Question about Maytag LAT2301AAE
Strong mildew smell coming from washer
I have a maytag model no.LAT2301AAE. For about a month now my washer has been putting off a strong mildew odor. I have ran bleach through it, cleaned all the drain lines. Even tore the top of the basket apart and cleaned it. The only thing I haven't done is take the agitator and drum out to see if a wash cloth or sock has got stuck in there, if that is even possible.
Help please, we can't breath anymore
  • 130 Answers
Try running a cup of white vinegar thru a wash cycle w/o clothes.
Posted on Jan 28, 2009
Testimonial: "That worked great! Thank you so very much"
Strong mildew smell in washer is making cloths & towels smell bad, how do you get rid of the problem?
if you look inside washer there is a rubber rim on the inside around the openning. Look inside and you will find where the stink is coming from. Keep door open when not in use and wipe inside of rubber trim to keep the mildew out.
I use tilex sometimes and do a rinse spin.
Nov 16, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune washer has bad odor, city water.
There is no filter in your washer that would cover the odor issue.
The website link below will give you all the information concerning odors in a Maytag Washer
http://maytag.custhelp.com/app/answers/list/kw/odors/p/293/r_id/108284/sno/1/search/1/session/L3NpZC9RRDdZdDhEag==
Jul 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Last few weeks there is a foul odor coming from the washer
How old of a unit? The new high energy effeciency washers are known for their "odors" due to the fact they dont drain out all water and it can mildew inside. Some solutions...leave door ajar after wash cycles , water will evaporate, there is products you can add every so many loads, one product being "affresh" ,,,some other people will run strong bleach load every so many loads it will kill mildew. These washeres have been out for years in Europe and they have same problems, its just inherent with product
May 21, 2009 | GE WSXH208A Front Load Washer
Odor coming from front door jams after shutting car door
I have the same problem in my 2011 sonata and i finally figured out where its coming from, its inside the doors! Put your window down and then smell the top of the door where the window slides down in...its so gross....its been making me sick to my stomach!
Apr 11, 2009 | 2002 Dodge Durango
Mildew smell coming from bottom front of refridgerator.
Carefully empty the drain pan under the fridge and empty it.
Then clean with a bleach and water solution.
Feb 22, 2009 | Hotpoint HTM17BBSSA Top Freezer...
LG washing machine has AWFUL mildew smell
Same here. We bought ours January 2005. Love the machines and take great care of them, too. Then the smell in the washer which seemed to affect certain clothes, like thick sweat pants and t-shirts (they smelled really "sour"). After doing some searches I found on this site where someone had recommended using a product called Affresh. I figured I might as well try it since my other attempts failed. This really worked for me. I bought it at Home Depot for $7 for a pkg of 3. I used 3 tablets per their directions, as this was my first time using it (afterwards they recommend using only 1 tablet per month). I was totally amazed as the smell was gone. I hope it works for you, too!
Oct 05, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Strong Musty odor
You will have take it apart, removing the wash tub and all top plastic parts. I just finished taking mine apart do to a mouse that chewed a larg hole in my water tub, and notice tons if old gunk mold and build up. It smells and will not go away unless you scrub it. Sorry to say it is all internal pouring clensers will only wash thru the tubes.
May 27, 2008 | Kenmore 15864/15862 Top Load Washer
Mildew Smell
Let me add...I was having a problem with the washer draining. I followed these instructions http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet from this website. I found two socks and they were extremely mildewed and the junk that came out smelled. It may be worth it to check and see if there is something in the pump. It wasn't very hard to do. Let me reiterate something that was mentioned...if your washer is not in a garage or somewhere you don't mind a good bit of smelly water leaking out...definitely use a shop vac first.
Feb 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer
Depending on how old it is, you should just be able to repair the unit if you have the will-to-do.  The smell more than likely is coming from a possible mildew growth inside the machine.  Sometimes you can remove the inner basket and clean the inner and outer baskets.  If you can find the leak (which on older models shouldn't be to hard to do), you should be able to correct pretty easy.  Be sure to check hose coming off water mixing valve and the smaller tube for the water level switch (will run off of outer basket up to console).  Be sure that hose doesnt come off because washer will keep on filling (and it will to).  If you get leak stopped, try getting some strong bleach, and washing a "no-load" a couple of times at high level in hot water.  This may get rid of the problem.   Jim
Oct 11, 2007 | Washing Machines
Mildew smell
Try doing just a hot bleach water "load".  Also check underneath and around the machine to make sure it's not leaking.  If it did or is and you can see the mildew just spray it with bleach.
Oct 11, 2007 | LG WM-2277HW Front Load Washer
Maytag LAT2301AAE Logo
170 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
