Question about Samsung WF337AA Front Load Washer
Samsung washer recently moved house and washer was working, tried washer at my new house and the washer turns off after a couple of mins thru the cycle, the water fills up and error message 4e shows up and stops the cylce. plz help
  • hvptech Jan 29, 2009
    hi, i have fixed the problem. its was something to do with where the water (in) pipe connects at the back of the washer, i opened the top of the washer and disconnected the water inlet connection and just rinsed it under neath the tap, and blew in it, couldnt see any debree looked good but still worked a miracle, tool required just a scewdriver, i u need any further info plz mail me on hvptech@hotmail.com
    cheers
    hvptech
  • 15,935 Answers
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Beko WMB71442w i have recently moved house and my
you need to take your drain hose off at the exit end it sounds like this end under has a bung in it so remove it ???
Nov 03, 2013 | Frigidaire ATF6000ES Front Load Washer
WF448AAP Drain hose short, door swings to left, washer on right?
plumbing in the wall is usually placed according to where your unit is going to be placed,..not the case here as i/you can see,..you should be able to get a piece of hose (from private appliance store) and an "insert coupling" (has little "barbs" on it so it stays put after you clamp it) and make your extension,...don't make it to long or to tight, you don't want tension on the hose,....baby sit this "custom repair" to insure it dosn't leak, ya know, watch a couple loads go thru it's cycle,......if you can't get this happening, you can have the drain in the wall moved,....not a big job if your drain is plastic. good luck.
Jan 03, 2010 | Samsung WF448AAW 4.5 cu. ft. Front Load...
Moved my washer and re-hooked it up and now it only runs for a few minutes and then flashes H F what can I do to fix this???
our washer did the same thing. it turned out it did not have enough water pressure to run the wash because our older than dirt water heater was full of calcium deposits and was blocking the water coming thru nearly every entry to the house. we got a new water heater and the problem solved itself immediately.
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front door won't open on 2003 Kenmore Washer and no release
When I had the same issue I tried the following things. It has been so long I do not recall the exact order I did them in or what finally worked but it did open.
Unplugged it for 5 mins.
Turned off everything else in house.
Plugged it back in.
Pushed Drain/spin - start (I could hear it try to click locked)
Then I pushed to stop it (then I hear the door lock click)
I tried all the different wash options and finally one of them allowed me to cancel the wash and the door unlocked. I know I unplugged it at least twice because of the computer needing to be reset. When a tech was working on it a couple of years ago I had him explain a few things and I don't recall the exact # of min's you are supposed to wait so I use 5 min's.
The water was still in my washer and I had to open the bottom and drain it by opening the cleanout to the pump. Large mess on the floor. Make sure you unplug the machine first. It will get on the wiring.
I also learned recently that your house electrical needs to be correct. These machines are extremely picky about their power.
Sep 17, 2009 | Kenmore Elite 45986 Front Load Washer
One side won't lock after collapsing and moving to new location.
I went thru that too. Try unlocking all other sides and lock the problem side first....I had to literally grab it with both hands and pull up hard to get it to lock. It happens from time to time and sometimes I have to pull up on it a couple times to get it to lock.
Aug 05, 2009 | Graco 9445DOH Crib
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Moved Washer and Now no Electrical
Suggestion: You dont need any special outlet. With a tester (you can get this in any electric shop) see if there is power in the outlet. You said it was hot?? It is not supposed to be hot. Try another outlet; & you could unscrew your machine plug to see if all the three wires are okay, ie. well connected, screwed in.
Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
TV won't turn on
sounds like the main board has an issue
Jan 18, 2007 | Samsung LTM1775W 17 in. LCD Television
Samsung WF337AA Front Load Washer Logo
232 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
