Question about Kenmore Freezer 20.6 cu. ft. Upright Freezer
Not cold enough?
Hi. I bought a used Kenmore freezer upright model 253.9280412 and after plugging it in and running it for 5-6 hours, it reached about 10 degrees and seemed to be stuck here. At a temp setting of 1 it just ran and ran and never got below 10 deg. As I backed the temp control down toward OFF, it finally cycled off. Shortly there after it came on again and continued to cycle at around 12-14 degrees. It would run for 4 minutes and off for 4 minutes. It did eventually go into defrost for about a 1/2 hour then came back on and ran unitl back to 12 deg. The freezer was empty with no food cause I want to make sure it's OK before I put food. Did I not leave it on long enough to reach 0 deg or so? Also there are no visible condensor coils but the sides of the freezer get very hot! I assume that the coils are there. Yes? The evap fan blows well. It's in my garage. Is it too hot in there?? Someone also left a service port on the high side so I connected a gauge and it read 165 psi or so when running. Seems normal to me. It's a 134A freezer. Help!! I have more questions but will stop here.
  • Rob Wilkinson Jul 25, 2007
    Thanks, I'll try to re-gas. System says 7oz. 134A. Can I re-gas from the high side service port as long as I don't turn the freezer on while gassing?
  • 51 Answers
Re-gas required
Posted on Jul 25, 2007
  • Ian Jul 26, 2007
    No NOT high pressure side!!!!!! BANG!!! Stick to the low.
SOURCE:
Why will it not come on?
The rust shouldn't make any difference.
When you plug it in, does the interior light turn on? If not, suspect the wall outlet - test it for power by plugging in something else. If the interior light turns on, listen very closely to the freezer. It should hum. If it doesn't, toy with the freezer control inside - it may just be turned off. Turn it to about midpoint and listen very closely to it again. If still no hum, wait a short while, then feel carefully on the outside of the cabinet - it may be running through a defrost cycle. The outside of the cabinet may get warm while that's happening, especially around the door gaskets. Wait a while (half an hour, an hour, for the defrost cycle to finish - the freezer should run then.
If it never hums, then the compressor isn't running, so adding freon won't make any difference. Instead, suspect the defrost timer - that's a little electronic circuit board inside.
If it HUMS but never gets COLD, then you potentially have a freon leakage problem. It's difficult at best, though, to refill a refrigerator or freezer - they don't usually have refill taps.
Oh, yes. If the internal light never comes on but you've proven that the wall outlet has power, it's entirely possible that the plug is bad and needs to be redone.
Jul 29, 2014 | Kenmore 12.1 cu. ft. Upright Freezer 2826
My Kenmore Freezer, 5649215011, won't get cold
Yes it is. You probably have a bad capacitor since it probably as been outside for this long. It is subject to aging even when not in use. This should be an inexpensive job.
Feb 13, 2013 | Kenmore 5 cu. ft. / 142 liter Upright...
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but...
it may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
Aug 12, 2010 | Kenmore Freezers
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Freezer not cold enough
the dryer is already sock ,, you need to change it and refill the gas
Jan 24, 2010 | Freezers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
New chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Jul 13, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Kenmore Freezer 20.6 cu. ft. Upright Freezer Logo
303 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
