Question about Lands Phones
Vt2651, replace existing #3 broken phone with newly purchased
Can't get new phone to connect with base unit, need to replace existing #3 phone. How do I clear base old base ID and use that ID number for newly purchased phone?
No help yet.
Posted on Feb 06, 2009
How do I turn off voicemail on my newly purchased DS6722-3?
The immediate remedy would be to contact the phone company to get it wired correctly.
Sep 02, 2017 | The Office Equipment & Supplies
We replaced the base unit and can not register our existing handsets because they were registered to the previous base unit. Once registered the handset's menu doesn't offer a register or...
To un-register the SB67108 handset from a base unit, SB67118 or SB67138, you will need to do these steps in order:
1. Press menu
2. Key in this sequence *883247#
3. Select deregister
4. Unplug the battery for minimum 10 seconds
5. Plug battery back in and it will want to be registered.
6. Follow the directions in your base unit manual to reregister it.
That's it in a nut shell.
Jun 08, 2011 | AT&T SB67108 Phone
My phones went dead and went into searching mode. Phone lines are working just not base
Your base station is dead, this is common with Uniden phones. You will need to purchase a new base station. You can use the new base station with existing phones as long as you buy a compatible model.
May 03, 2011 | Uniden DECT 6.0 Cordless Phone ID
We have two newly purchased base units that can't pick up a line that has been placed on hold by the main reception desk phones. If you try to pick up a line that is open from these phones, they work fine....
You can't pick it up on another unit unless it is transferred from the original phone. I HATE that about this system. I have a question - we are trying to use a second base unit and are having a terrible time getting it to work right. Is it possible to use more than one base unit?
Jan 11, 2011 | RCA 25450 4-Line Extended Range Multi...
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Syncing a new ipod
What you have been told is not true, you can sync a newly purchased ipod. All you need to do is register when you connect into your USB port it will have you register it
Sep 21, 2009 | Apple iPod nano 3rd Generation
Just purchased GE model 28101 hoped to add to existing phones. Battery was dead and will not charge. Put battery in from existing phone and now lights up. Calls for registration at base unit. I have...
I have determined that the phone purchased is not compatible with my current phone system. My mistake for not understanding the fine print on the box!!!!!!
Sep 08, 2009 | Uniden Cordless Phone
Cannot reregister phones to the base.
If your base is a VT2651:
1) take phone off of the base's cradle.
2) enter **335782 on the keypad
3) phone beeps
4) remove all batteries from handsets.
5) reinstall battery in 1st handset, and enter the code number for the base unit (sticker on bottom of base). First handset will be set to phone 1
6) repeat step 5 for all other handsets.
If your base is a VT2656, there is no keypad on the base. I don't know the trick to reregister the handsets. I wish I did, since that is the problem I am having.
Nov 22, 2008 | Vtech VT2600 Additional Handsetfor...
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
The phone is constantly searching for network
It seem that the base is either bad or there is no power supplied to the base from the power adapter. Check and see if the charging light is coming on if it is then you have to replace the base unit and re register the handsets to it. If it is not then most likely the power adaptor is bad. It is difficult to check the adaptor with out a meter but if you know of a way you can try it. If the adaptor is good and there is no charging light on the base then the base definitely is bad. Good luck
Jan 02, 2007 | Uniden Cordless Phone
Lands Phones Logo
108 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
