Question about Karcher 2500 PSI Pressure Washer
8HP troy-bilt will not start, this is my 1st time this year
Cleaned spark plug just will not run
  • Anonymous Feb 13, 2009
    2200 troy-bilt pressure washer locked up and will not start. It is leaking oil out of the muffler. why will it not let me pull the cord to start it?
  • 211 Answers
Hi
Try changing the plug with a new one with the same heat range.Priming the engine(put some gas in the cilinder through the plug hole)and start the engine.
best regards savumihai71
Posted on Feb 12, 2009
Troy bilt troubleshooting
-Try replace spark plug first. If still do that then the ignition coil is bad when it's hot.
Good luck
mai
Aug 28, 2014 | Garden
Engine won't start- I have changed gas, I have a good spark, and no air blockages
Put a nice new spark plug in the engine and clean the carb with carb cleaner. Spray some cleaner in the carb throat, and put some liquid carb cleaner in the fuel tank.
Mar 05, 2014 | Troy-Bilt Super Tomahawk Chipper Shredder...
Honda Engine on my Troy-Bilt 834 wont start
Check the engine coil sounds like it is either bad or ground wire is not going to start check by removing the wire from the coil if it starts fix the brake ground if it does not start the coil is bad replace coil.
Oct 10, 2017 | Troy Bilt 5.5hp Self Propelled Mower
Old (1981)Troy Prof. 8hp tiller runs 30 sec. and stops.
Clean the carb and if this machine was kept outside all winter make sure no water in tank. I realize you stated that you removed old gas but how it was removed is the key. Try the carb thing first though.
Apr 28, 2010 | Troy-Bilt Pony Garden Tiller
Troy bilt hasn't been used in 2yrs.; has oil and gas in it but will not electric or pull cord start...
1st I would drain the gas and put new in. It loses octane over time. Then try new spark plug. Also you may need a new diaphram in the carburetor. They are cheap and sell them at most hardware stores.
Dec 20, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Jul 14, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Weed eater does not start
I had a similar problem with my troy-bilt weedeater. I tried replacing the sparkplug, replaced the fuel filter and etc. It still would not start. I looked at the troubleshooting guide in the owner's manual and it listed a possible cause as a clogged spark arrestor. I cleaned out the spark arrestor by taking it off and cleaning it with a wire brush. Now it runs like brand new again. I hope this helps.
Apr 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Karcher 2500 PSI Pressure Washer Logo
385 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
