Question about Frigidaire GLEQ642A Electric Dryer
Dryer keeps shutting off after few minutes.
I have a Frigidaire GLEQ642A electric dryer.
Recently when I set the timer on my dryer it only stays on for about 4 minutes and then shuts off. I start it again only to have it stop again.
But when it is on it does dry the clothes. The heat works.
I clean the lint out of the trap before EVERY use and the vent is clear so I know that isn't the problem.
I don't use the dryer a lot. Only for sheets, towels and whites. I don't over fill it.
What could be the problem?
  • 979 Answers
It sounds like to me that the timer may be bad. Does your breaker trip when this happens? If it does, then it is probably not the timer. The motor turning the drum might be going bad. It could be building up resistance then cutting it off on overload(current). Try to bypass the thermal overload switch which is located under the top. This may very well be your problem. Let me know how this does.
Posted on Jan 28, 2009
My Frigidaire Dryer will not progress through any cycle.
You are going to need a new timer for the dryer.
Feb 23, 2018 | Frigidaire Electric Dryer
Frigidaire electric dryer. 1.5 years old, stopped turning and only hums when button is pushed
Hello
Is it a pleasant sounding hum, like the sound of a motor running? If so , probably your belt broke.If that hum goes on and on for several minutes, it's definitely belt. Bad motor or start relay, would cut out quickly. Either way ,youv'e got to pull out machine and pull off back to inspect.
Aug 18, 2011 | Frigidaire GLEQ642A Electric Dryer
My dryer has stopped heating up. It will still run but not get hot. I have checked continuity on the heating element, and thermostat. What could it be and if it is the timer how would I check that?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 03, 2011 | Frigidaire GLEQ642A Electric Dryer
WE have no heat in the dryer. It will keep running but no heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 15, 2010 | Frigidaire GLEQ642A Electric Dryer
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
When i turn the on switch i hear a humming as if it is going to start but it does not. my dryer brand is Frigidaire FEQ 332 E s
Depending on the hum you hear (if you hear the sound and it keeps humming) the belt that connects the motor and the drum is probably broken.
If the hum only happens when you turn the on switch, the motor has probably failed.
Aug 31, 2009 | Frigidaire GLEQ642A Electric Dryer
Frigidaire GLEQ642AS2
Sounds like a wire problem. Frist unplug the unit. Then take the cover off where the wires go in the back to check for a burnt wire. If that is ok you need an amp meter to check for the heater amp draw. You could have a weak breaker.
Apr 24, 2008 | Frigidaire GLEQ642A Electric Dryer
Frigidaire dryer
There is a switch under the lid,Look for a slot onder where the lid rests on the dryer,there is an actuator under there where the dryer lid when shut should avtivate,this switch is either bent out of place,or the little pin that hits it when shut is missing or broke off.
Aug 07, 2007 | Frigidaire GLEQ642A Electric Dryer
Frigidaire GLEQ642A Electric Dryer Logo
242 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
