Question about Mitsubishi WS-55819 55" Rear Projection Television
Vertical lines in the picture on light background only
When there is a light background you can see two vertical lines about 6 inches from either side going from the top to the bottom.
  • vwilkins Jan 28, 2009
    The picture is not grayed or blacked out on the outside of these lines. The lines are only about 1/2" wide and the picture is fully displayed past the lines.
  • 106 Answers
It sounds like you have Image burn in on your crt's. This happens when you watch programs in 4X3 mode. (The sides are blacked or grayed out and the picture is centered in the screen). The only way to fix this is to replace the crt's. I wish I had better news. Let me know if I can be of further assistance
Posted on Jan 28, 2009
  • tvguy171
    tvguy171 Jan 28, 2009
    You have a full picture, I know that. The point I was trying to make is that maybe at some point in time, a program that you were watching was in the 4X3 mode. HD stations transmit commercials in the 4x3 mode a lot of times. In the 4x3 mode, you will have a fulle picture from top to bottom but it will not completely fill the screen from left to right. The video usually stops about 6 inches from either side. If you watch a program in this mode for tooo long, that edge will be burned into the phosphorous of the crts and will be seen on light background scenes. That is what I think has happened. I carry a video generator with me which gives me th ability to light each individual crt. When I do this it becomes readily apparent what the problem is.
Vizio XVT3D650SV 65-Inch Theater 3D Edge Lit Razor LED LCD HDTV has a black vertical 6" wide line on the right side of screen. What is causing this problem? Is it the T-Con board?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 23, 2016 | Vizio Televison & Video
Red light flashing 4 times
sounds like it's toast http://community.sony.com/t5/Television-Picture-Sound/Vertical-Lines-of-death-KDL-52W4100/td-p/29582
Mar 26, 2014 | Sony KD-27FS170 27-Inch FD Trinitron WEGA...
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Jun 16, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Blue vertical line thru picture
It is called "Thin vertical lines" and change colors depending on the background color.
It is fixable but there are several components that can show this sympton.
You will need a tech to fix it in order to save money (because you do not want to buy a board you dont know if will fix it).
Possible Solutions:
Replace Timer Control Board, if it is not fixed
Replace Sustain Board.
One of those boards needs to be replaced and I wrote the most likely first.
May 27, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
GREEN VERTICAL LINES
vertical line ic no pda 3653
Aug 16, 2008 | RCA F36650 36" TV
Mitsubishi WS-55819 55" Rear Projection Television Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
