Question about Fisher and Paykel GC36 Gas Cooktop
Where can you order parts for Fisher Paykel GC36WAC Cooktop?
Two of the electrode for igniting the units are broken. I found the part numbers but cannot find where to order them, any ideas
Parts
530244 Electrode Wok 600 MK 2
530243 Electrode 350 MM Fish
530242 Electrode 600 MK 2
  • 145 Answers
These people can get anything you need for Fisher-Paykel:
http://www.fisherpaykelparts.net
If you don't see it, ask them. They can get it.
Posted on Jan 29, 2009
What is causing my Fisher and Paykel OR61 Duel element to on work high heat when turned on?
Likely a bad resistor Unit, I suggest replacement before it gets worst and possibley causes a fire.
May 27, 2014 | Fisher and Paykel CT560QX 23 in. Electric...
One of burners can not ignite only having clicking sound.
First you need to brush out the end tip of the sparking electrode and the burner metal part facing the electrode so they can create a spark. If not any result the you should remove electrode and check if the ceramic cover is broken and the sparking goes in wrong way and you will need to replace it.
Sep 10, 2011 | Jenn-Air JGC8430 Gas Cooktop
Back right burnor ignitor will not turn off, even when knob it turned to off of GC36 gas cooktop
Hi staneand,
I believe your ignition switch has come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 27, 2011 | Fisher and Paykel GC36 Gas Cooktop
My front left ignitor/electrode is continually igniting on its own. How do I get it to stop?
Somethings when we clean the cooktop with a damp rag especially around the knobs moisture can get onto the burner switches. When this happens it creates a short and spark the electrodes. Try to unplug the unit for 24hrs. I have had so many just dry out and never had a problem. If you try this and still get the clicking change out the wire harness part#WB18T10339. Its a series of switches that sit on top of each burner and connected to the spark module. I would recommend changing out the spark module part#WB13T10046. Both of the parts are only around $20-$30 a piece and you will have your cooktop running like new.
Please look at item numbers 323,318 on the picture thats what needs to be changed out national_a_r.png
Please rate me a "4" if I helped you. Have a super day!
Dec 14, 2010 | GE 30 in. JGP328 Gas Cooktop
Electrode sparking
Here is a tip that I wrote that will help you to find out why the sparker keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 29, 2010 | Fisher and Paykel GC36 Gas Cooktop
How do I fix a bad igniter on my F&P GC912 cooktop?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 18, 2010 | Fisher and Paykel GC912 Iridium Stainless...
Clicks but does not ignite. works with match or lighter.
You will need to change the Igniter. There are at least 2 igniters that operate with one knob. Some units all 4 igniters operate with one knob. The clicking you hear is the other Igniter or Igniters clicking. The Igniter for the burner that does not light has failed.
The model number you passed is missing some numbers JGP628 should be like this JGP628BEC1BB or this JGP628WEK1WW
The Igniters are NOT all the same:
AP 3191250
http://www.appliancepartspros.com/part_details.aspx?part_id=3191250&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d214810%26diagram_id%3d21784824
or...
AP3779012 (No image)
http://www.appliancepartspros.com/part_details.aspx?part_id=3779012&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5213362
It can even be a wire to the electrode / igniter that has found a chassis ground inside the cooktop.
When you have a complete model number go to this page and choose your model number:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JGP628
The item you may need is item 154 of the cooktop.
Thanks for using FixYa!
Kelly
Mar 08, 2010 | GE 36 in. JGP628 Gas Cooktop
GC913 wok ignitor installation
The electrode goes through the wok burner bowl then the spring fits under the bowl. You have to push it up until it clips into the groove on the electrode. Should be quite a tight fit.
Mar 27, 2009 | Fisher and Paykel GC913 - Stainless Steel...
Fisher and Paykel GC36 Gas Cooktop Logo
1,621 people viewed this question
Top Fisher and Paykel Cooktops Experts
Paul Carew
Are you a Fisher and Paykel Cooktop Expert? Answer questions, earn points and help others
