Question about Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL2000N not using Magenta Toner
Howdy! Anyone out hear ever mess with a CL2000N that wasn't using the Magenta Toner? Is there any information to trouble shoot this, other than replacing the cpu board?
  • Dan Tassell Nov 17, 2007
    Howdy! The Ricoh Aficio CL2000n is not using any of the magenta toner. It is printing with the other colors, just not red. Have tried another magenta cartridge, but that did not help. I have been told I need to replace a board, but if I could just get the schematic I could sort it out. I think it is most likely a motor or the motor controlling circuit for the magenta toner cartridge that have failed. Any help you could give I would greatly appreciate! Thank you for your reply! Dan
I will have a look and see if i have the schematic for you , it could also be one of the development clutches that is slipping and not pulling forward , if you open the front door were you install the cartridges you will see there is a switch on the right hand side , stick like a screwdriver in there to jippo the door , then make a copy and see if the magenta dev init engages(meaning that it pulls all of the colours forward to the opc belt when making a copy , if magenta is not pulled you will know it is either the clutch or the board then .
Posted on Nov 17, 2007
  • 37 Answers
If you give me more info on what you mean about the machine is not using magenta toner i can try to help you .
Posted on Nov 16, 2007
  • rwirth888 Aug 24, 2011
    Umm I'm having the same problem..... Anyone can help me? Not very technical but I can follow directions...
Error code sc440
Black drum motor error. These machines are bad about the waste toner building up in the drum unit. You could try and take the auger out of the drum unit(very messy) and clean it out or try replacing the black pcu.
Mar 17, 2009 | Ricoh Aficio CL2000N Laser Printer
Error message on Ricoh Aficio BP 20 PCL 6 printer
Flashing orange means low toner.....solid red should be a paper jam
Feb 20, 2009 | Ricoh Aficio CL2000N Laser Printer
Cl2000n Ricoh can't reset add toner cyan in display
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Ricoh Aficio CL2000N Laser Printer
How do I replace the waste toner to Aficio CL2000N
seat the bottom of the cartridge first and then press upwards, it should then click into place, thats also the reason why the door is no closing
http://www.websitetoolbox.com/mb/copierquestions
Dec 29, 2008 | Ricoh Aficio CL2000N Laser Printer
You may have to replace the transfer belt or the drum. I would start with the drum first
Sep 02, 2008 | Ricoh Aficio CL2000N Laser Printer
Red toner leaking onto "spongy" rollers and down onto the paper trays
Hi, its sounds like a faulty magenta cartridge. Contact your supplier for a replacement
May 13, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
Jan 24, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000N
open rt. door remove the waste toner ant the color and black drum units undo the green screws and slide out, watch out for the green swutch an the left side of transfer unit thurn it up so as not to break it both going in and out
Jan 22, 2008 | Ricoh Aficio CL2000N Laser Printer
Message toner is low
save your self the trouble and just buy the toner cartridge you need. I Think you can go to ricoh.com to down load a manual. hope this helps.
Oct 25, 2007 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
108 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
