Question about Fedders A6X05F2D Air Conditioner
I have a Fedders Model AEJ 12 E 7AB REV N installed in Nov 2000. When running the heat Monday night, we had sparks and smoke come out of the unit. A terrible smell took over the house for a few hours. We immediately pulled the plug and hit the circuit breaker. The sparks (fire?) came from behind the top louvers/grill. I think it may have been from lack of cleaning? We used to clean the filter regularly and only recently did we begin to get lax with it, so we may have gone about 6 months or more without cleaning. It was very very dirty. Is there something I should/could replace, or should I get a service person in here to look it over thoroughly?
    Problem Solver:
  • 8 Answers
I am a heating and cooling extrodinaire and it sounds like the blower motor has failed, but it could also be electrical burnout.(ciruit board, coil on a relay etc..) I would call a service tech. Most motors that are mounted in the air stream are called air over motors so if the filter was plugged and not letting enough air over the motor, its a good chance that the motor over heated.
Posted on Jan 29, 2009
I have a older Fedders unit model number CRB120CNA what is the tonnage of this unit
I don't believe you have copied that number correctly.Look for a serial number. Is this a window unit?
Jun 27, 2017 | Fedders Heating & Cooling
I replaced all of the contractor installed smoke detectors with First Alert Model P1210 detectors.
The replacement smoke detectors may have had low batteries when installed or the contractor-selected mounting locations may be wrong.
Feb 04, 2017 | Heating & Cooling
Fedders frustration
Sorry we can be of no assistance on this problem.
Mar 13, 2017 | Fedders Heating & Cooling
I have a Fedders dehumidifier Model A7DH45B2A REV-A. The nipple on the float broke off. Where can I buy a float? Do you have one? How much is it?
Although Fedders, as you knew it is no longer in business, some parts are still available.
Here is a link, with an explodes view of your model's parts.Locate th epart you need and then enter the part number, to see if it's still available. FYI Maytag Dehumidifier parts are interchangeable with Fedders. Fedders made the units for Maytag.
http://www.appliancefactoryparts.com/dehumidifiers/fedders/a7dh45b2a.html
I hope this helps you find what you need.
Jun 19, 2011 | Fedders A7DH45B2A Dehumidifier
Smokes bad when burner kicks on
Hey mate,
What brand of burner are you running? I am a Karcher Tech but they all work on the same principle,
Your burner is getting to much diesel/kero, most have little flow swicthes on them to tell them to pump fuel or spark when there is water present in the burner coil, if this switch is faulty or getting a faulse reading then it will tell the unit to pump fuel when it is not needed and this will cause very excessive smoke for the first few mins when the burner kicks in...
If you have the excessive smoke continuously(even after 10 mins of continous use then it is probable that your fuel pump/system is running to rich, these units need regular servicing and adjustments as fuel nozzles/components wear,
There is alot of precise adjustments and checks on these units and i would reccommend getting it checked by a qualified tech, as when there is heated fuel and spark these units can be dangerous!
Hope this helps
Regards
Brad
Feb 03, 2010 | Northstar Electric Wet Steam & Hot Water...
Heat doesn't work on ac unit
u have to be more specific. is it gas or electric. If electric check breaker first. Gas check thermocouple
Apr 01, 2009 | Fedders Y Chassis AEY12F7E Air Conditioner
Fedders A6X05F2D Air Conditioner Logo
106 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
