Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Best setup for Xbox 360 for Sony 32" Tube WEGA tv
What is the best setup for my Xbox 360 on my Sony 32" WEGA tv?
  • 257 Answers
Hi, Not sure whether you are kidding or not. You don't mention the tv model so I will try to help using a KV-32FS100 as an example. You really only have 2 choices assuming you have a current model xbox 360. The component cable that comes with the xbox has 6 connectors, a green, blue, red, yellow on one part and a white and red on the other part. On the back of the tv below and to the right of the s video connector are inputs labeled Y, Pb and Pr and are colored Y is green Pb is Blue and Pr is red if they aren't colored that is the correct order. Don't connect the yellow to anything. The red and white on the other part of the cable go directly to the right of these connections. It will say audio and L and R they should also be colored but if not white is L and red is R. There is also a small switch at the xbox end of the cablewhich you need to slide to HDTV. Once you are powered up don't forget to enter the setup menu on the xbox and select the settings for your tv. Again without knowing the model most wega tvs limit the component input to 480p which was the limit of a dvd. I hope this is helps.
Posted on Jan 28, 2009
  • Jim London
    Jim London Feb 04, 2009
    Hi, I hope I solved your problem, Please rate my response, your
    favorable ratings help others that may have the same or similar
    problem. Thank you!
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
I have a xbox 360 slim and I am trying to hook up to a sony trinatron wega model # KV27FS120
you will need to purchase the the xbox A/V component cables as your tv doesn't have hdmi
Jul 14, 2014 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony wega tv hdmi not responding to xbox one
Is the Xbox one not picking up the tv if not try an HDMI cable. They mostly cost $15
Dec 30, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I need best sound settings for Sony WEGA KV-HV21
Sound Settings have a resetting at the botton go there.Tries resetting back to factory settings best reconmentation for the tv.
Sep 02, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen size problem on 720p
Best to contact sony, local game repair shop.
Dec 30, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I can not find the remote for my 32" Sony trinitron can I manual make any changes. It is a tube set
I think the best thing to do is purchase a replacement remote such as universal.
All instructions are with it , and if you read below that will help you understand.
http://www.answerbag.com/articles/How-Does-a-Replacement-Remote-Control-Work/89114f3e-a2e0-b409-52ae-8384013312dc
Hope i`ve helped.
Dec 04, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Dropped sony tv trinitron face down, ti goes to standby
You have a cracked board inside the TV. The biggest weight creating the crack would probably be the Flyback transformer. And you may have done damage to the tube internally..the shadow mask perhaps? The yoke or the neck of the tube is broken.....Could be a lot of things or minor...just have to check with a tech!
Nov 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-32xbr400
There are no hazards, Just a Picture tube trying to tell you something. The tube is defective. There is no way to fix it, but to replace the tube. To replace the tube is not cost friendly. Cost of tube $707.00 part number 8-735-047-05
Best regards
circuitcity
Dec 01, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony 32" wega tube
plug out tv and start over by then the tv will reset itself.if that does not work call in a tech to solve,your problem.good luck/
Apr 01, 2007 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
765 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
