Question about Dell Dimension 4700C PC Desktop
Power surge on hub port
I keep on getting a tab that says there is a "power surge on hub port" and it is causing my computer to run slowly. the message reads "a usb device has exceeded the power limits of its hub port. forassistence with this problem click this message".... then when i click the message it reads "the usb device has malfunctioned and exceeds the power limits of its ub port. you should disconnect the device." i don't know which hub it is referring to/ or it's location (it is the fourth one on the list), since there are only two hubs being used total. one hub, the sixth on the list is for a wireless g 'usb adapter, and the one that is in bold is the fourth one and is called "and unknown usb device". can't get the message to disappear.
  • mymail0505 Mar 13, 2009
    i accidentally clicked the button "close" instead of reset. it doesn't function anymore. how can i get it functioning again?
  • 26 Answers
Try this to find out which one of your components has an issue. Turn off your machine then unplug all of your USB cables. Turn your machine back on and plug in one of your USB cables. Verify the component you just plugged in works correctly and if it does plug in another cable and verify that component is working. Continue these steps until you have the one component that displays the error you have seen. That component is most likely the cause of your issue and should be replaced.
Good luck, Greased.
Posted on Feb 07, 2009
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
Usb surge hub port exceeded
The message indicates that either a device or the USB controller has drawn too much power.Disconnect all external USB devices (make sure that the touchpad is active if you use a mouse with the notebook). Then click on the Restart command on the error message.
Try adding one device at a time and see if the message recurs. Try moving the devices to a powered USB hub and try that at different USB ports. (Disconnect and reset the message if needed.)
You can choose to ignore the message. In XP, click Start > Properties. Select the Taskbar and select customize. Set the Surge message to Ignore.
Since this error most often occurs when the computer is hibernating, go to the Control Panel section for Power Options. Disable the System Standby (set to Never in the Power Scheme Tab) and Hibernate (uncheck in that tab) options. Note: these settings will limit battery run time. (Windows XP didn't handle these well.)
Other solutions that may help is to set the USB controller to USB 1.0 or to disable it. You can disable this from the Device Manager; scroll down to the Universal Serial Bus.
If you have a device that is pulling too much power, you will need to replace it. (That's more cost-effective than repairing the power draw for most USB devices.) It could damage the port.
I hope this helps.
Jun 10, 2012 | Toshiba Satellite 5105-S501 Notebook
I Have Toshiba Satellite Laptop, i am continuously getting pop up message " Power Surge On Hub Port " A USB device has exceeded the power limits of its hub port. Please help how to stop this pop...
Remember the help below is only a fix for seeing the error message not for overdrawing the port.
To stop overdrawing the port you need to either use a power supply or a double USB cable.
To prevent seeing the USB Power Surge alert message, complete the following steps:
Click on START, Click on CONTROL PANEL, Double-click on the SYSTEM icon, Click on the HARDWARE tab, Click the DEVICE MANAGER button, Click the "+" next to Universal Serial Bus Controllers to expand the selection.,Right-click and select PROPERTIES on the Intel® USB UNIVERSAL HOST CONTROLLER (not the USB Root Hub),Click the ADVANCED Tab, Check the box that says: "Don't tell me about USB errors"
Nov 29, 2010 | Amstron Toshiba Satellite A80 Laptop AC...
Anytime I plug something in to the USB port it give a error message that states, Power Surge on the USB port. What can I do to fix this?
The USB device could be drawing more current than the USB port can supply or the USB port may be faulty.
Get a powered USB hub and plug it into your computer's USB port and then plug the USB devices into the powered USB hub.
Aug 16, 2009 | Dell Dimension 3000 PC Desktop
Power Surge on Hub Port
hi, Please reinstall the chipset drivers and "Turn off the error messages from Device Manager => USB Host Controller => Advanced Tab => check mark "Don't tell me about USB errors"
Jun 12, 2009 | Compaq NX6110 TFT XGA Notebook
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Power surge message
Problem :Overvoltage on USB hub port
Solution: Look carefully at that same port and you will four gold pins make sure they are NOT touching each other..
Apr 16, 2009 | Computers & Internet
Error power surge on hub port
Some USB devices draw too much current from the computer's USB port and you get an exceed power error message.
To get around this problem, get a powered USB hub and connect it to the Computer's USB port and then connect the troublesome USB device into the powered USB hub.
Apr 09, 2009 | Lenovo 3000 N500 Notebook
Western Digital Passport 160 GB external HD won't load.
WinXP SP2 blocks the use of the drive because it thinks it draws too much power. But there is a simple procedure to override this (from WD site):
"Problem:
Under Windows XP, an error message of "Power Surge on Hub Port" or "USB device has exceeded the power limits of it's hub port" is displayed when connecting a USB device to a USB port on a computer or Hub.
Cause:
Under some computers, USB devices are only allowed to draw a maximum of 500 milliamps (mA) per connection from the USB port on the computer system or from a USB hub. Under the Windows XP Operating System, with the release of Service Pack 2, if a device attempts to draw more than this (500 milliamps), a USB port balloon message is displayed to indicate this over current condition. When connecting a USB device that draws power from the USB bus, a very brief over current condition is sometimes detected by the OS, and the warning message is displayed.
Resolution:
This message has no affect on the functionality of the USB port. The USB hard drive should still function correctly on the USB port regardless of the error message. To prevent the USB Power Surge Alert message from displaying, please complete the following steps:
Click on Start.
Click on Control Panel.
Double-click on the System Icon.
Click on the Hardware Tab.
Click on the Device Manager button.
Click on the + next to Universal Serial Bus Controllers to expand the selection.
Right-click and select Properties on any listing that displays USB UNIVERSAL HOST CONTROLLER.
Click on the Advanced Tab.
Check the box that says: Don't tell me about USB errors."
This works fine, and the drive works fine afterwards. I suspect it actually draws less power than they say. Maybe it has a brief power draw spike on startup, but it's running power seems less. In any case, it works fine without the Y cable. I do think it is tacky that WD doesn't give the cable for free, since my $7 Sabrent 2.5" Hard drive enclosure came with a y cable.
But most likely the drive will work fine for you. It is a lovely quiet drive, and takes up no space at all.
Feb 01, 2009 | Western Digital Passport 160GB External...
Power Surge error message
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
Dell Dimension 4700C PC Desktop Logo
597 people viewed this question
Alun Cox
