Question about Agri-Fab Agri - Fab Snow Blower - 42"
Cub cadet 10 snow blower
I am having a problem where the drive for the wheels stops. It could take up to 2 min then the wheels take off again. I have cleaned the drive plate, adjusted the tension. There were some skid marks on the plate, I cleaned those off too.
Any other suggestions, does not make sense to me why it is pausing like this.
  • bill_reen Jan 29, 2009
    Thank you, I wipe it down, but did not clean it, I do have some Carb cleaner so I will give that a try and clean them both up good.
    thanks for your help !
I have a 2 blade cub cadet and it pushes snow like a blade but the fan part that blows snow out shoot is spinning. Why wont the agars spin?
The simple solution is the replaceable shear pins in the front auger have sheared. This is normal and protects the snow blower from major repairs. I suggest going to youtube and search "replace shear pins on Cub Cadet snow blower." There are a dozen videos that will help you troubleshoot and make the repair.
Feb 08, 2017 | Cub Cadet Garden
I have a Cub Cadet 522 WE snow blower, it start fine but the auger will not turn. I have checked and there is nothing in the way. What should I try next?
The transmission that moves the auger is the most likely problem. If the Auger is a hydrostatic drive check the fluid in the drive unit.
Nov 21, 2016 | Cub Cadet Garden
It will not go forward or revirse
Look to see if your friction wheel needs replacement.
Jan 24, 2016 | Cub Cadet Snow Blowers. 24 in. Two-Stage...
What type of oil do i use
(32 degrees and above, 30w oil) - (32 degrees to 0 degrees, 10w-30) - (32 degrees to -20 degrees below 0 and beyond -20, 5w-20 or 5w-30) Cub Cadets call for a low ash oil. it can be purchased at any cub cadet tractor dealership.
Jan 21, 2016 | Cub Cadet Snow Blowers. 28 in. Two-Stage...
How do I adjust the chute on the cub cadet snow blower it only goes partway to one side and all the way on the other side
Un plug the chute control rod..put the chute in middle (foward) and the handle at 1 oclock and remount the chute rod..see at 3:40 on this video ===>
Feb 15, 2015 | Cub Cadet Snow Blowers. 26 in. Two-Stage...
What is required to attach a MTD Snowblower model 190-032 to a ty4000 lawn tractor
That looks like a Cub Cadet part # for the Snow Blower.
You will absolutely need to customize a Belly bracket and Mule drive. Possibly find a Cub Cadet belly bracket and modify it to match your mounting points on the TY4000
Oct 13, 2014 | Mtd Housing Auger 26" - 684 04071 4044
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
CC 989 quit pulling after replacing rear wheels
on my snow blower there was two positions to put the drive wheels back on, locked and unlocked. need to put the pin in the locked position thru the wheels and axles.
Aug 10, 2012 | Cub Cadet Garden
Agri-Fab Agri - Fab Snow Blower - 42" Logo
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Joseph Mueller
Joseph Mueller
David Ellis Rhea
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
