Question about Toshiba Estudio 200L Copier
Wrong count i have a toshiba copier e-studio 281c, every time i make a copy, it will register in the counter as 2 copy been made, how to fix that problem. thanks
  • 3 more comments
  • drknowdrknow Jan 28, 2009
    thanks for the reply.. NO i am not coping double sided, just one side
    thanks for fast reply,,
    NO. only one side copy,, and it is a e-studio 281C toshiba machine
    thanks
    thanks for the reply,, i did check with toshiba, and the firmware is up to date,, it only need the combination code to go to a maintenace to change the counter from 2 to 1,, they told me it is set to 2 now, and i need the codes for the service mode, to be able to go and change it,,, example on my CLC1150 cannon, the sevice code is function 81,, so what is it for the TOSHIBA 281 C
    thanks
  • drknowdrknow Jan 29, 2009
    hi,, and yes they already overcharged me for 60,000.00 copy, and they wont fix the problem, so i have to take care of it on my own,, i talk to toshiba and they told me i need the service maintenance code and that will fix the problem
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are you copying double sided?
  • Toshiba Master
  • 643 Answers
FYI, if copy 1 side of A4, then is count as 1. If both sides, count as 2.
If copy 1 side of A3, then is count as 2. If both sides, count as 4.
That's the default settings on the MFP.
If u want to be copy 1 side of A3 and count as 1, u need to adjust the setting mode.
Press 08 and ON MFP, Enter 346, change "1" to "0".
Posted on Feb 13, 2009
  • sasheevja1 Feb 09, 2011
    Mr. didi, i think it is 08-352.... not 346. pls confirm the shb. There is no 346 in sys mode (08)
  • Toshiba Master
  • 2,794 Answers
It may need a firmware upgrade to fix the count. You will have to contact a Toshiba dealer in your area to get one.
Posted on Jan 28, 2009
  • Tim Babcock
    Tim Babcock Jan 29, 2009
    Wow I didn't know they were doing that. If that machine was charging you by the piece for a service agreement that could rack things up higher.
What can i do for toshiba 281c if it not giving clear copies?
replacing the drum is usually the most effective way of regaining print quality on laser printers with no extra marks on the paper.
Apr 04, 2015 | Toshiba E-studio 281c Copier
How do i check the ink/toner levels of Toshiba Studio 281c Printer/Copier
You will need the official software from the toshiba support site install it and it will show you toner levels
Jan 23, 2015 | Toshiba E-studio 281c Copier
How do I check Ink/Toner levels on Toshiba e-Studio 281c
My toshiba e studio 281c will not print in colour it will only copy in colour
Your print driver is probably set to monochrome. Usually there are to drivers set up on your computer: a pcl5 for black/white, and a ps3 for color--or vice-versa. Right click your driver; you can change the setting in your preference or properties section.
Oct 16, 2012 | Toshiba E-studio 281c Copier
How can i check the copy counter of toshiba e studio 181 copier machine
Date:06/04/2013Sir
My digital copier toshiba 181 showing page counting 179113 but when doing copy the previous reading is not increasing , it is stopped in 179113. could you give me suggestion to(Programe) reactivate the page counting.
Thanks
Golam Rabbani
Chittagong, Bangladesh
Apr 19, 2012 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Toshiba e-Studio 281C ADF not working
Make sure the ADF connector is plugged...
Feb 24, 2012 | Toshiba E-studio 281c Copier
How do I find the copy counter function on the E-Studio 600 copier?
If the e-Studio 600 is similar to other Toshiba models (like the e-Studio 452 or e-Studio 3510c) you can view the copy count by simply pressing the User Functions button, and it should be displayed in the lower right corner.
If you don't see it there, select Total Counter while you're in the User Functions screen, then select Print Counter.
Did that help?
Jun 06, 2011 | Toshiba COPIERS E-STUDIO 600 Copier
I have a Toshiba 281c and a few days ago the display started acting up. Now when you power up the machine the display lights up but has no text or menus on it. You can't change the functions it is stuck on...
try to enter service mode by pressing 08+power on
enter code 1501 you will see 2 sighns "+" on display
by using plastic stick you can calibrate your display
just touch this "+" jently
then wait few seconds till calibrating process
Good luck!!!
Mar 13, 2011 | Toshiba E-studio 281c Copier
Wrong count
You find that answer out on copytechnet.com. There are authorized Toshiba reps available on there to answer your question.
I don't work on Toshiba unfortunately. If I did I would give you the answer.
Jan 29, 2009 | Toshiba E-Studio 3511 Color Copier
385 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
