Question about Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System
I just payed for a repairman to come out to find out why my washer quit washing. We don't know if it's the timer or a loose wire. Im hoping for the loose wire. However it was a total waste of money because the wire diagram was missing. Where can I find one of these for a White-Westinghouse model WWS833ES. He said if I can locate one TODAY, he'll come back out and won't charge me the service call fee again.
    President:
  • 2,992 Answers
Go here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5148891
Scroll down to the bottom of the left side under the "Select Diagram" tab and you'll find the "Wiring diagram" link. Click it for the diagram. You can then right-click on the diagram when it comes up and select "view image." That will show it to you in a single window so you can copy and print it.
Posted on Jan 28, 2009
I have a Maytag Dependable Care Plus washing machine. Water won't fill. The spin cycle works. Repairman out and said there was a short and lose wire. I wanted to know so I could resolve the next time....
Find a repairman who stands behind his work. If no water, I'd first be looking at the screens in water valve and hoses. Could also be lid lock or lid switch depending on model. Could also be defective water valve or possibly defective pressure Switch. Timer could be bad. Many possibilities
Sep 06, 2017 | Washing Machines
My washer is relatively new but won't kick into its high speed spin anymore. It washes normally, does its rinse thing, but then stays in the low speed spin. I have done all kinds of washes to determine...
It sounds like a problem with the agitator. Simply remove softener insert and just below that is a seal easily removed and then a 7/16'' bolt. The clutch mechanism between base and upper agitators is probably loose or broken.
I hope this helps. Good luck!
Mar 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Stop working during a wash cycle, power was at the plug
ince the washer is stopping during the fill, wash and rinse cycles, it is possible that you have a failed timer. A loose wiring connection could also cause this problem. Before replacing the timer, I recommend that you unplug the washer and check the wiring connections on the timer for a loose wire. Check the wiring connections on the water level pressure switch as well.
Jan 12, 2011 | Whirlpool Washing Machines
The washing machine at my church stops in the middle of a cycle. When I "jiggle" the timer it starts again and works for a while and then stops again.
The timer probably has dirty/corroded/loose contacts or it has loose wire connections to it. Needs to be removed to assess.
More info, let me know.
Charlie
Oct 01, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool washer (model LA5578XTWO) starts washing and quits
DOES THE TIMER KEEP GOING WHEN THIS HAPPENS, IF THE TIMER STOPS IT NEEDS TO BE REPLACED. DOES THE WASHER DRAIN IF YOU TURN THE TIMER MANUALLY BY HAND IF SO THE TIMER IS WORKING TO THE END OF THE WASH CYCLE AND STOPS THE TIME IS BAD
Aug 11, 2009 | Washing Machines
Ultimate 2 whirlpool washer will go through the wash cycle then quit before it drains the water out or spins or rinses
SOUNDS TO ME LIKE EITHER THE TIMER HAS GONE BAD IN IT. MY LATE GRANDMOTHER HAD A WASHER THAT WOULD QUIT DURING THE CYCLE. OR IT COULD BE YOUR MOTOR OVERHEATING. CALL A REPAIRMAN AND SEE IF HE CAN FIX IT FOR YA. GOOD LUCK.
RODNEY
May 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Ge profile washer has a d5 code that is displayed machine
CHECK THE TIMER. I DON'T KNOW IF THAT IS WHAT IT IS, BUT IF IT IS YOUR TIMER, YOU NEED TO CALL A REPAIRMAN AND SEE IF HE CAN FIX IT FOR YA. HOW OLD IS YOUR WASHER?
RODNEY
Apr 12, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Help with washer
yes it could be the timer, next time it happens jiggle the timer knob and see if does anything, if it does then you know it is the timer. if it doesn't then it may be something loose in the control panel like the wire harness on the timer may not be getting good contact.
Jul 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer
could be timer,or motor short out,check and wire connections,remove time and look to see if you have any burnt point,hope this helps .
May 29, 2008 | Maytag LSE7806A Top Load Stacked...
Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
371 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
