Question about Westinghouse LTV-19W3 19 in. LCD Television
Sony DVI ?? to HDMI or Component Video Cable
I have a SONY LDM-3000 Display Unit (TV) which have been connected up to a SONY Multi Media Box through a "SONY EXCLUSIVE CABLE" which is one cable but with a White and Black plug on each end (I believe that the white connector is for the video signals and the black plug is for the audio signals). The White plug looks like a DVI plug except it only have one big connecter next to the 24 smaller connectors and I have not seen any other DVI plug with this configuration. The black plug is a little bit smaler than the white plug and it has a 26 pin rectangular male socket inside the plug. I am moving the TV to another location and need to use HDMI or Component Video Cables but can't connect either to the TV because it only have the Described plug connections. Does anyone know if it is any adaptors for these specific SONY plugs?
SOURCE: TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Posted on Apr 29, 2009
SOURCE: No Signal report by TV when connected to PC
Try changing resolution and refresh rates.  I have seen the same thing on Macs, and found that the TVs expect a 60Hz refresh rate and at least the Mac likes to use a 75Hz refresh rate.  When the two mismatched the TV would not accept a signal.  The easiest way to make the change is to use some sort of remote desktop login like LogMeIn.com or GoToMyPC.com.
  • 11 Answers
SOURCE: wesitinghouse 37
Same problem I had... My problem was with any HD input from PS3 (only HD device I have), the PS3 was fine on other televisions so I determined that it must be a problem with the TV in question. I fixed this problem by unplugging the TV, letting it sit for about a minute and then plugging back in.
Posted on May 08, 2009
roety
  • 585 Answers
SOURCE: Westinghouse TV no stereo
Hi my name is Roety,
I can help you with your issue ,
Why don't you simply run the cable box and DVD stereo outputs direct to the receiver. Thats what most people do. TVs do not passthrough stereo signal very well do to DHCP compliance requirements .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Nov 11, 2009
Testimonial: "A very good solution, right under my nose. Thanks!!!"
budmrtn
  • 11361 Answers
SOURCE: Westinghouse LTV32W6HD. Turned it on and video is
If the picture goes bad after about 15~30 minutes, then more likely to be bad LCD controller bd. See sample of the failed LTV-32W3HD here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W6HD&limit=200
You can try running the TV with the back open with a small fan blowing in the back to keep it cool just to verify that it is heat related.
Posted on Jan 05, 2010
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
How do i connect sony mobile phone to sony tv
Watch and listen to your Xperia TM content on your TV
Open this link & watch this video will let u know how to connect sony mobile to bravia via mirroring.
Thank You
Dec 01, 2014 | Sony Cell Phones
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
Sony wega engine LCD model; ldm-3210 Monitor wont power on or respond to remote power botton. LCD flashes stand light continuously. What is the solution to this problem???
If the Standby light is blinking at the front panel of the TV, it seems that there is an internal malfunction occurred in the TV.
I will forward a link to a page where you can get more information and troubleshooting steps for this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
Please perform the steps provided on the page. If the issue still persists then service of the TV is required.
Jun 10, 2009 | Sony WEGA KDL-32XBR950 32 in. LCD HDTV
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
KP-53HS10 Real HD
On this TV there is only one input for any HD resolution. Input # 5 is the component input i.e. red/green/blue cable. Just get the correct cable and match colors from cable box to TV this will allow the TV to display 1080i resolution ( only one this TV supports ). FYI you will also have to connect the red and white cables to the appropriate inputs to get any sound because red/green/blue connectors are just for video display not sound. Once your connected you'll be able to access video # 5 be sure to set your cable box to 1080i resolution also. I hope this helps later J.
Dec 02, 2008 | Sony KP-53HS10 TV
Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
Nov 22, 2008 | Sony Grand WEGA KF-50WE620 Television
Westinghouse LTV-19W3 19 in. LCD Television Logo
1,098 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
