Question about Zenith Data Systems Zenith (OP-260-74501) Plug-In Module 24x CD-ROM Drive
CD/DVD drive stuck CLOSED and NO pin hole
I have an e-machine brand computer desk top type. My CD/DVD drive is stuck closed. I can't get it open at all. It tries. You can hear it trying. I have no pin hole on the front as most places suggest.I tried blowing it out from back and front. When it last was opening it would read a disc but not burn it. If you tried to burn a disc it said please insert a disc. Which there was a blank one in there LOL. But now I just want it to open so I can READ a disc. I havea ez-dub burner that is a stand alone but I don't know how to read discs from there . I think it only burns them?
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Posted on Feb 01, 2010
  • 600 Answers
Alternate click on the device in MY COMPUTER and click eject
Posted on Apr 14, 2009
    Problem Solver:
  • 8 Answers
A disc is stuck in my dell laptop
Please provide the model number. Also, assuming you're talking about a CD stuck in the drive. There should be a tiny pin hole on the CD/DVD drive bezel. Unplug laptop and remove battery. Then stick a tiny pin in that hole -- should release the catch that keeps the optical drive bay closed. You can then open the drive and remove the disc.
Nov 08, 2014 | Dell Inspiron Computers & Internet
Cd stuck in emachine and there's no pin hole
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Jun 15, 2012 | E-Machines emachines (emachinees) CD-ROM...
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
Cd dvd door wont open.i push the button to put in cd and nothing happens.i do see a little cd on screen ,then it goes away.
On the front of most CD or DVD drives there is a small pin hole that you can use to open the drive if it gets stuck. Grab yourself a strong paper clip, straighten one end, insert the straight bit into the hole and push firmly once you feel some resistance.
This will partly open the drive tray to either allow you to remove a cd or insert a new cd or dvd.
Question, Is there a light lit on the front of the drive when you are:
a. trying to eject (instead of using the front button on the drive try using the "Right Click and then Eject" option when selecting the dvd drive in My Computer), If not the drive may be stuffed (broken) or perhaps the 4 pin power connection lead at the rear of the dvd drive has fallen out.
b. is the drive tray sticky when opening or closing? (get a new drive...very easy and very cheap to buy and replace)
Good luck,
Steve (Melbourne,Australia)
May 14, 2010 | E-Machines eMachines Desktop PC
Cd stuck no way to eject
Hoping it's running XP or later.
1) Start the computer in safe mode - Pressing F8 after the boot but before it tries to start windows.
2) Select "Start in safe mode"
3) when active (fingers crossed) Choose Start - All Programmes - Accessories - System Tools - System Restore and restore to a date prior to all your problems.
4) Win Vista is similar but the System restore is in a slightly different place, but not sure where exactly
Mar 14, 2010 | Computers & Internet
Well we have a acer computer and the cd drive is stuck
If pressing the eject button does not eject the tray, look for the small pin hole on the cd drive and insert a paper clip to press that hole. It would manually eject your CD tray. Hope this helps.
Nov 03, 2009 | Acer Aspire 5500 5570-2609 Laptop
MY DVD IS STUCK IN MY BROKEN MACHINE, HOW DO I GET IT OUT?
if your dvd drive is stuck in your ole computer!!! you need to give more info on what type of computer you have? is it a dell compaq "what"?... if you are trying to get a DVD out of your dvd drive then thats easy, in the front you will see a very small pin hole. push a pin into it and you will open the drives draw.
Aug 17, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
DVD Drive door stays open
>One solution is to TAKE A SMALL PIN AND RESET YOUR DRIVE BY POKING THE PIN INTO THE HOLE BELOW THE DOOR..
If this doesnt solve....
You need to necessarily replace the drive..
Jul 07, 2009 | Samsung SC 152 Internal 52x CD-ROM Drive
Help i got this 2 weeks ago and rented cd stuck
Most players have a small hole just below the tray (a little bigger than a pin hole),put a pin in the hole,and the tray should open.
Jul 17, 2008 | Durabrand STS92 System
DVD drive Stuck
There is an issue with the drive.If u see in the front there is a small hole in which you can insurt and safety pin to oen it.Incase that is not working as well i would suggest to replace it.
Dec 21, 2007 | Zenith Data Systems Zenith (OP-260-74501)...
Computers & Internet Logo
1,974 people viewed this question
Top Zenith Data Systems Computers & Internet Experts
David Payne
David Payne
Are you a Zenith Data Systems Computer and Internet Expert? Answer questions, earn points and help others
