Question about Autodesk AutoCAD 2002 for PC
AutoCAD error message
When I open the program, it gives an error message, "Error 14.19", but still works! What is 14.19?
5 Suggested Answers
  • 73 Answers
SOURCE: when i switch from a
probably is a registry problem. Try to clean the registry or uninstall and proceed with a clean installation of the product
Posted on Nov 10, 2008
SpideRaY
  • 687 Answers
SOURCE: My Autocad LT 2004 (upgraded
James I am on the chat now but cant see you !!
Posted on Oct 16, 2009
SOURCE: windows vista will not open autocad 2004 after being loaded
Installing autocad 2004 on Vista windows, while loading disc stops, Error MS 19725
Posted on Aug 24, 2010
  • 401 Answers
SOURCE: opening dwgs. in autocad 2004
The cause must be virus, incorrect user actions, power failures directs to program corruption
Make use of programmed method to solve problem out http://www.autocad.repairtoolbox.com
Posted on Jun 17, 2012
Error opening AutoCad file
This error can have a variety of causes....corrupt drawing, a program corruption, or a problem with your system configuration.
There are several ways to troubleshoot the problem: try opening another drawing ,uninstall any antivirus or desktop locking programs or update your graphics driver. If it useless so your file is damaged. In this case you can try to recover it with the help of https://www.fixtoolbox.com/autocadfix.html
Feb 21, 2017 | The Computers & Internet
Error AutoCAD 2016
DWG Repair Kit is a program will show you how to repair dwg files online.
Here the link: http://www.dwg.repair/
Best Regards,
Roger Mason
Oct 07, 2016 | Computers & Internet
Fatal error: unhandled e06d7363h exception at 7618c41fh.. What is this and how do I fix it???
Try checking in with the AutoCAD Community for additional visibility and potential solutions.
Philip
AutodeskCare' Community Manager
TW l PI l YT l BLOG
Oct 16, 2012 | Autodesk AutoCAD 2002 for PC
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
See More
Issue:
Causes:
Solution:
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Sep 15, 2010 | Autodesk AutoCAD 2010
Opening dwgs. in autocad 2004
Try rebooting your computer, then relaunch AutoCAD. If your .dwg file will not open then open the backup file. Sometimes the .dwg file goes crazy and the backup file will save your life, most of the time. Also make sure that your machine has enough memory to run AutoCAD. Memory is either your best friend or your worst enemy when working with AutoCAD. I hope this helps.
Apr 08, 2009 | Autodesk AutoCAD 2004 for PC
AutoCAD LT 2008 (xref circular references)
The "circular reference" indicates that the xref you are pulling in is also xrefing the drawing file you are in which creates this circular reference to each other. The error message is only a warning and does not prevent you from working and saving changes. To get rid of the error message, close the primary drawing file and then open the reference drawing and DETACH the xref that is linked to your primary drawing. Save the changes and then open the primary drawing file again to see if the error was resolved.
Mar 16, 2009 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
Windows vista will not open autocad 2004 after being loaded
All you need do is got to autocad website and download the autocad lockeds1. its a patch it works for pirated autocad as well.
Mar 02, 2009 | Autodesk AutoCAD 2004 for PC
AutoCad R14 to Vista - bab-Mem-Pointer error message
You are still using AutoCAD R14? If you are that might be the problem. If you are running Vista, then AutoCAD R14 might be too old of a version to run. You will probably need to upgrade to a newer version of AutoCAD. I know this isn't a solution, but I am just trying to look at it from a different point of view. You can also go to autodesk.com and join their discussion groups. It is free and you can post questions. You usually get a fast response with an answer that really helps. I will do a little more research and add more when I get a chance. Good luck and I hope that I helped.
Feb 22, 2009 | Autodesk AutoCAD LT 2008 - Upgrade for 5...
Autodesk AutoCAD 2002 for PC Logo
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
