Question about GE 29869GE2 Digital Answering Machine
Wanted to know if i can check messages by calling in
If you can check your messages from another phone or location
  • 15,935 Answers
CLICK HERE for the user manual.
The following is on Page 19....
REMOTE ACCESS
You can access your answerer from any touch-tone phone
by entering your 4-digit security code (the default security
code is 0123). The remote functions do not work with rotary
or push-button pulse-dialing phones. You can cut out the
wallet-size remote card near the back of the User’s Guide
so you know the touch-tone commands when you're
picking up messages from another location.
To access your answerer:
1. Call your telephone number.
2. After you hear the beep that follows the greeting,
enter your 4-digit security code. To bypass the
greeting, you can enter your 4-digit security code at
any time while the greeting is playing.
3. The unit plays the remote menu after the correct
security code has been entered. Menu selections can
be made at any time while the menu is playing.
NOTE: The unit answers on the 10th ring when it is
turned off or the memory is full. To access the
answerer, enter the 4-digit security code after the
beep. If memory is full, play messages and erase
some of them to restore memory. If the answerer is
off, press 2 to turn it on.
NOTE: After the unit plays the remote menu, it will
wait several seconds for a command, then disconnect
Thank you for using Fixya - a FixYa rating is appreciated!!
Posted on Jan 28, 2009
Message sending problem in nokia 5630
Check the Message Centre Number for your phone operators number are correct, located in Message settings
If you really dont know about for the exact number call to your operator for the exact number
Sep 16, 2010 | Nokia 5630 XpressMusic Smartphone
Tip
Ericsson CODES DESCRIPTIONS
*#06# For checking the International Mobile Equipment Identity (IMEI Number)
Shortcuts:
Save a Missed Call into your phone directory Scroll to "Missed Call", press "Yes" to display the required number. Press any number (i.e. 0 to 9), then press "clear" once to clear that number, then press & hold "<" until you see "Store". Press "Yes"
Hide your number when calling when you don't want the other party to know your number) After dialling the required number & before pressing "Yes", press ">" twice to choose "Hide Id?" & then press "Yes". Also works for pre-programmed & last dialled numbers just press "No" & wait for the number to appear on the screen first then follow same procedure
Check you battery level when phone is off Press "No" quickly one time & wait for the battery meter to show up!
Save a number into your phone memory (not SIM card) Follow normal procedures to store a phone number. When prompted to set a storage position, press "#" once & key in desired location, or press "#" twice for next available position
Call a phone number from SMS message You can call from within a SMS message if the phone number is written in it. Just scroll the message until the phone number appears on the display, then press "Yes" to call
on Aug 30, 2009 | Nokia 9500 Communicator
Lost my manual and I want to know how can I check my messages from another location it is a GE model # 29586ge1-a
When you call your number, as soon as the message starts to play, press the # or * key on the phone your on, then it will ask you to enter the security number that you set. Then you can listen, save, delete your messages.
Mar 10, 2010 | Lands Phones
NEED OWNER'S MANUAL FOR UNIDEN CORDLESS W/ A M MODEL #EXA7248
When answering machine picks up, message says "No one is available to take your call. Please call back." I cannot find "menu" on phone set for caller to leave message.
Mar 30, 2009 | Uniden Cordless Phone EXAI985
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
Talking on phone,someone calls in & leaves message, can't locate
Thanks for the opportunity to help with your problem. If you also have voice mail through your phone service provider, it's possible that while you are on the phone, the incoming call is "waiting" (meaning you are hearing a beep while you are still talking assuming you have call waiting). If you don't pick up the incoming call, your caller will hear your "voice mail" message and leave a message. However, your answering machine will not indicate that you have a message.
If my assistance was of any benefit whatsoever, please give me a rating so I can continue to improve my service. Thanks for using FixYa.com.
Jan 22, 2009 | Panasonic KX-TG5632 Phone
Does anyone know how can I block calls or messages from specific numbers?
I would just like to know how I can block a particular number through my 6060. Please don't tell me divert the calls; that's not the solution. T
here are just a few numbers from a couple of people that I don't ever want to receive any messages or calls from. My other friend's seem to able to block numbers on their more recent Nokia phones. Don't tell me the 6060 is too old fashioned to be able to do that?
Oct 17, 2008 | Nokia 6060 Cellular Phone
I was talking on the phone and when I was finished the call I heard a sound; message said insert SmartChip. I don't know what to do - can't make a call or do anything - then I get "emergency...
It's possible the SIM card within your phone has become loose. You may want to check your owners manual to locate where it is on your phone. After locating it, you should remove it and put it back in to the device.Make sure the phone is off when you do this, and then restart it when you're done.
Aug 11, 2008 | Sony Ericsson Cell Phones
Don't have manual and phone shows "SENT" and ext #?
i want to setting toshiba dkt-2020 code number
May 14, 2008 | Toshiba DKT-2020 Corded Phone
GE 29869GE2 Digital Answering Machine Logo
433 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
