Question about Panasonic NN-S443WF / NN-S443BF 1200 Watts Microwave Oven
Panasonic Microwave Model NN-S443WF No Power
Where is the main fuse located?
  • Anonymous Mar 09, 2009
    No power getting to Panasonic Microwave Model NN-S443WF.
    No Power. Tried plugging into another power source and still no power.
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Dimension 4 microwave model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
Posted on Aug 03, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Panasonic Genius Prestige Model
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can order Panasonic parts here.
You can find an authorized Panasonic servicer here.
Posted on Sep 28, 2008
  • 178 Answers
SOURCE: Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Posted on Sep 13, 2009
Testimonial: "Thank you for replying! You really seem to know what you are talking about!"
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
SOURCE: Panasonic microwave (model NN-P295) power failure
Panasonic CQ-C1313NE
Posted on Feb 17, 2010
Panaonic nn 1000 gs 597 no working microwave
follow this steps and fix it. God bless you
No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models
Jan 23, 2013 | Panasonic NN-H965 Microwave Oven
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
There is no power coming into my microwave which is a panasonic nn-L531WF model. I think it's the fuse. How can i change the fuse?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 18, 2011 | Panasonic NN-L531WF Microwave Oven
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
Oven will not turn on. No Power at all. Does this model have a fuse and if so where is it located?
Yes there is a main power fuse. It is situated where the power cable terminates, within the unit.
It is a special type of fuse and MUST be replaced with exactly the same type and size.
Oct 18, 2010 | Panasonic NN-H504WF Microwave Oven
Panasonic Microwave NN-T993SF has no power. Was working and suddenly the power went out like it was unplugged. It is not our fuses or cord but something in the microwave itself. Is there a fuse or...
most microwaves do have an internal ceramic fuse either 15 amp or 20 amp the cover has to come off to locate it usually at the top just behind the control board. do not touch the high voltage capacitor as it holds a charge even when the unit is unplugged.
Nov 07, 2009 | Panasonic NN-T993SF Microwave Oven
My new microwave is completely dead
good day,
hope this link below will solve your problem.
kitchen appliances
May 24, 2009 | Panasonic NN-H504WF Microwave Oven
NN-A574SBBPQ - Microwave fans & turntable not working
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Feb 10, 2009 | Panasonic NN-S961 Microwave Oven
Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
Nov 19, 2008 | Panasonic NN-S443WF / NN-S443BF 1200 Watts...
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
Panasonic NN-S443WF / NN-S443BF 1200 Watts Microwave Oven Logo
82 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
