Question about KitchenAid KGSA906PSS Gas Kitchen Range
Self Clean I self cleaned our range last night now the display is out and the door will not open
  • 4 more comments
  • linkmpg Mar 08, 2009
    I have the same problem on my range, the thermal fuse blows every time I use the self-clean feature. I have replaced part no. 8400802 several times.
    I'm wondering what you think of replacing this part with 4451442, which is a 248 degree thermostat, or 4452223, which is a 266 degree thermostat. the stock 8300802 is a 230 degree thermostat
  • monicamartin Mar 12, 2009
    WHAT DOES THERMAL FUSE LOOK LIKE
  • dre0652 Apr 05, 2009
    After starting the Self Cleaning Mode the Display went blank and the Oven Door stayed locked. The Burner Igniters still work on the Stove Top and I tried resetting the power to the unit but this did not fix the problem. Apparently there is an updated kit for repair, part number 9759243 which should be available free of charge. Everyone should complain to KitchenAid. If you know where the part is located in the oven please advise.
  • plc10 Apr 19, 2009
    Same thing happened to me just yesterday. Tried shutting the power off too. Oven is still locked. I have a repair scheduled for tomorrow. It was the first time I used the self-cleaning feature. I've also had the safety valve go on this range 3 times in the 4 years I've had it.
  • apaletta May 26, 2009
    this has happenned to our range twice during self clean cycle panel goes blank and door remains locked. First repair one year ago replaced high limit sensor. that appears to have happened again, clearly a design problem that should be on a recall list!!!!
  • Michael Fisher
    Michael Fisher May 11, 2010
    Have You Tried Unplugging The Unit And Then Plug It Back In?
This problem is well documented on the net and a common problem with running self clean on these ranges. There is a thermal fuse on the back of the oven box (under the outer sheetmetal skin.) It overheats in self clean mode and shuts off gas and power to the oven/display (like it's designed to do in a fire.). IT's a $40 part and not hard to do yourself. All you need is a screwdriver to remove the sheetmetal and part. The replacement part # # is 8300802.
Just fixed mine this week..
hth
Posted on Feb 14, 2009
  • 4 Answers
Write to Whirlpool! There is a fix! It's part number 9159243! It's coming to me free of charge.
Posted on Feb 02, 2009
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Self clean - door will not open - no display
Without the model I don't know if unit has one or two open fused which has stopped power to the electronic control this the schematic should be in a plastic packet stuck behind control panel if not then on the back side of the storage drawer if equipped.
Jan 20, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
I performed a self clean on my gas oven last night and now this morning the oven won't open and the lights are out in the display window. The electric start works on the burners so I have power what else...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Display shows 'door' at start of self clean
mine is doing this too. Were you able to solve this?
Dec 25, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Bosch evolution range door won't lock for sef cleaning
You are correct. If the door does not lock, the self-clean function will not activate.
Spray some WD40 into the lock mechanism and let it sit over night. Then try it again.
Feb 10, 2009 | Bosch Evolution Pro-Style 700 HDS7282U...
Does not go into self clean only beeps
here is a link for your owners manual click here
To set Self-Clean:
1. Close the oven door.
2. Press the appropriate Clean pad.
• CLEAN flashes.
• SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
• “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning
settings.
“HVy” (Heavy Soil, 4 hours)
“MEd” (Medium soil, 3 hours)
“LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs
the self-cleaning time.
5. After four seconds, the oven will start cleaning.
• If the door is not closed, beeps will sound and ‘door’ will
display. If the door is not closed within 30 seconds, the
self-cleaning operation will be canceled and the display
will return to the time of day.
• CLEAN will appear in the display.
• LOCK will flash in the display. Once the door locks,
LOCK will remain steady.
• The cleaning time will start counting down in the
display.
Please take the time to rate this solution
Jan 30, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Hotpoint RB757 DOOR LOCKED CANT OPEN NO MANUAL PLEASE HELP
act like your going to self clean and start from beginning and set it to self clean ,,, after you hear it lock down and start to go in clean the cancel it out and it will open / have a good thanksgiving
Nov 26, 2008 | Hotpoint RB757 Electric Kitchen Range
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
KitchenAid KGSA906PSS Gas Kitchen Range Logo
531 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
