Question about Proview Computers & Internet
ProView PL716s U101 roasted
I have a ProView PL716s that shuts off the video after about 10 seconds. I read some of the posted solutions, took it apart looking for swollen/exploded caps, but all caps look OK. On the main power board, U101 is roasted and U105 looks like its been hot. These are surface-mount 8 pin mini-DIP ICs, located on the opposite side of the board from transformer T102. Does anyone know anyone who sells replacement boards for this monitor (Board has label E5260357G on it), and if so, at what cost? Or is this baby belly-up?
  • Gary Jan 30, 2009
    Thanks for replying, Bat. But the IC is actually burned (crispy) - one of the legs has lifted away from the board, and the middle part of the DIP is charcoal. I'm surprised that the monitor displays any kind of image, even for 10 seconds...
  • 585 Answers
I would change the caps anyway, they're cheap. The IC's may be running hot trying to make up for the bad caps.
Posted on Jan 29, 2009
  • Bruce Volkers
    Bruce Volkers Jan 30, 2009
    Those little I.C.'s are probably the inverter drivers for the CCFL transformers. The crispy one may then be the source of overload causing the shutdown. The one remaining is making backlight for the brief period of time you have a display. I don't know where exactly to buy the board. Your best bet may be to offer the unit on eBay, indicating it has a problem, and sell it as parts or repair. there's always someone looking to buy such for parts or for the screen. It may surprise you what you will get for it. Or you may find one on eBay with one of those broken screens and good for parts, like the board you need.
How to defrost a roast lamb in a vario stream oven
Have a read of this. I am a chef and would advise the traditional way.
Cooking a Frozen Roast Without Thawing - Cooking - eGullet Forums
https://forums.egullet.org/topic/112634-cooking-a-frozen-roast-without-thawing/
Feb 5, 2008 - 25 posts - ‎15 authors
So now there's a 10 or 11 lb. beef shoulder in the oven. ..... roasts with additional water added as required were put into a large steam kettle to ... This works with any meat Pork, Lamb, Beef or even Frozen Turkeys especially at ...
defrost roast lamb in vario stream oven Google Search
Apr 30, 2017 | Ovens
2007 road king codes p0152, S-U1016, SP - U101. Bike will crank but wont start
P0152 Rear O2 sensor high (rich)
U1016 Loss of ECM serial data - this is why the bike will not run. Fix this first.
NO code such as U101
Jul 19, 2012 | Harley Davidson FLHRCI Road King Classic...
I have a Proview PL716S and sometimes the entire
ur monitor got err i need to be changecoz repairing of monitor is unprofit
Apr 14, 2010 | Proview PL916S2 Monitor
Power cord for proview monitor model Por PL716S
This link will have it....http://quail.com/index.cfm?gclid=CLuglZORppgCFQu-GgodGwZmoA.RICHARDM69
Jan 23, 2009 | Proview PL913B 19" Flat Panel LCD Monitor
ENERGY SAver is stuck on
I know it's an older post, but you still may be waiting an answer:
What is probably happening is Your power board is failing to maintain power enough to run the bulbs and the rest.
That is why it takes long to start up and why it goes into sleep mode.
Does the power button stay lit (getting signal) or turn to amber (sleep mode) or does it flash.
powerseller
bammbammfran
Sep 04, 2008 | Proview PL926WBi 19" LCD Monitor
Need help: ProView 700P Silver LCD Monitor
You do NOT need a driver. Your monitor is broken. The high voltage power supply that provides power to light the CCFL cold cathode fluorescent lights is broken. The most common problem is that the 470uF 25V capacitors on the power supply circuit board are bad. Bad Caps have a swollen and sometimes leaky top. There are 6 capacitors that cost about 50 cents apiece from www.partsexpress.com . Buy high temperature replacement capacitors rated at 105C. If you can't de-solder and resolder have some 14 year old kid do it for you.
Feb 26, 2008 | Computers & Internet
Proview monitor PL716s
you ave some blown caps on the vga board replace them and all will be well
Dec 28, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Proview PL716s computer monitor
Bad Inverter. Or a surface mount component on the inverter. Either way it needs to be trouble shot down to the component level or replace the inverter board.
Sep 17, 2007 | Gateway FPD2275W LCD Monitor
Proview pl716s monitor will not come on
i just had this problem with my screen (proview pl716s) if you open the case and take out the power board, there are 6 470 uf capasitors bundled together and 1 220uf capasitor replace all 7 and that should fix your problem , that is what i did and it worked like a charm , oh and btw make sure before you swap your monitor from an older standard monitor to the lcd make sure the resolution is high enough becuase if it is not then the monitor will not be able to be displayd , hope that helps
Aug 16, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
Computers & Internet Logo
242 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
