Question about Kenmore 64952 Electric Dryer
Dryer runs and runs...
I'll turn the timer on and start the dryer but it will run for hours and the timer won't move.
  • Anonymous Mar 13, 2014
    the dryer runs but the timer wont move to turn it off
  • 5,911 Answers
If your timer does not move, more than likely the timer motor is bad. The motor is not serviceable and the entire assembly must be replaced. They cost about $120 or higher depending on model. There is a wiring diagram inside the console to assist you in troubleshooting as well. If you decide the attempt any repairs, or decide to remove the console, unplug the unit first. There is 240VAC at the terminal block near the console and associated wiring. I hope this helps.
Posted on Jul 25, 2007
  • Jeff Rockwell
    Jeff Rockwell Aug 11, 2007
    Could you please provide feedback as to why you rated this as "Not Helpful"? I work on appliances for a living and the advice I gave you is a "best guess" solution based on the symptoms you gave. It's often hard to determine a cause without being there to see for myself. What have you done to troubleshoot the problem? Have you corrected the problem? Any comments would be helpful in being able to provide you with a better solution.
SOURCE:
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
The dryer knob won't move while the dryer is on, so it will run for hours and never turn off. What needs to be replaced?
http://forum.appliancepartspros.com/dryer-repair/53816-maytag-dryer-runs-continuously-timer-auto.html
Apr 30, 2011 | GE EED4600GWW Dryer
Kenmore dryer quit running. I don't hear the timer moving and motor is not moving the tub. I've checked the circuit breakers and they are not tripped. I've even reset them. I'm about to check the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 04, 2010 | Kenmore Dryers
New Dryer and there is no heat and the timer is not moving !
you need to first check your power do you have 240 nstraight across your receptical? i would flip breaker on and off. see what happens...what was wrong with your other dryer?
May 04, 2010 | Roper REX4634KQ Electric Dryer
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
I have a maytag dryer and when you start it the timer doesn't move - it will run for hours unless you stop it. now when you pull the knob to start it doesn't respond
Sounds like the problem is in your timer contacts, in which case you would have to replace your timer. A no heat scenario on auto dry could also cause a dryer to run continuously.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Apr 14, 2007 | Kenmore 64902 Electric Dryer
Kenmore 64952 Electric Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
