Question about E-Machines eMachines Desktop PC
Connections i have a emachine t2882 i need to know how the power supply plug in to what and where
  • 2,404 Answers
The main connector to the power supply has to go into the motherboard. Its a rectangle shapped male connector that is on the end of the power supply that plugs into a rectangle female shaped connector on the motherboard. There might also be a shorter square male 4 pin connector at the end of the power supply that should connect into a 4 pin female connector on the motherboard.
After this then you'll want to plug the other connectors into any cd-rom, dvd-rom drives you may have. Same for a floppy drive if you have one. Also make sure your hard drive is hooked up. The connectors that you plug to these devices can only go in one way so no worries about hooking it up improperly. Hope this helps.
After all this, turn on the computer and then after you boot up into windows, make sure you go into my computer and verify that all your drives are being shown in there.
Posted on Feb 02, 2009
Usb not recognizing device t2882
What I suspect here is that,
Provided the operating system that you are using is Up to Date (e.g WinXP SP2 to Win Vista),
the USB port that you are using might be a USB 1.0 port, which has a lower voltage not enough to power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a USB 2.0 one (Just keep Checking all the ports one by one in case you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Hope this helps you out.
Goodluck
Oct 30, 2009 | E-Machines eMachines Desktop PC
Emachine t2882: not powering up just an amber light. replaced power supply, still just an amber light. power supply fan runs, but cpu fan does not. reseated all connections. plugged in drives one by one,...
Hello there:
ok unplug everything from the board first and power up and see what happnes. if nothing still unplug the powersupply to the motherboard and press in the power button and hold it in for 1 min and than plug in the powersupply to the motherboard and see what happnes. Also doublecheck the jumper for the cmos. ok please keep me informed there is a lot more that we can do but lets try this first ok best regards mike
Aug 16, 2009 | Computers & Internet
I have a t2882 emachine it won`t turn on light on frount is on but won`t turn on
Check the monitor connection the pc or you may have to buy a video card for your pc.
Jul 18, 2009 | E-Machines T2882 PC Desktop
Not getting power on my t2882 e-machine.
I am an emachine specialist. These computer suffer with problem motherboards which often blow the power supply unit. Replacing the power supply on it's own does not solve the problem as the motherboard processor socket is the cause of the problem, the fault in turn blows the power supply. The same applies to all Advent and Medion computers sold via the high street stores.
Need help to repair, email me me at compdoctor2005@btinternet.com or ring me on 07926-106150
Mar 19, 2009 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Short but rapid beep code when powering up emachine
The beep code most likely is either video card or memory.
If you have a video card or can borrow one that you know it works try it first, if that doesn't resolve your issue try the memory.
You can take the memory out and have it tested to see if it is defective.
Go to this site and get the Beep Codes, http://www.computerhope.com/beep.htm
I hope this helps.
Good Luck.
Feb 26, 2009 | E-Machines eMachines Desktop PC
My emachine t2882
Try this : See if you can find your motherboard model number. If so, type it into Google, go to the manufacturers site and download a manual which should have the wiring diagram you require.
Cheers.
Jan 28, 2009 | E-Machines eMachines Desktop PC
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
Will not boot up at start
this sounds like a mobo issue .... if the machine has been in service for a while or is in a dusty environment a good internal vacume / brushing to remove dust buildup from the mobo might help.... also disconnect and reconnect the main powwer connectors from the mobo... the power button on the case is simply a contact which jumpers the two pins on the mobo... the actual power switching takes place withing the power circuits built into the mobo... you may also try a mobo driver update if it is available
Mar 29, 2008 | E-Machines eMachines Desktop PC
EMACHINE t2882
Are the pins from the switch to the motherboard connected properly?
Could be a faulty switch on you case. T
ry shorting out the two power on pins (on motherboard) with a screw driver but be carefull not to touch anything else with it!! :)
hope this helps?
Jan 06, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
59 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
