I want hp 3050 laser scanner drivers - Office Equipment & Supplies
    Sergeant:
  • 285 Answers
  • 716 Answers
Clck Here Once You Click The Link Select Your Operating System And Then It Will Give You The Download For Your Drivers.
Please Rate Our Experts
Thanks For Using Fixya.com
Sincerely,
Michael Scott
Posted on Jan 28, 2009
  • 42 Answers
SOURCE: HP LASERJET 3050 SCANNER: ERROR (not set up on pc).
Hey,
did you windows install drivers when you connected this printer?
is the interface usb version or LAN network?
Windows version ?
best regards michael
DIY site 'Why pay when you can play'
Posted on Dec 14, 2007
ctf1800
  • 4402 Answers
SOURCE: Receiving fax on HP laser Jet 3050
go here
Posted on Mar 12, 2008
SOURCE: low memory display on HP Laser Jet 3050
I had the same problem, tried clearing memory, etc. but no luck. Turns out the pages I was sending were printed on a darker colored (purple) paper which made the size of each page very large.
I tried again with the pages printed on light colored paper and had no problem.
Posted on Jul 14, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: 52 scanner error problem
Perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
If this step does not resolve the issue, please repair/replace the printer.
Nikhil Gedam
Posted on Dec 22, 2008
  • 102 Answers
SOURCE: SCANNING ISSUE
You need to install the complete software from HP Website or use the link belows:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1140783&prodNameId=1140778&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
After downloading and installing the complete software you need to set-up scanner.
Using steps and i m sure your issue will be resolved.
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Posted on Jul 02, 2009
I want to find out how to use my HP 3050 All In One Scanner again; drivers are no longer available
the driver is available in hp.com anway you have to select your opration system for the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1140778&taskId=135&lang=en&cc=us&prodSeriesId=1140783&prodTypeId=18972
Mar 24, 2013 | HP LaserJet 3050 All-In-One Printer
Hp laserjet 3050 scanner does not work with Vista 64 bit
This is usually means that windows does not see the scanner, or the
scanner uses an OEM driver instead of built in windows support. There may
also be a problem that is caused by the scanner driver
not being installed.
A possibility is to use the trial version of Viewscan from Hamrick software
to see if the scanner works with it.
Thank you
Mar 27, 2010 | HP LaserJet 3050 All-In-One Printer
Hp 3050 laser jet printer the fax page is black
The scanner in your FAX is nothing working -- i.e., "100%-black" or "100%-white", and so what is transmitted is what the scanner has scanned, improperly.
Dec 13, 2009 | HP LaserJet 3050 All-In-One Printer
52scans error in hp 3050
Turn off power and wait 30 seconds. Power on and try again. Still fails...is it plugged into a surge protector? Plug it directly into the wall. If the error persists you are going to have to replace the "laser/scanner" assembly
Oct 19, 2009 | HP LaserJet 3050 All-In-One Printer
Hp laserjet3050 scanner error:not set up on pc"
hp has a website that you can download your drivers for your printer/scanner for free
Feb 27, 2009 | HP LaserJet 3050 All-In-One Printer
52 scanner error turn off and on is displayed in the contoll panel,the same thing is again displayed if i turned off and on also nothing can be printed due to this displey. please help
The printer has burned a scanner assembly. The part number is RM1-2033-030CN. The part is extremely expensive in relation to the printer cost. ($182.00 @ HP)
I would recommend surfing ebay for an HP Laserjet 1022 printer as it is the cheapest printer that has the same scanner. Even a dead 1022 will work as they tend to either have formatter or fuser issues when dead. A scanner error on your printer or the 1022 is extremely rare.
I have included a link to the HP 3050 service manual for you that will walk you through it step by step. The teardown is significant however very do-able by the novice with the service manual.
http://h20181.www2.hp.com/plmcontent/NACSC/Printers/LaserJet/30328_020806/course/library/service/service.html
Good luck, You can do it.
Jul 09, 2008 | HP LaserJet 3050 All-In-One Printer
Hp laserjet 3050 scan problem
You should go to HP.com and look for a TWAIN scanner driver the works for that printer in Vista.
Jun 14, 2008 | HP LaserJet 3050 All-In-One Printer
CANT FIND A WAY TO SET UP THE SCANNER
Hello there!
Click on this NOTE as a guide..
Click HERE for your driver guide
Enjoy!
Mar 25, 2008 | Office Equipment & Supplies
Scanning with Laserjet 3050 on IMAC with leopard
Correct me if I am wrong but doesn't this printer come with mac drivers? But I am not supprised to head that HP is alienating you. They do the same for Linux users. Although there is a growing base of support coming from HP. Maybe you should switch to Linux.
Jan 10, 2008 | HP LaserJet 3050 All-In-One Printer
128 people viewed this question
k24674
jasbo
jasbo
