Question about Pentax 4X - 16X 50mm Lightseeker-30 Matte Rifle Scope with Side Parallax Ad
I have a Pentax lightseeker scope and I can not get it adjusted and it has a cracked lense. The adjustments turn but nothing happens, I still shoot the same direction no matter what...
  • 117 Answers
If it has a cracked lens it obviously took a very hard shot at some time or other.I would send it back to Pentax.They are not cheap, so I would attempt to get it repaired by the manufacturer.
Good Luck
Posted on Mar 25, 2009
Windage adjustment will not adjust to the right - clicks but does not move the shot groups to the right.
if you have forsed the scope turrets you may have broken your scope,,,if the turret turns to the left set it to the center and change the scope mounts or pack out the scope mount with some strips of 35mm camera film 3 strips should do you,
pack out the eye end mount on the left side of the scope
Aug 28, 2010 | Pentax 4-12x40 Gameseeker Rifle Scope...
When looking through my scope any object over 10 feet away is blury
generally you should be able to adjust the clarity of the image by adjusting the lense nearest the eye .First loosen the set collar that holds the lense in place, then adjusting the image to clear
Jul 07, 2010 | Optics
Sight adjustments
It's a common misconception that you are moving the bullet's impact on the target... the bullet is hitting where the rifle is pointing and you want to get the scope to look at that very same spot.
To move the scope's reticle up or down, turn the elevation adjustment on the TOP of the scope in the direction you want the scope to look, so if your shooting low, turn the scope's adjustment in the DOWN direction.
If you want to move the direction the scope is looking left or right, turn the windage adjustment on the RIGHT side of the scope left or right to look where the bullet is impacting. To move the crosshairs to the right, turn it right.
Hope this helps, Mark the Gunsmith
Dec 11, 2009 | Bushnell 3-9x38 Sportview Rifle Scope...
I can shoot my centerpoint scope on my .22 and it
When adjusting a scope just move a few clicks at the time, after every few clicks tap the scope with a screw driver handle. Fire 2 rounds for group tap and fire the third round it should be in line with the 2. Keep that up till on target. Let the gun sit till cold and re-fire for grouping, 2 rounds, wait then the third. To keep shooting round after round can get the reciver warm enough to wedge the scope in its bases, causing your problem.
Oct 13, 2009 | Optics
VX-III 1.75-6X32MM. While zeroing for the fist time, I had to adjust the scope up by 10 clicks because it was shooting low. After the first adjustment, it was still shooting low. When I went to adjust...
cross hairs stick some times try taping the top after each adjustment if that don't work turn your scope so the left to right adjustment is on top and use it to raise and lower point of aim.
Jul 10, 2009 | Optics
Cap cover pentax 3x-9x scopes
You do not define "cap cover" as to whether it is a 'lens cap' of which the Objective Lens comes in varying sizes with the 3x9 scope depending on the model.
However, you should be able to find one in the size you need at most any Firearms supply store. I have even found a lens cap for a Leupold at a Walmart.
Barring that, go to; www.pentaxsportoptics.com, they should be able to help you in your quest.
Good luck. :)
Apr 14, 2009 | Pentax 3X - 9X 40mm Lightseeker XL Glossy...
Whitch way do my lenses go?
If you completely disassembled the scope then it is compromised they have a special gas mixture inside for fogging and clarity so if they were removed you are likely better off with a new one out of reference what kind of scope is it
Apr 02, 2009 | Hawke Sport Optics Hawke® Endurance MAP 3...
Crosshairs on pentax 4.5x14x42 don't move
With modern rifle scopes the crosshairs do not move.They are designed so that the crosshairs are always centered.I have not seen a scope with crosshairs that move for about 40 years.If your scope has 1/4 minute clicks, then the strike of the bullet moves 1/4 inch at 100 yards for every click.1 inch for 4 clicks and so on.If you rifle shoots 6 inches high at 100 yards you should turn it down 24 clicks to strike dead on.Many hunters and shooters adjust their scopes to strike 1 1/2 inches high at 100 yards.Then it will be accurate to about 300 yards without further adjustment.
Feb 15, 2009 | Pentax 4.5X-14X 42mm Pioneer Matte Rifle...
Pentax 4X - 16X 50mm Lightseeker-30 Matte Rifle Scope with Side Parallax Ad Logo
188 people viewed this question
Top Pentax Optics Experts
jasbo
jasbo
Are you a Pentax Optic Expert? Answer questions, earn points and help others
