Question about Rangemaster 110 (Gas) Kitchen Range
Rangemaster Disconnect the gas to move house
Does anyone know how to disconnect the gas supply on a rangemaster as I am moving house?
  • 315 Answers
I dont know if your in the UK but if you do disconnect your gas feed the way MrMark has mentioned you will be breaking the law.. you'll need to be corgi registered to do it that way.
BUT.....
Again if you are in the UK, some gas supplies were fitted with a quick release system.
With this all you need to do is slide your cooker out, locate the connection at the wall, not the back of the stove.
Press down on the top of the connector and turn the pipe coming out about 1/4 of a turn and it will release and self seal the gas outlet.
Posted on Jan 28, 2009
    President:
  • 1,214 Answers
Slowly slide unit out from wall.Get behind unit, turn the gas off. Using a set of pipe wrenches or crescent wrenches, grab the flange nut of the gas line with on wrench, and the gas valve fitting with the other. Loosen and disconnect.
I have just moved into a house with Leisure rangemaster 110 dual fuel, how do i change the time on the clock have pressed all knobs in various sequences, found the automatic, the timer but cannot move it...
http://www.rangemaster.co.uk/Siteimages/Site_311/Pdf/ProfessionalPlus110DFOct08.pdf
User manual.
When the clock is first connected, the display flashes ( 0.00) and (?) alternately. To set the time, turn and hold the Timer knob to the clock symbol (?) and at the same time turn the Adjusting knob left or right until the clock shows the time of day. Remember this is a 24-hour clock. Let go of the Timer knob and it will spring back to the vertical, oven manual setting.
It is on page 6 of manual
Mar 28, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
I have a rangemaster 110 LPG Hob and double oven cooker. I will be moving to a mains gas area and would like to convert it to natural gas. Is this possible?
Hi, a complete shot in the dark as its a while since you posted - we have a mains gas rangemaster 110 and need an LPG one, do you still need to change or have you sorted it now? Cheers
Dec 04, 2009 | Rangemaster 110 (Gas) Kitchen Range
Don't know what electricity supply is required
Emmet in luton: what fuse does a rangemaster 90 duel fuel need?
Apr 10, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
Grill Element Blown Rangemaster Classic 110
I have the same problem. The installation and service guide details how to change the grill element but does anyone know what the part number is for the grill element?
Apr 01, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster gas grill - little or no gas pressure
you can phone rangemaster helpline on 08707 895 107 spare parts or tech team.
Feb 26, 2009 | Rangemaster 110 (Gas) Kitchen Range
How to fit a flame failure device to rangemaster 55
the part that you need is the oven ignitor, located nest to the oven burner. that part gets hot to open the gas to the burner, that will make the oven work again.
Dec 08, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
RANGEMASTER CLASS110LPRG/B
you need the btus of both to size gas pipework
Apr 16, 2008 | Rangemaster 110 (Gas) Kitchen Range
Elan 1100
I had a similar problem with my Rangemaster Toledo 110. The glass cover would move slightly but would stop as if being held by something. I went to the Rangemaster website and the checked the users manual which suggested it was a simple operation of turning anticlockwise. Eventually I got a pair of vice grips and opened them to their widest and clamped them round the glass. The slightest of pressure and the glass moved past the stop point and off!! I've replaced the bulb and put the glass back on only hand tight and in anticipation I've loosened the glass cover in the other oven - just in case!
Dec 16, 2007 | Rangemaster Elan 90 (Dual Fuel) Dual Fuel...
Rangemaster 110 (Gas) Kitchen Range Logo
327 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
