Question about HP 14.1 Refurbished Thinkpad, 1.13GHz Processor with Wireless Internet Card and Carrying Case (89777700071) PC Notebook
Wireless not working
I have an HP Pavillion DV4000. The light above the keyboard to let me know i am connected is not working. I cannot connect using the built in wireless. How do I get it to work?
  • 120 Answers
First thing to do - check wireless is turned on. It sounds basic, but sometimes the switch can get knocked, meaning that the laptop won't recieve any wireless signal. If this doesn't work, play around with the settings for a while - if you're running Windows you can go to 'network connection' in Control Panel and right-click on your wireless connection; go to 'repair' and the repair wizard will go through it to try and fix it. Make sure both the wireless switch on your laptop is turned on, and that your modem is turned on too.
If this doesn't work, go to your modem's setup page (usually a web page - the address will be in the manual) and choose a different wireless channel - 0, 6 and 11 are the only non-overlapping channels. You may want to adjust your wireless signal power to make sure you have enough signal. You might also want to run a diagnostic on your modem to see if it is running properly. Some modems will display on the setup page which computers are active. See if yours comes up.
If this still doesn't work, you may want to go to an internet cafe or other wireless hotspot to check whether it is your modem which is at fault. If you get a signal and can connect, then it may well be the modem at fault. Check at some other locations just to be sure. If not, it sounds like the wireless card has a problem. If it is an internal wireless card, you might want to take it back to the manufacturer for repair. If it is an external wireless adapter, you may just want to replace the card or adapter to see if this helps.
Hope you work it out, and that you get your wireless connection back soon!
Posted on Jan 28, 2009
Internet connection
That model isn't a Desktop, it's a laptop. If you're attempting to connect wirelessly, there's a wireless button, identified by an icon that looks like a tower with radio waves emanating from it. It's usually above the keyboard, and it has a blue light that indicates that wireless power is on. If the light is amber, the power is off.
Even when on, you have to use the icon in the notification area to select a wireless source, and maybe enter a numeric key or password. But on newer routers, you press a WPS button to automatically allow the device to connect.
Nov 06, 2013 | HP PAVILLION DV6841TX PC Desktop
Hp wireless keyboard not working
exact key board driver install then try
what keyboard model?
download load driver for keyboard
update keyboard driver
May 16, 2012 | HP Computers & Internet
Turn on wireless
To turn the wireless on on your laptop:
1. Click on Start. Type Mobility in the Search box. Hit the enter key.
2. In the Search results under Programs you will see Windows Mobility Center. Click on it to open it.
3. You will see a button under "Turn Wireless On"
4. Click on it to enable your wireless.
Another way using a keyboard shortcut: Press the fn and F2 keys at the same time.
I hope this helps you-Thanks for using Fix Ya.
May 02, 2011 | HP Pavilion dv4000 Notebook
I am having trouble connecting to the internet because my WLAN has been turned off, how do I turn my wireless back on?
From the HP website:
The power to the wireless network and bluetooth devices is controlled by a switch or button on most computers. It is possible to accidentally bump the button and turn off the wireless service. c02230159.jpg On most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme. To turn on and enable the wireless device, do the following:
  1. To turn on the wireless device, simply move the switch to the on position. On some computers, the switch is actually a touch point on the panel above the keyboard.
  2. To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon c02228164.gif and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon c02228163.gif will display.
Apr 18, 2011 | HP Pavilion dv4000 Notebook
Cant get the wireless connection to come on. on my hp pavillion dv4000
Check this page, I have posted a permanant fix, and a quick fix. This applies to most dv laptops. Here is a link to HP's site addressing the problem and offering a free fix (expired)-really only useful for definite verification of whether or not your laptop is affected...
Feb 16, 2010 | HP Computers & Internet
Keyboard doesn't work
If you have droped any kind of liquid on the keyboard get it replaced
Apr 17, 2009 | Computers & Internet
I have an HP Pavillion DV4000. My built in wireless is not working. The light at the top of the keyboard does not come on. How do I get it to work?
you can see the wi-fi switch...you turn on and it will work if you install already the wireless driver...its only the problem with the switch combination between wireless..there some option also for enabling the wi-fi...you can press FN key + wi-fi botton.
Jan 28, 2009 | HP 14.1 Refurbished Thinkpad, 1.13GHz...
Faulty Connection
I have HP DV6000, I used it without the battery. it worked until I was able to purchase a new battery. It might work on the HP dv4000...
Jan 05, 2009 | HP Pavilion dv4000 Notebook
Can't connect to the computer wireless
Laptops have an option to turn off the wireless, you basically have to turn on your laptop and hold the FN key and look for your key that has a little atenna with signals and press that together with the FN key, you should be good, if that doesnt work then check your device settings and make sure something didnt disable your wireless card.
Dec 22, 2008 | HP Pavilion dv4000 Notebook
HP 14.1 Refurbished Thinkpad, 1.13GHz Processor with Wireless Internet Card and Carrying Case (89777700071) PC Notebook Logo
108 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
