Question about RCA 20V500T 20" TV
Composite video jack in rear of tv broken
Snapped screw stud broke off of box looking device which is soldered onto board.... can i purchase this device and resolder onto board.. if yes where, how and how much...
thank you,
brian pollere
    Sergeant:
  • 227 Answers
Try Radio Shack, about $1.25
Posted on Jan 28, 2009
How I do I repair cable connection from back of TV. It broke off when I tried to unscrew the cable to it
unless you have excellent desolder and soldering skills plus the special tools needed, you will have to replace the board that the broken connector is on. Or use a cable box/satellite box and the component, composite, or HDMI input
Oct 20, 2014 | Seiki Televison & Video
The box on the back of tv that the coax cable turns onto is broken. Can we go buy a cable peice and just solder it back on or do we need to order the whole little box?
You can buy the RF jack and solder it back onto the tuner as long as the tuner has not been damaged beyond repair. Inside the tuner the center conductor from the jack solders into the printed circuit board. If any small parts are broken or missing then you will have to replace the tuner.
Jan 04, 2011 | Sony KP-41T35 41" Rear Projection...
Broken tuner
If the board is not cracked,a qualified technician may be able to sloder another coaxial jack for a service call charge. Look carefully with a flash light........if you see the small board is cracked.....it will need the tuner and could cost $200. You may be able to cicuimvent by hooking your cable box or satellite box into the video inputs instead......select with input button on remote and should work fine with no repair at all
Jun 06, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Jack plug broken off
Buy a $4.00 1/8" jack replacement from Radio Shack - part # 274-0869, which has small screw connectors that don't need soldering.
Strip about 1" of the braided insulation at the old jack end, which will expose 4 very small wires: Blue, Green, Red, Copper.
Attach the Green & Copper wires to the tallest pin on the replacement jack.
Attach the Red to the shortest pin, and the Blue to the medium pin.
Remember to slide the jack cover onto the headphone cord before attaching any wires!
This works great, I just did it.
May 14, 2009 | Skull Candy Lowrider Headphones
Tv fell and coax antenna cable got yanked out of back of tv.
Repair can be made if you use the utmost care. Do not remove tuner (steel case). Open side closest to screw jack and remove other side,may be soldered. Observe the the center lead and how damaged the pc board is. Use solder and thin wire, strip a twisted wire till you have one strand and repair board and solder the outer metal to the tuner can. Then presto TV again! Good Luck be safe..
Mar 30, 2009 | Emerson EWC20D4 Combo
I broke off the power connector inside my Tomtom
I finally managed to pull back the rear cover by inserting a thin piece of metal at the top of the rear cover. It snapped off by pulling it backwards and then downwards. And I soldered the connector back on. I only had to solder the 4 feet of the small metal shield, the contacts are just pressing on the circuit board.
Mar 30, 2009 | Tomtom One XL GPS Receiver
Broke the piece where the cable wire goes in...what's it called?
Unfortunately, that coax connector  is almost certainly crimped onto a cable inside.  You might want to pull off the back panel to see if that internal cable is screwed onto another jack on the chassis. If so, you can disconnect that end and substitute another cable, they come in several different lengths and are not critical. Any electronics store will have them.
If it isn't equipped with a connector inside, you will need to have someone unsolder the defective cable and install a new one.
Dec 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Cable antena ready input repair
Purchase replacement at radio shack, disassemble the tuner, and solder the replacement in. It is not a screw in.
Sep 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help! Surround Sound problems!
Since you have a surround sound system, you probably should just bypass the TV's audio.
Connect the red/white plugs from your digital cable box to one of the inputs on your surround sound system but not the Phono input unless the Phono input lists something aside from Phono, like Aux/Phono or CD/Phono.
Connect the S-Video or composite (yellow) video plug from your digital cable box directly to the S-Video or composite (yellow) video jack on your TV.
If your digital cable box does not have a S-Video (4 pins and flat rectangular hole) or Composite (yellow RCA jack) jack and only has the screw/push-on type cable with the pin in it, then leave the remaining connections as-is.
Now switch your surround sound system to the input you connected the red and white plugs to and turn on your TV. You should see picture from the TV, but hear audio from the surround sound system.
Apr 06, 2008 | Emerson EWF2004 20" TV
REMOTE CENSOR
I assume you are speaking of the sensor (on the TV) which picks up the remote box commands, or the infrared LED (on the remote) which transmits the commands. Which ever the case, it sounds like a broken & intermittent solder connection where the device solders onto the circuit board. Most of problem I've seen is the remote box end of things.
You will need a solder iron, solder, and a little soldering expertise to fix this. The remote box might have one or two screws, otherwise the case is usually a snap together, and sometimes frustrating to get apart.
If the TV end of things, then you must unplug the set, take the back cover, and carefully remove the main chassis, and note where the sensor is.
Hope this helps!
Nov 13, 2007 | Televison & Video
Televison & Video Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
