Question about Toshiba Satellite M35X-S109 Notebook
LCD screen mostly dead
My friend went to pick up the remote control and instead grabbed the laptop and something popped/snapped, and now the screen is pretty much crap. Only the left side displays normally except for a few lines through it and everything else is just crap, only showing white or black. How would I go about opening it and finding whether it's just a broken lighting tube or if I need to completely replace the LCD? It looks like replacement lcd screens are about $300 and for that much, I'd rather buy another laptop. I can always use the HDD as an external and put the ram in another laptop I have. Any help on opening it would be appreciated. Thanks.
  • Leon Cham Jul 27, 2007
    It's a Toshiba Satellite M35X-S109 that I bought 3 Thanksgiving 2004. I'm not exactly how he mistook it, but he grabbed one corner of the laptop and something broke on the inside of the LCD. Hooking it up to a monitor is fine, except that the laptop doesn't have the native resolution of my 22" Westinghouse. What kind of extended warranty are you talking about? Do you have a link I can take a look at?
    Thanks for everyone's help.
Call Toshiba at 800-240-7100 to get your laptop fixed free under the extended warranty. Toshiba will tell you a repair location locally to take it too.
Posted on Aug 01, 2007
  • 181 Answers
Can you tell more about how this happened? (How do you mistake a remote for a laptop, or vise verse?) Where did your 'friend' grab the laptop? Also, can you hook up an external monitor to the laptop and tell us what that screen looks like? These things will help determine exactly what needs to be replaced. BTW, did you know your system has had a warranty extension till November due to a manufacturer's defect? Might just get in touch with Toshiba, tell them your system's having issues and see what happens. I've sent 4 of these models off to be repaired under the extended warranty. Good luck, let us know how the external monitor looks, ok?
Posted on Jul 25, 2007
    Problem Solver:
  • 10 Answers
There are no lights to replace in an LCD. If the LCD is damaged in any way, it must be replaced. Sorry. Email me the model of your laptop. I may be able to find you a cheaper screen.
How do i fix a black corner on my laptop screen?
You damaged pixels in the LCD screen, Camilia. The answer is No. You have to replace the LCD screen.
[There are statements made, that a warm water damp clean cloth, can be used to gently massage the 'afflicted' area. Ummm, No.
Drip ANY water inside, and Poof! Bye-bye laptop AND LCD screen.
(Yes, even with ALL power removed. To include the CMOS battery inside. { RTC battery } Water droplet/s could still be present when power is reinstalled )
Statements made about gently using a pencil eraser on the area.
Compresses the layers of the panel, and forces oil to move around.
Does NOT always work, and may damage the LCD screen further ]
How tough is it? Doesn't take a rocket scientist. (Sorry Gort)
It's like doing an easy puzzle.
Example using an Asus K53U laptop,
1) ALL power is removed. Remove the AC adapter, and Battery.
2) Open the laptop. Remove the Screw Covers from the LCD Panel Bezel.
(The thin plastic frame in front of the LCD screen )
Screw Covers may be flat small pieces of plastic, or rubber covers.
Both will have a type of rubber cement on them. They are carefully removed with a pick type of instrument. (I use a computer pick)
They are then, one at a time, lightly stuck to the bezel, so they can be reused later.
Then all Philips head screws under the Screw Covers, are removed.
The LCD Panel Bezel has protrusions formed out of it's plastic body, and they surround the outside edges of the bezel. These are Tabs.
They snap into Latches, formed on the inside edge of the Display Cover.
The method to remove the LCD Panel Bezel, is to use your fingernail on the inside top edge/middle, of the bezel, and flex it slightly up away from the LCD screen. Then move your fingers along under the bezel on each side at the top, and pop the Tabs out of the Latches.
A thick guitar pick does help immensely. Use care when removing, but be aware that the bezel is made of space-age plastic. Snap, snap, snap, when the Tabs are freed from the Latches. Almost sounds like you are breaking something, and is a slightly tense situation for your first time.
Unplug the cable (Wire/s) from the screen Inverter, IF a screen Inverter is used. Usually mounted to an area at the bottom of the LCD screen.
If it does not use a CCFL for a Backlight, and uses LED's for a Backlight, it will not have a screen Inverter.
(Cold Cathode Fluorescent Lamp)
Average example of a screen Inverter,
(Approximately 3 to 4 inches Long, 1/2 inch Tall )
Lay the bezel aside. The LCD screen has a metal frame around it. Looks like a thin picture frame. On each side of this frame are Brackets. The screws are removed that hold the brackets, to the LCD Screen Frame.
Then the LCD screen can be tilted forward, and Video Cable removed.
The Video Cable's connector on the LCD screen side, has two Locks on each side usually, that you depress in, in order to unlock the video cable connector, and unplug the video cable from the LCD screen.
Reverse steps to reinstall.
Note that on the example for LCD screens, just the manufacturer code number is stated, not the laptop.
Look at the back of the LCD screen you removed, and match up the correct numbers.
For additional questions please post in a Comment.
Sep 03, 2012 | Samsung Computers & Internet
Tv remote wont work the lights turns on but still wont work
There are two ends to IR control; the remote itself and a receiver inside the set that is active any time the set has AC available. Testing the receiver end requires a known-working remote control but you can check to see if the remote is still sending IR signals by taking any digital camera you have on hand, turning it on as if you wanted to take a snap of something, watch the display while you aim the working end of the remote toward the camera's lens and holding down any button on the remote. If the remote is sending IR signals, you will see these as white spots, often blinking rapidly, on your camera's LCD screen.
If the remote is outputting IR, the receiver in the TV is likely dead and will require replacement.
Jun 01, 2012 | RCA Televison & Video
How to replace LCD panel on Toshiba Satellite M105-S3004 Notebook?
Plastic Display Bezel is not as simpy as you think. It is made of space-age plastic.
Procedure is the same as for a Satellite M110 series, and M115 series Notebook PC,
Just to add;
After the Screw Covers are removed, and the screws, from the Display Bezel, the Bezel can be 'popped' off.
The Bezel has plastic protrusions, or tabs, extruded from it's plastic frame. These tabs snap into place in the Display Cover. (Top cover of laptop)
There are tabs formed on the inside edge of the Display Cover, that the tabs from the Display Bezel, snap into.
When I started years ago, I used a guitar pick to ease the Bezel up, so I could get my fingertips under it. (OUTSIDE edge of Bezel. Not inside edge where the LCD screen is)
Now I don a set of anti-static gloves, and ease the inside middle edge of the Bezel, (LCD screen side), up. Then I start working towards one corner, until this portion pops free, and then I go towards the other corner.
Once you work a side loose, and the bottom, the rest of the Bezel starts popping free.
Although the Display Bezel looks to be flimsy, as stated previously it is made of a space-age plastic. Pretty tough stuff, really.
Just go slow, and use care.
When you hear the tabs pop up for the first time, you may think you have broken something. Nope.
Just wanted to state to ease your mind.
Make SURE the LCD screen you are purchasing is THE correct one.
An LCD screen, and the screen Inverter, are a MATCHING pair.
Crossover the manufacturer name, and model number on the back of the LCD screen, to the new one.
Or go with the LCD screen replacement manufacturer's information. B
If so, be sure there is a Return option, if the new replacement LCD screen proves to be the wrong one
[ An LCD screen does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Some of the newer LCD screens use LED lights for a Backlight.
The Toshiba Satellite M105-S3004 Notebook PC, uses a CCFL for a Backlight)
A screen Inverter is used to convert the electricity (Power) from the laptop, for the Backlight, and the LCD screen ]
Jan 04, 2012 | Toshiba Computers & Internet
My wife has a Samsung NP-N310 Netbook. Around Thanksgiving we went to see some friends. Overnight, some ants got into the screen of her netbook. She tried to tap on the screen to chase one away, and killed...
I do not have the manual for your laptop. This link will give you a general idea on how to remove the LCD bezel.
Good luck.....
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 19, 2011 | Samsung Computers & Internet
My laptop started to slide off my bed...I grabbed it before it hit the floor. I grabbed ahold the screen. Now where my thumb pressed on the screen is red and black and there are several red and hot pink...
You have probably damaged the LCD display by compressing it. It may improve over time but it is unlikely that it will go back to normal. You can try gently massaging the screen and see how it affects the issue, this is a method to repair dead pixels.
Hope this helps,
Jul 02, 2010 | Sony VAIO VGN-N130G/W Notebook
Dropped and screen went black.still turns on but the screen doesn't work
Attach and external monitor and boot the machine. If you don't have one, ask around your friends and family... someone has a monitor.
If you can see stuff on the monitor when it boots, but when you boot with no monotor the laptop screen is blank, then you most likely have a dead lcd panel on the notebook. It would need to be replaced.
If the external monitor also shows nothing during boot then you likely have larger problems.
Aug 09, 2009 | HP Pavilion dv9000z Notebook
Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
Jan 04, 2009 | ViewSonic NextVision N3260W 32 in....
Need instructions to replace the bezel on a gateway 7330gz
Just like any other laptop LCD screen, edtechservic. Remove the rubber caps that cover the Philips head screws, remove the screws, and work around the bezel to pop it loose, a little at a time.
Top cover up, you are looking at the LCD screen. Look at the top Left and Right corners of the screen bezel. Look in-between. Now look along the bottom of the screen bezel. See those small rubber caps? G-E-N-T-L-Y pry them loose with a 60 or 90 degree pick. (In your computer repair kit)
Use care, and finesse! You don't want to scratch the clients laptop!
Now loosen, and remove the screws underneath.
Use a Jewelers flat tip screwdriver, (No.2), and ease it in the parting line, that you will see between the bezel, and top cover. Don't go more than a 1/4 inch in! You could be up against the LCD screen metal frame, if you go too far in. (Which could break the LCD screen)
Won't ease in there? Move over an inch or so. You could be hitting the plastic part of the bezel, that snaps down into the Top Cover.
There are several of these plastic protrusions, that stick down from the bezel, and snap into place in the Top Cover. Every few inches or so.
After you start easing one of these plastic snaps out, (Plastic protrusion I spoke of above), move along the edge, pick another place, and start easing it up. Keep bringing the edge up a little at a time. (Bring the back of the flat tip jewelers screwdriver down)
When you have gone along, and raised a large portion of the bezel, you should hear a distinct Click, as one of the plastic snaps come out of the Top Cover.
If not, move back to the first plastic snap that started to come out, and place your flat tip Jewelers screwdriver next to it. Bring the back of the screwdriver down to pop that plastic snap up, and out.
Hearing it your first time might make you a little stomach sick. You'll think you broke something! If you go along, and raise the bezel up a little at a time, you'll be okay. The bezel is made of space age plastic, and is VERY tough! You can't get crazy with it though!
When you have gone almost all the way around the bezel, the last few inches may just pop up, and out.
This link shows you with photos, and information, for a Gateway MT6704 Notebook PC,
This guide is to completely replace the LCD screen. You can just use the information under the first five photos, for bezel replacement.
Nov 15, 2008 | Acer Aspire 3000 Notebook
Why does the LCD act crazy?
select reset all function in menu and press ok. Your camera will set on default factory setting.
Mar 16, 2008 | Canon PowerShot A570 IS Digital Camera
Toshiba Satellite M35X-S109 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
