Aug 30, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Pls. help me with my new seagate external freeagent pro ( 500GB)
hi..there....i think if you can get e sata cable to connect between external and pc at you country is very bad news..but maybe you can get it in another store...last time when i visit bangkok thailand i'm very happy because i can get all componnet for pc..i buy a internal card reader that include the e sata connection is around 400 baht and the cable connector for it (power and data cable) is around 100 baht. so if you have friend at tahiland (bangkok) you may ask them to buy it for you and send it to your place....
Feb 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 500 gig external hard drive problem
Your computer must have a firewire connection.
Jan 11, 2009 | Computers & Internet
Seagate (ST3160827AS) 160 GB Hard Drive Logo
263 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
