Question about LG Flatron 775FT 17" CRT Monitor
LG Flatron 775FT monitor distortion
FOr some days now my LG Flatron 775FT monitor was displaying the bottom area of the screen magnified, now the middle area of the screen in magnified and the top and bottom areas are really condensed. You help greatly appreciated. Thanks.
  • vivek singh Feb 21, 2008
    i am using zenith monitor and from some days the bottom area of my monitor becomes magnified.there is some type of distortion.Please email me if any slution found
  • Anonymous Mar 22, 2014
    Can't remove neck of base from monitor
Doesn't look very good :( You can try returning to the "factory settings" in your monitor's menu. Maybe try the monitor in another computer to check whether your graphics card is faulty. But all in all it looks like a fault from the monitor :( Good Luck!
Posted on Jul 27, 2007
Hi, I have an LG Flatron w2343T and on a recent restart the screen resolution came up all distorted in that all the icons are bigger and my wallpaper photo is enlarged to the point that I can only see...
For some reason your screen resolution changed, to adjust it
Right click on a clear area on your screen, select Properties,
select the Settings Tab, Screen Resolution, adjust to the desired
resolution
Jul 13, 2011 | LG Flatron L2320A 23" LCD Monitor
I cannot center my desktop on my monitor it is to far to the right of the screen
there is a picture tube inside the monitor which is not pointed well at the center so you have to take it to the service center..
Oct 22, 2010 | LG Flatron 775FT 17" CRT Monitor
I need the elctronic layout of monitor lg flatron 775ft
TYPE THE FOLLOWING INFORMATION
WWW.MFG NAME.COM/SERVICE
WWW.SCHEMITICS LG FLATRON 775FT [WHITE] 17" CRT MONITOR
ENTER
LG FLATRON 775FT 17" CRT MONITOR SCHEMITICS
OR
LAYOUT
ENTER
May 12, 2009 | LG Flatron 775FT 17" CRT Monitor
Lg flatron 775ft screen size problem
Hi Edit123,
U can chane output width and height from buttons given on LCD panel manually
Sep 19, 2008 | LG Flatron L1750S 17" LCD Monitor
No signal
can you please help me?
I want the software driver for LG775FT for windows98. can you please send me through e-mail?
my e-mail is ::
jigneshnpd@rediffmail.com
thanks
Aug 20, 2008 | LG Flatron 775FT 17" CRT Monitor
Drivers
go to http://www.Lg.com support drivers you need to check for you model make serial and windows tipe if you can not get it from there you can go to http://www.driversguide.com fill out the registration and go to the LG monitor and look for your model serial and windows system
Dec 14, 2007 | LG Flatron 775FT 17" CRT Monitor
Lg flatron l1510s
Try hooking the monitor up to another computer to see if the symptom remains the same if it does you might be needing a new monitor
Nov 01, 2007 | LG Flatron 775FT 17" CRT Monitor
Screen not smooth in the sides and corners
hi there, i've done a bit of research about your monitor apparently this model is not very reliable and has all sorts of common problems including yours here's what some people said about it: Bad Points Extremely unreliable. Over a 2 year period I have had to replace 6 out of 20 monitors Main problem, the image degrades to the point where any text in the centre of the screen is difficult to read. this monitor has a blurry corner right bottom corner and a bit of a whole right section.. and its out of focus constrast is like not on full and correct and identical to the left side.. left side is crisp and perfect.. also it takes bit of time to correct the display in the screen position and pincusion, the convergence isnt impressive at all.. anyways this is what you get from cheap monitors and BTW this is made in Indonesia, i am not flaming on the country, i am just saying this monitor isnt tested or not in quality as samsung flat monitors or sony. i am disappointed on LG for the first time, well if you really consider buying this monitor, you must check the monitor screen or something if it is correct. so you dont have to cry after you came all the way back home with it.. looks like a lot of people are not happy with this monitor. just replace it they are not expensive nowadays regards
Aug 19, 2007 | LG Flatron 775FT 17" CRT Monitor
Display flips 90 degrees
Use ctrl+alt+ up Arrow key (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Jan 26, 2007 | LG Flatron 775FT 17" CRT Monitor
LG Flatron 775FT 17" CRT Monitor Logo
303 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
