Question about Maytag PYE2300AY Electric Dryer
PYE2300AY Dryer shuts off after just running for a few seconds
I unhooked the belt to see if it was the load on the motor and it does the same thing. Seems like it is some sensor or something that is shutting it off. My Wife said yesterday that it was smelling like burning rubber before it started this.
  • fonecop1 Jan 28, 2009
    I wondered about the motor but it doesn't get hot in the amount of time it takes to shut down. I think it may be the thermal cutoff, would that cause the motor to stop or just cause the heating element to stop?
    well I think you are right that it is the motor. I took the drum out so I could get to it and it is pretty tight. It isn't heating up but I guess it is just drawing too much current because it is so tight. It should spin free right?
  • 135 Answers
See how hot your motor gets - it is very likely overheating ans will need to be replaced. Hope this helps!
Posted on Jan 28, 2009
  • Jim Balcum
    Jim Balcum Jan 28, 2009
    Motor should spin free. They do usually get hot, but not always. Hope I have helped!
My dryer runs a few seconds and then shuts off I can wait a few seconds then it will run again shut off after a few seconds
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
Feb 20, 2015 | Dryers
The dryer runs for a few minutes then shuts off and restarts in a few more minutes8xcccxb2
Sounds like your motor is getting hot, shutting down to cool off and coming back on. This is a motor that will have to be replaced. On some models the only other thing is could be would be the thermal link that is usually located on the back of the dryer. This would definitely be the cheaper part to replace. If possible, jumper around this thermal link, if it still does the same thing you will more than likely have to replace the motor. Good luck I hope this helps.
Apr 19, 2011 | Maytag PYE2300AY Electric Dryer
My maytag pye2300ay dryer....is not starting..... i push the start button and no sound... no turn... resently the belt was change.....what should i do?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 30, 2010 | Maytag PYE2300AY Electric Dryer
Dryer will not start -- dried one load and would not start the second time and still will not start
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 23, 2009 | Maytag PYE2300AY Electric Dryer
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
Aug 13, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Model PYE 2300 AYW Dryer will not Start
How about the controller that turns everything on? Check for power to it? Relays(if any) working?
Aug 28, 2017 | Maytag PYE2300AY Electric Dryer
Dryer will not turn
There is a belt like a fan belt that goes around the outer tub and onto a pulley that turns the tub, it may have slipped off, you should be able to take the top off of the dryer to check it.
Mar 19, 2009 | Maytag PYE2300AY Electric Dryer
Maytag SDE4606AYW electric dryer won't start. After drying several loads successfully, I set the timer knob, there was a humming noise and the dryer won't start. The humming noise happens at any timer...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
dghj53
Mar 01, 2009 | Maytag PYE2300AY Electric Dryer
Only turns with light load
If this is not turning with a heavy load it can be one of or a few different things. The motor may be going bad and cant handle the heavy load or the drum belt may be slipping or the dryer drum wheels where the dryer rides on may be worn out.
If its the wheels the machine will be making a sort of a grinding sound when it runs and the dryer drum will be loose and wobbly inside the machine. The drum wheels and belt are cheapest, probably less than 10 bucks for both.
You will need to remove the front of the machine and remove the drum to get to the wheels and belt. It shouldnt take more than 1/2 hour or so to do this job.
The motor is another thing. 150.00 for the part, hours of labor and electrical connections. Clearly not worth it unless you have access to a cheap parts supplier. Check ebay for appliance parts suppliers. They usually buy up manufacturers surplus parts and sell them for 1/2 of what they originally sold for.
Oct 11, 2008 | Amana ALG331RAW Gas Dryer
Maytag PYE2300AY Electric Dryer Logo
145 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
