Question about GE Nautilus 24" Built-in Dishwasher
I have a GE Nautilus that wont pump out the water
I have taken the drian hose off and sucked out the water witha shop vac. No clogs. but still does every thing but pumps the water out. I can hear the pump running but nothing. any fixes?
  • Anonymous Jan 29, 2009
    I have a GE Nautilus that wont pump out the water problem
  • sirskruffz Feb 06, 2009
    wont let water past the check valva, replaced the valve and nothing
    Problem Solver:
  • 8 Answers
Do u get water to fill and not drain?
Posted on Feb 06, 2009
Water wont drain, water leaks out of pump and from the front of the dishwasher
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 01, 2011 | GE Nautilus 24" Built-in Dishwasher
Water is not draining out
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 13, 2010 | GE Nautilus 24" Built-in Dishwasher
Won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Daniel
Aug 07, 2010 | GE Nautilus 24" Built-in Dishwasher
I have standing water, what do I do?
you can use a wet dry shop vac and attach it to the end of the drian hose to remove the water.
Disconnect the hose from the garbage disposal and attach the shop vac to it this will remove all the water.
once the water is removed check the drain pump for any obstructions
Mar 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
Water is not draining? thank's
there are a couple of things that could cause this issue.
1. is the drain pump is faulty
2. the main control board is faulty
3.there is some kind of object stopping the pump from turning
4 the wiring to the pump has become dislodge or loose.
5 there is a blockage in the drain hose from the pump
6 if you have a wet dry shop vac disconnect the drain hose from under the sink and attach the shop vac to the hose and try and remove the water.
If the water drain easy then check in the pump for something that could be stopping the impellar wheel or faulty pump.
If no water comes out then there could be a grease plug blocking the hose you can use a hair dryer and heat the area of hose the grease plug may be in to remove it. good luck i hope this was helpful for you
Feb 06, 2010 | GE Nautilus 24" Built-in Dishwasher
My GE Nautilus DW doesn't fully drain. When it is drained as much as it will it leaves water in the sump at the rear right. If you run the pump at that point, it sucks water out of the sump, but when you...
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer or control
Replace if defective (note: uncommon problem).
Oct 28, 2009 | Dishwashers
The dishwasher won't drain and we have no air gap. what can we try? the sink drain is good
The first thing to try is to unhook the drain hose to the drain. dump out any water, then blow in the hose or use a shop vac reattach the hose and then run through cycle. If this did not work, you will need to pull out the dishwasher, (shutoff electric to d/w) remove hose from pump, remove debris from drain pump, make sure hose is clear, reattach the hose, and run through the drain cycle.
I am assuming the d/w was draining previously. If the above suggestions do not work, the next issue is to replace the drain pump.
Good Luck
Oct 15, 2009 | GE Nautilus 24" Built-in Dishwasher
Unit will not drain. It will fill with water in normal manner. Circulating pump also works normally. Float switch seems to be sound. But the wash water is not expelled as it ought to be.
Something simple to check is the drain hose. I am an installer and have seen this many times and people will buy a new dishwasher after putting in a new garbage disposal. If you did, did you remove the knock out plug from the disposal? Next, remove the drain hose end from under the sink and try sucking the water out with a wet/dry vac. All the water from the dishwasher should easily be sucked out from any dishwasher except a GE brand. If not, your drain hose is clogged.
Sep 25, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
My GE Nautilus will not drain. I have taken out the covers on the inside to check for blockage and there is none. I took the cover off the lower portion to check if motor is turning and I am not certain...
do you hear the pump running? i dont like the idea of calling it a grinder.....things can still cause your pump to clog need to unassemble from the inside and check pump...also check drain hose for clogs. mac and cheese is a stinky mess.
Jun 10, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus not draining water out
If the pump is not running, it could be the pump or the timing switch. My GSD2600G00WW would not drain. Wash cylce was running fine. I have just taken out the solenoid attached to the pump and the solenoid is burned out. Will replace tomorrow and see if that does the job. On line price for a new solenoid is about $35.00
Oct 16, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
235 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
