Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
Snow blower is running sluggish with the choke in the on position
After the blower is started, I move the choke to the off position, but it cuts off and the only way it remains running is to move the choke back to the on position. Its not running to its full capacity and power. I have a toro, model # 38170.
  • allezrider02 Jan 28, 2009
    Mine is a Model S620 with the same issue, and if you attempt to use it while running this way, it dies. Seems to run good with the choke in the on position. I'm thinking that maybe because of the choke position that it may be an air issue???
  • 49 Answers
It sounds like you my need to rebuild and clean the carburator. Or you have an air leak between the carb and the cylinder.
Posted on Jan 29, 2009
I have an older craftsman snow blower 10 hp. It starts ok with full choke, runs ok half choke, backfires with no choke-run position.
It's too lean; not enough fuel mixed with the air. Look for the main mixture screw--it should be a large screw with a spring under it on the carburetor. Run the engine until it's warm.
With the engine running, turn the screw outward (lefty-loosey) about 1/8 turn slowly and see if it improves. Slowly turn the screw back and forth until it runs best with the choke completely off. Then set it 1/8 turn richer (turn screw outward 1/8 turn) than the best position.
Reason for doing this: Conditions change, even the barometric pressure. Small engines run okay if they are a little rich but not if they are a little lean.
Mar 03, 2015 | Garden
Start snow blower runs for 3 min. and starts to over heat checked oil its ok then stats to shut down like its not geting oil
Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
Mar 01, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Need starting instructions for Ariens snow blower Model # H5065226H
do you have a fuel shut off valve? if so make sure its in the open position. choke closed,prime 3 times and pull cord. if not started after three pulls open choke and look in carb for fuel delivery. if none service your carb also check to make sure you have spark before assuming its the carb
Nov 22, 2014 | Garden
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
Snow thrower starts then shuts down after a few minutes
Hmmm... THAT sounds like you have an obstruction (ice???) in the fuel line or in the bottom of the tank.
Feb 15, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Toro power clear will not stay running brand new
is the choke closed when you start this thing make sure you close the choke to start then shut it off , the plug gets fouled if you do not do it this way make shore you have the right gas mix in it , takes 50 to 1 I believe 2+2
Feb 08, 2014 | Toro Snow Blowers. Power Clear 621 QZR 21...
Sears snow blower runs rough like the choke is on
put in injector cleaner in gas
Dec 14, 2013 | Garden
Trouble shooting New Toro Power Clear 418 zr - slight misses and pops while running
when you start it do u use the choke right , when starting close choke when it starts open choke you prob fouled the plug clean it put back it walah
Nov 22, 2013 | Toro Power Clear 418 ZR - Single Stage...
Snow blower won't stay running
ok heres what you do to get your snow blower to keep running.
while you have it choked, and you get it to the running point, turn the cup bowl ajustment in/out a fraction at a time while you move the chock off slowly till you get the right setting to keep it running then ajust the setting once more to clear it up to purrr like a kitten again the vibration moves the screw out to set everything out of wack......
Feb 09, 2010 | Craftsman 16" High Garden Tractor Snow and...
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
752 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
