Question about StarTech.com StarView SV211K 2-port KVM Switch
How to input new codes
Hi
i have forgotten how to input the codes from the menu button, it has been a while and further has anyone got the new codes.
I would appreciate hearing from someone asap
Cheers
Niamh
    President:
  • 159 Answers
Hi, press menu, 1570, ok on nagravision, and enter these codes, hope this is what you are after.
C & W 5C 01 09/01/09
00= 7D 9B 0E 8B 69 3F E7 34
01= EF 38 DF 11 3D 85 FE 2F
Telewest 5A 01] 23/12/08
00= E7 D3 69 2E 6F 38 EA 78
01= E8 C9 E5 6E B0 49 53 F5
NTL 54 01] 09/01/09
00= 2E E9 B1 3F F7 F8 53 B2
01= 97 9B 22 E0 5B 13 B1 C7
Posted on Jan 28, 2009
How to remove child locks
If you have lost or forgotten the code, the default factory password is 0000. This should still work even if you have set another password and forgotten. You should also deactivate the lock fully from the menu if you no longer wish to use it or activated it accidentally.
Disabling the child lock (and/or other locks):
(This can be done from the remote or the buttons on the front of the TV)
1. Press MENU to open the main menu.
2. Press CH+ or CH- to highlight PREFERENCES.
3. Press OK to enter the PREFERENCES menu.
4. Press CH+ or CH- to highlight FPA Lock (Front Panel lock) .
5. Press VOL+ or VOL- to switch the lock on or off
6. Press MENU repeatedly to exit the menu
The menu will disappear if no buttons are pressed on the remote for several seconds.
Please let me know if you need further assistance.
Regards,
BElectric.
Jan 31, 2011 | RCA TruFlat 27F520T 27" TV
How to enable the input of lcd
hi,
u can sellect input by following setup
1. Press INPUT. on remote
(A list of selectable sources appears).
2. Press INPUT again to select the input
source.
( An image from the selected source automatically
displays).
Each time INPUT is pressed, the input source
toggles.
If the image does not come in clearly from the external
equipment connected to INPUT 1 or 2, you may need
to change the input signal type setting on the "Input
Select" menu.
1. Press MENU to display the MENU screen,
and then press c/d button (on remote) to select "Option".
2.Press a/b button (on remote) to select "Input Select", and then
press ENTER.
3.Press a/b button (on remote) to select the signal type you
want to set, and then press ENTER.
4.Press MENU to exit.
just try these. need further help feel free to contact.
ok.
Dec 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have forgotten N78 phone lock code can you help me
Do a hard reset but keep in mind this will restore to its factory default settings
Turn off the mobile phone.Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.While holding these three buttons, press the power button to switch on the device.Release your fingers when the screen displays the Nokia Logo and the language selection menu further.
www.usedcellphoneshop.com
Jun 07, 2010 | Nokia N78 Smartphone
What is the reset code if you have forgotten the child lock code for aquos 22" 6 years old
Press menu for the menu to appear. Press the Up or down button to select features then press ok to display the features screen. Press the up or down buttons to select child lock then press ok the pin input appears. Input (3001) with channel select. The child lock menu appears and the pin is cleared. You can then enter a new pin. Hey if this works give me a vote please so I'll know if I helped.
Mar 04, 2010 | Sharp Aquos LC-22SV2E 22 in. EDTV-Ready...
Cant enter codes in Eurovox ex1000 sl
if you need to manually enter the keys a different procedure is required to previous versions of the firmware.
To access the key entry screen try the following:
On the remote press "Menu".
Highlight "Language Settings" and press "OK".
Highlight "1st audio lang" or "2nd audio lang" or "Subtitle lang" NOT "Menu language", then press the buttons 1,9,6,8 in order.
The key entry screen should now be visible.
Use the left/right arrow keys or "FAV" button to find the "NagraVision" screen which contains the keys for UK service providers.
to reveal the "Emulation" and "EMM Capture" Highlight "Menu language"
Aug 21, 2009 | StarTech.com StarView SV211K 2-port KVM...
I need 4 digit ''input''code a 1990 VS-4501R big screen mitsubishi.
If you have the original remote or at least one with a QV button on your remote it is easy.
When prompted for the code, Just hold down the "QV" and the number 9 together for a bit.
That will unlock the set.
I would then go the the main menu and unlock the set from the menu. Use the "QV" and 9 to get in and turn off the password.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Aug 07, 2009 | Televison & Video
Just brought a new Eurovox SL1000
press the menu button then the yellow button
Apr 20, 2009 | StarTech.com StarView SV211K 2-port KVM...
Virgin codes for starview box
To enter the codes: Press "menu" then enter "1570" and a secret menu appears. **MAKE SURE "EMU" IS SET TO "ON"** Selecet "Nagravision" and the codes will appear. At the top select your provider: N*L, EX C*W, CH*&US etc, then in the box below select key 00. Move down to the keys below. Enter the codes by a combination of the number keys on the remote and "Audio", "Pause", red, green, yellow & blue buttons for the letters A to F.
After you have entered keys for 00 press "OK" to save. Go back up and select Key 01. Move back down and enter the codes for 01 then press OK to save.
Press exit & exit again until you get back to the first MENU screen. Press "Installation", select your provider again, go down the menu and press Auto search. This should then find all programs. After the programs have been found press exit & it should say something like saving or updating data. Then you should be able to view your channels again.
Jun 06, 2008 | StarTech.com StarView SV431USB 4-port KVM...
Resetting V-Chip pin code
I don't know the sharp(mfg) code to activate my universal remote
May 12, 2008 | Sharp 27U-S60 27" TV
L6 motorola
when the phone ask for the unlock code you press and hold the menu key button till the screen changes asking for the security code , hoping that you have not changed it, just enter 0 six times...eg 000000
Jan 07, 2008 | Motorola Mobility L6 Cellular Phone
StarTech.com StarView SV211K 2-port KVM Switch Logo
83 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
