Question about Sub-Zero Freezers
Temperature goes up
Right now it is 17 and things start to thaw. The freezer drawers stay colder than the cabinet does
  • Lisa Davis Jan 29, 2009
    I did as you suggested and the fans appear to be working just fine. Could an accumulation of dust be the problem?
  • Lisa Davis Jan 31, 2009
    The freezer temperature is now down to 10 or 13.
    The freon has been checked and i wiped dust off the coil which is behind the bottom drawer. I would have vacuumed if off but the central vac is plugged up right at the moment and have been using an upright to vacuum. The whole freezer is built in and and has a wood face and there is a strip of wood at the bottom where the coil is covering up the works. I have been told by repair men in the past that having the board down at the bottom covering up the coil and such that the freezer might not work as efficiently. Blowing off the dust with compressed air is an excellent idea. thx for the advice.
  • 410 Answers
Do you hear any fans running?  by the temp staying cold on the drawers whih are in the lower area of the freezer it indiates to me that the fans are inoperable. to test open freezer door then push in light switch by hand and listen for the fans to come on. if it turns out you have bad motor you most likely will have to call a sub zero dealer to have repaired. messge me back with any questions peyton
Posted on Jan 28, 2009
  • peyton thompson
    peyton thompson Jan 29, 2009
    yes it could Im sure that the cond for your refrig is on top of the unit so remove the cover and expose the coil. vacum or blow them out with compressed air depending on how dirty they are. also while you have the cover off besure the fan motor on top is operational as well. after you do this and find everything operational let it run for a couple of days too see if the temp will come back to normal. if not, you most likely will have a freon system problem and will need a qualified service company to repair for you. thx peyton
2 lights on bottom outside on food defrosting
5 Common Freezer Problems - APWagner Appliance Parts ...
May 22, 2008 - Answer 2: The first thing to do is to set the thermostat to a colder setting. ... The compressor is at the back of the freezer near the bottom. ... You can manually defrost your freezer by turning it off for 24-48 hours and turn it back on to see if it begins to work ... Verify that the door light switch is working properly.
Why is my freezer suddenly frosting over? - Askville
May 30, 2009 - For the last 2 months my freezer has had a layer of frost over ...Normally when frost build up occurs its because warmer outside air is getting into thefreezer and the ... Or you may have an issue with the defrost heater, thermostat or timer. ... If there is no light you may not have a frost free freezer which means ...
Why is my upright freezer freezing at the bottom but warm on ... > Patricia Delugas > Questions
Food in the drawers is still frozen, but above this level is room temperature to the touch. ... the lower inside pane to remove ice from around the fan and evaporator (mostly refrozen fluids from thawing foods on the upper shelves). ... 2 Answers from these members: ... Outside is not warm (as usual). Yellow light remains on. 2 ...
[PDF]All about the of your Freezer - AJ Madison
Jan 20, 2016 | Freezers
Freezer in unheated/unairconditioned garage it stays cold in winter time but it is not freezing when the temperature is hot in the garage
The first thing is to find out if there is a fan that runs next to the compressor. If not then in the summer the machine is overheating and passing the heat up to the machine itself thawing or preventing the freezer from operation properly
May 17, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Unsure how the temperature dial goes. Is it l. or r. for colder?
Hi Normally temperature dial has at left maximum temperature while right is minimum temperature.
You can feel ( hear ) actually the sound of motor/compressor when it is run. Running motor will produce low temperature. By this you can decide where the set point should be made
Sep 09, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
How to make my freezer colder
Hi, some thermostat control knobs and directions to make it colder are different. Here is the best way to find out which way to turn it to make it colder. Make sure you hear it running. Take the control knob and listen carefully while you start to turn it in one direction first. Turn it until you hear the unit shut off. If you turn it all the way to the left and it keeps running, turn it all the way to the right until it stops running. Once you know which way it stops running when you turn it, this will tell you that you need to turn it until it comes back on again and runs. This will be the way it turns to get the temperature to get to a colder setting. When you are doing this, do it very slow and give it about 3 minutes in between each time you start to turn it the other way. On mine it has numbers on it. The higher the number lets say from 1 to 8, the colder it gets, but some are the lower the number the colder it gets. So, you want it to shut off, so wait until you hear it running before you turn the knob. You can open the doors and it will make it come on faster. So when it goes off when you turn the control knob, you will no to turn it the other way for it to come on and it will get colder the more you turn it in that direction. Very easy. PS If it doesn't get colder when you find out which way it goes, you may have a bad thermostat. Please let me know. You can put a thermometer inside to watch the temperature
Good Luck,
Jun 30, 2010 | Hoover 9.9 cu. ft. / 280 liter Upright...
We had a power surge and the freezer thawed out and did not come back on when the power came on the freezer sounds like it is working the quick freeze light is on and the green light is on we...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Jun 24, 2010 | Kenmore 4.8 cu. ft. / 136 liter Chest...
Temp changes in freezer
If the temperature fluctuations occur (at least the ones to 20-30 degrees) at intervals of 6 hours or so then you are catching it in it's defrost mode which occurs on a timer. The timer shuts off everything except lights every 6 hours for an average of 20 minutes. This usually isn't enough to thaw things but I have seen it cause some crystale. Look closely at the back inside wall of the freezer for an accumulation of frost. If you see it there then you may have a defrost problem. Usually this is accompanied by steadily rising temperature in the freezer and fresh food secions both. The temps you listed (0to10) are fine. Good luck, AJ
May 22, 2009 | Freezers
Recommended temp for a freezer is -17C. That's MINUS 17 degrees Celcius.
Usually the higher the number the colder the temperature.
Oct 21, 2008 | Freezers
Maytag freezer
sure its on ly 3 years old. you rseled system should be covered for 5 years (compreessor, freon, evap, condesor). was it making a buzzing noise?? trying to start and clicking right off??? thaose are sounds a bad compressor makes,
Mar 19, 2008 | Maytag Freezer MQU2057
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Upright freezer--manual defrost
I would check that the door gasket makes good contact with the cabinet. If it does then I would check the temp inside the cabinet. If you have large buildups of ice on the evaporator coils then I would suggest defrosting the freezer and see if that makes a difference. Hope this helps.
Aug 10, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
265 people viewed this question
Top Sub-Zero Freezers Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Roderick Scott
Roderick Scott
Are you a Sub-Zero Freezer Expert? Answer questions, earn points and help others
