Question about Sony PlayStation 2 Slimline Console
Our PS2 was dropped and now won't read disc
It doesn't say "disc error" like the problem a lot of other people are having but doesn't even seem to be spinning the disc. It comes up to "Browser" and "System Configuration" and doesn't play the game.
  • 64 Answers
It looks as if your PS2 has died. I'm sorry to say, but since the firmware boots and it's just the disc error message, it lokos like a hardware error that is likely irreparable. This is the best "solution" i can give! please dont blame me! Just trying to help... but you can find great used ones for cheap now. Good Luck!
Posted on Jul 26, 2007
How do i fix a webpage error message object doesn't support property or method 'playJSON'
It seems like an IE browser issue.
Plz read the following discussion :
IE9 Javascript error object doesn support property or method
Anyhow, I would recommend the FireFox Browser to work with.
G'Luck.
Jul 30, 2014 | Microsoft Windows 7 Home Premium 64BIT...
I have a playstation 2 slim here. It wont spin the
Is that the only disc you seem to be having the problem with?? If so try getting the disc repair kit and using that. I had the same problem with mine but it was only some of the discs. The ps2 slim can be very sensitive and even the slightest defect in a disc will cause it not to recognize there is even a disc there.
Oct 17, 2013 | Sony PlayStation 2 (PS2) Console
Denon DN-C635 CD Player problem.
In working with consumer electronics a lot of years, the pickup, mechanism or CD section is not always at fault but people that
are trying to work on their own equipment make assumptions that may not be correct. If you put in a new CD player then the other issues as with all wave soldered equipment can be bad solder joints and even bad solder at joints where the connectors are as these get a lot of activity in a repair. Look at the PCB well. I have fixed a lot of equipment by resoldering bad or broken joints. Check around power transistors and those larger drive transistors for these broken joints.
Mar 22, 2013 | Denon DN-C635 CD Player
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
Can't play CDs in my car. The Unit gives me error code 4
The error 4 in most CD Player is an error that comes up when the laser pickup doesn't read the disc correctly. This happens most of the time because of a dirty lens in the laser pickup. If anyone smokes in the vehicle the smoke may be on the lens causing the error code. Try a wet type CD cleaning disc to see if it helps.
"Error 4" is a mechanical disc loading problem. The disc probably hasn't been seating in the #6 carrier properly, leading to some mechanical interference when it is selected. It would seem to be properly seated now, but next time you have it out you might check it on a perfectly smooth flat surface to be sure it is not warped slightly. Try another disc in that position, one you know to be trouble-free.
I burn a lot of discs for my clients and have never had a problem with the mid or high-grade discs from Taiyo Yuden, and others. Even lesser discs like Ritek perform fairly well. Some brands - usually the no-names - fail right out of the box. One of the problems seems to be that the cheapest discs are pretty thin and subject to mechanical problems like warping.
If you use "economy" discs particularly, be sure to put a label on them. Most of the cheap discs don't have much of a protective coat on top and scratching the top metal foil finish can lead to serious playback troubles as the disc is read by the laser from the bottom.. In addition to telling you what's ON the disc, the label helps protect that critical foil.
Hope helps.
Aug 20, 2011 | Car Audio & Video
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
Aug 16, 2011 | Computers & Internet
PLAYSTATION DOES NOT READ ANY DISK AT ALL, AS SOON AS YOU ENTER DISC, BROWSER SCREEN COMES UP. AND WHEN YOU CLICK ON BROWSER, JUST THE MEMORY CARD POPS UP. DOESNT SAY ITS READING AT ALL, IT.DONT EVEN SOUND...
try to check CD ROM if its working or not and try also to used another Play Station using your DISC.if your disc is OK then your CD ROM of your play station needs to repair.
May 17, 2011 | Computers & Internet
The disc spins but doesn't show anything. It goes straight to the browser and system configuration screen. It acts like there's no disc in it.
The disc spins but doesn\'t show anything. It goes straight to the browser and system configuration screen. It acts like there\'s no disc in it.
Sep 04, 2010 | Sony PlayStation 2 Slimline Console
Memorex dvd player 2040..disc won't stop spinning!
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD hed cleaning CDs.If still the problem persists, contact near by service center for replacing the faulty Lens.
Mar 13, 2009 | Televison & Video
Sony PlayStation 2 Slimline Console Logo
372 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
David
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
