Question about Frigidaire Ovens
Oven door will not open
A friend's oven door will not open
  • Jim London
    Jim London May 11, 2010
    Hi, You don't give any info on the make or model or any details as to if it just happened or what so my best guess is the self cleaning latch is engaged. there is a locking handle on most models between the cooktop and the oven door and the unlock position would be to the left as you are looking at it. Some models will lock this latch if any of the dials are set to clean mode or anything above 500 degrees. Hope this helps.
  • 979 Answers
If you have just finished using the self clean part, the latch may be stuck. Push the door closed and hold it and then tap moderately on the door where the latch is and it may release. Unplug the oven and then then replug after 10-15 seconds.
Posted on Jan 28, 2009
Electrolux oven racks how do they go in oven?
Hi Friend, that's a great question!
I see that your post is listed under Electrolux Wall-Oven. May I have your model number please? You can normally find the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door. With this material I can provide you the correct instructions on how to place the racks in your Electrolux wall-oven. Thank you! - Z
Jul 20, 2014 | Electrolux 30" Built-In Double Electric...
Door came off the hinge
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Whirlpool RBS305PDS Electric Single Oven
Locked oven door to clean. Need instructions to
These might help you get the door off
Mar 04, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
My oven door won't open and its not locked or on clean. what do i do
Mar 03, 2010 | Ovens
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
I lifted it by its door and its came off, not broke though
ok wht you have to do is grab the hinge with pliers or your hand and fold the hinge to the open position,carefull this hinge has some pressure to it and you dont want to pinch your skin ,once the hinge is open,you want to take a screw or strong nail and stick it thru the hole that is between the top of the hinge and bottom in the center put the nail thru the hole and let the hinge close slow i,it will hold the hinge 3/4 open,now hook the door on it will be 3/4 open once you feel it latch on the door open the door all the way pull the nails out and close the door ,it takes a little practice but youll get it remember to use the nail to hold the hinge open,youll see the hole on the hinge
Jul 09, 2008 | Gaggenau EB388 Electric Single Oven
Door locked
resetting thebreaker sometimes will work. if not try setting to clean. after engages the door to clean simply cancel the cycle the door lock/latch will cycleback . perhaps it just glitched shut.
Mar 12, 2008 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
145 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
