Question about GE WBVH6240F Front Load Washer
Makes horrible noise during spin cycle only
G.E. WPRE6150HWT, washer 2 years old, noise ONLY during spin cycle
  • 367 Answers
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Posted on Jan 28, 2009
Washer makes a lot of noise during spinning
we need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
Sep 10, 2009 | Whirlpool Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Apr 22, 2009 | GE Washing Machines
Thumping Noise
it must be due to the damaged belt inside the motor. check it out.
thank you
Mar 09, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing machine makes a clanging sound during agitation/spin
Without being there to physically see what it's doing or hear the sound, I would say there's 3 possibilities. 1) drive block is slipping on basket drive / brake assembly. 2) basket drive assembly is worn where drive block seats onto it. 3) clutch slipping.
Sep 26, 2017 | Whirlpool Washing Machines
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
Apr 15, 2008 | Washing Machines
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
GE WBVH6240F Front Load Washer Logo
701 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
