I have a problem with my WBR1310 router. I am not able to access the internet thru the wireless router. the connection is not consistent like connecting and disconnecting.
Bluetooth (BT) is not compatible with WiFi. There is no way to do that, and it must be done with or thru a PC, or laptop. The USB ports on wireless routers are for network storage, and/or network access to printers. Hope this helps
Connect modem lan cable to Router Wan / Internet port.
From Router Lan port you can either connect your system or switch .
wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
You need to configure your router. For that Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.0.1 or http://192.168.1.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click on WAN settings and set those settings as your internet service provider settings. Enable DHCP if you want to get ip from router. Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router. Then you can connect your wi fi network with that code. Let me know if you need further assistance. Thanks for using FixYa.
Is it happening with all the wireless computers ? If it is then it must be the problem with the router. You can try to upgrade the firmware of the router and reconfigure the router. Click Here for more info
With power on, push & HOLD reset button on rear of router for at least 10 secs - then release. UNplug power to the cable modem while you're doing all this. Then, plug power to modem back in, and try router connect to computer again. Please let me know - and if you wouldn't mind, please take the time to rate my response to you.
Verified that the Internet connection is working good
- Now if your connected to the wireless network but unable to access a website try this:
- Open the control panel - Open the network connection - Right click on wireless networks (Choose properties) - Choose Internet protocol then click properties - Assign DNS Server address (Preferred DNS: 4.2.2.2, Alternate DNS: 4.2.2.3) - Leave the DCHP as obtain IP address
if you have internet connection access the d-link website to get info of the router's manual.
or may may also call d-link tech support from your router manufacturer or vendor.
