Sony kdf-e42a10 red light blinks 4 times
I have this sony tv. 4 years old. i have been having a very dim picture. i started shopping for a new tv and one of the sales man suggested it needed to be cleaned. he also suggested that i unplug the tv for ten mins. then take canned air and blow the fan out then take the bulb out and blow it off then plug it back in and i should notice a slightly better picture. well i did that and i think he just wanted to sell me a new tv. cuz now i have a tv that take a good 15-20 secs to boot then bout for 3 secs with noise then shut down to the standy by light blinking 4 times. and if course it right before my super bowl party. im a mechanic. im very good with small things. is this something i could repair myself? and what about the cleaning processes? please respond i need help. hiclassmotorlube@aol.com
mfspencer
  • 58 Answers
SOURCE: please help
That is the blink code for the lamp ballast. Here is the more complicated explanation from the service manual.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp is blown
Hope this helps.
Posted on Apr 03, 2008
  • 2336 Answers
SOURCE: Sony KDF-50WE655 won't turn on.
if your TV blinks 10 times. Possible solution should be to check and replace on the G1 board Q1600 and Q1601 if shorted and R1614 and diode D1605 open.
Posted on Oct 20, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony- KDF-50E2000
Have you replaced its Lamp?
Symptoms shows TV needs new lamp.
Please always buy original Sony lamp for replacement.
Posted on Mar 15, 2009
Slinteriors
  • 8617 Answers
SOURCE: KDF-E42A10 std by lite keeps flashing, tv is
you can get the service info from http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10/cName/sony
Posted on May 31, 2010
SOURCE: Hi all,\r\n Ok, I have a Sony KDF-60XS955, about 5
http://www.nodevice.com/manual/sonymans/manual3400pdf/get4917.html
Above is your user manual, below is your service and repair manual. http://www.fixdevice.com/smanuals/tv/sony/kdf60xs955.html
This may very well be a lamp problem, or it may be the "Driver" for the lamp, or indeed the Power Supply to that lamp, unfortunately one must troubleshoot these issues to isolate the actual problem, Please use these manuals, and you should soon be able to isolate and effect a repair.
Posted on Jun 15, 2010
Testimonial: "Thanks for the quick help, and the pointer in the right direction. Helped me find what I needed to do the same night, and got my part ordered the next morning."
I have a kdf-e42a10 tv no sound or picture red light flashes continuous
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 09, 2013 | Sony KDF-E42A10 42 in. LCD Television
I have a sony wega kdf-42a10 its only years old. i already replaced the bulb about a year ago....now when i turn it on the picture comes up then is there for about 4 to 5 sec. then disapears... they...
The tv also have a board that called a Ballast board this board only job are to ignite the tv lamp only.Hear alot of clinking too while the stanby light are blinking.Yes,the Ballast board it is dead and not help to ignite the lamp and helping it stay on.
Aug 25, 2011 | Sony KDF-E42A10 42 in. LCD Television
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
Why power/stanby blinks light red
how many times does it flash? The back of the manual will usually tell you what the flashes mean. Try this: unplug tv from power. While unplugged, hold the power button in on the TV, not on the remote! Hold for 10 seconds. Replug the power and try to power it up. If you get no picture, you need a repair. Contact the manufacturer for an authorized servicer.
Jul 19, 2010 | Sony KDF-E42A10 42 in. LCD Television
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KDF E42A10 picture loses quality.
It sounds Lamp is weak and causing darker picture.
How old is this TV and did you replaced Lamp recently?
If lamp has not been replaced in past 2-3 years then its time for new lamp, XL-2400 available in Sony Accessories Store and lamp replacement procedure is written in user manual.
Thanks.
Nov 05, 2009 | Sony KDF-E42A10 42 in. LCD Television
THE POWER STAND BY LIGHT IS FLASHING RED 4 TIMES
Anything less than 5 blinks is major trouble. More likely vertical IC and circuit failure. Picture has been muted or turned off by TV. If Stand By light was blinking 5 times the Stand By might have came out self-diagnosis function or mode.
Contact Sony Service Tech for service adjustment to fix problem.
Oct 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from rivervalleyelectronics.net. They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Sep 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
Televison & Video Logo
196 people viewed this question
Top Televison & Video Experts
