Question about Linksys EtherFast Workgroup 8x10/100 Mbps Networking Switch
Two computers and printer dont communicate with workgroup swith
I tried to create home network using Linksys 8-port workgroup switch. Now one computer gets internet and is on "Network". The other computer and printer that are also plugged into the switch, are not part of network.
  • 3 Answers
Do you have a router in front of the switch? Most ISPs only give you one or two "public" addresses. If you don't have a router in front of the switch, your computers and devices will not receive the "private" addresses they need to communicate with each other and the internet.
Posted on Jan 28, 2009
I have small network in an office, with 8 - port Ethernet switch. after buying two new PCs, i have tried to expand the LAN by adding another switch and i couldnt dont know why. i have connected the two...
Sir your computers are not in the same workgroup that's why coundn't ping the computer please open up *my computer then right click in it and go properties then on to the computer name > network id at the right side of that properties then add you network name what ever your have then it will work properly
( Note: do these things on that computers which is connected to the other port)
Thank you
Mar 29, 2012 | D-Link DES-1008D 8-Port Ethernet Switch...
I purchased a wireless router from a yard sale. and need a network to connect to another computer of mine can you help
installing a network
requirmenst rj45 crimping tools and UTP cable
before u crimp the rj45 must fallow the color coding
white orange
orange
white green
creating a workgroup for file and printer sharing
visit this link for window xp
http://reviews.cnet.com/4520-11334_7-6232456-3.html
http://www.home-network-help.com/set-computer-name.html
for window 7
http://windows.microsoft.com/en-US/windows7/Join-or-create-a-workgroup
note all workgroup name should be same
ex.. (you computer1) computer "name is: com1" workgroup is: maywrkgroup"
( your computer 2) computer "name is: com2" workgroup is: maywrkgroup"
May 27, 2011 | Trendware TRENDnet TEW-432BRP 54Mbps...
How do i connect two computers so they both have the same ip address i have a linksys 5-port workgroup switch will that work ? also i had hooked it up but only one of my computers had internet
They cannot have the same IP address due to the mechanics of DHCP. Buying a cheap 50$ router (not switch) will fix your problem as your internet service provider will see that device as a single unit that it will assign an IP and then the router will give out internal ip addresses so that they can get online. The switch does not have this functionality.
Feb 16, 2011 | Linksys EZXS55W EtherFast 10/100 5-Port...
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Aug 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
My linksys network switch is not connecting network computer, what can i do to get it back to work?
Do you have any activity lights on the Linksys? If not your switch has no power a hardware problem. Try to power off for 5 seconds and restore power on the Linksys unit. Try to shut down (do not restart) all computers. Are all the activity lights off? If not again power off the Linksys for five seconds and restore power. Power on the computers and verify the activity lights are now green for each computer. If the computers are not networked and the activity lights are green, check your network settings on your computers, which could have incorrect TCP/IP settings or workgroup. If one activity light is not green for that Ethernet connection, check your cable connection or replace the Ethernet cable. The workgroup should all be the same name. The TCP/IP address should be the same with the exception of the last set of host digits which should be unique to each computer address.
Jul 27, 2010 | Linksys SR224 24Port Ethernet Switch
Linksys EZXS16W Issue
Hi There, first of all you need to connect from your modem or router's port a link. Use a cat5 ethernet cable from the modem to the switch or if you also use a router from a port in back to the switch. Then when you plug in other computers it will see the internet connection. Good Luck...
Oct 28, 2009 | Linksys EtherFast 10/100 16-Port Workgroup...
Home Network sharing issues using 2wire wireless modem
Did you manually assign the IP address to your shared devices? If so, the Linksys and the 2wire have different IP schemes.
2wire Gateway IP address:
192.168.1.254
255.255.255.0
Do an ipconfig /all on your computer and compare it to the ip scheme on your devices.
Feb 07, 2009 | 2wire 2700HG-B Router (2700HGB)
Can I create a closed hub lan using MS Server 2003 and a client?
try going into my network places and on the left pane go to set up ahome or office network make sure you do this on each computer and the workgroup name must all be the same on each computer you want to be in that network.
Nov 19, 2008 | Computers & Internet
Setting up my HOME network! HELP!!!
Sounds like something is not right with the sharing... Assuming that computer 1 (the computer with the printer) is sharing and everything is set correctly, I would change the workgroup name. Instead of using "MSHOME" use say some basic word like "example" or some other name.
Ironically for my workgroup here I call it "StarWars"
needless to say my printers and everything shares just perfect. When you use "MShome" there's restrictions on what XP professional and XP home machines see on the network. I changed the workgroup name and that solved that problem.
Be sure to put all computers on the same workgroup name that you pick. You can even choose your first name if you want.
Dec 29, 2007 | Computers & Internet
Linksys EtherFast Workgroup 8x10/100 Mbps Networking Switch Logo
166 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
