Question about Brother Sewing Machines
Bobbin dose not fit
Brother PQ 1500 Bobbin SA159 dose not fit ( to large in dia') in our bobbin case. We called Brother an were told we must haver the wrong bobin case. The machine was donated to our church. How ever it work just fine with the bobbins that came with it. How can we tell if the case is the wrong one? what are the measurments of it? where can I view the parts?
Thanks Pat
  • 66 Answers
Get me your email and I will see if I can emal you the correct part number and maybe a diagram of the machine
Posted on Jan 29, 2009
How to remove sewing bed where fabric lays when sewing to get to bobbin area of Brother LS - 2020 sewing machine
Lower bobbin threading Brother
  1. Turn the power switch to "o".
  2. Raise the needle to its highest position by turning the balance wheel towards you (anti-clockwise) and raise the presser foot lever.
  3. Open the shuttle cover behind the extension table on the the front of the machine and remove the bobbin case by pulling its latch towards you and pulling it out of the shuttle race. (fig A).
  4. Unwind about 10cm (4") of the thread from a full bobbin and insert it into the bobbin case. (see fig B-1). Pull the trailing thread into the slot then down and to the left, as shown in fig B-2, until it enters the delivery eye under the tension spring (fig B-3).
  5. Holding the bobbin case by the latch, fully insert the bobbin case into the shuttle race and release the latch. Make sure the bobbin case finger fits into the notch at the top of the race as shown in fig C.
Sep 13, 2016 | Brother Sewing Machines
How do I thread the bobbin of a brother xr-35
fit the bobbin into the bobbin case and feed the thread to the outside through the opening. it does not matter which way round the bobbin is in the case, then insert the case into the machine make one turn with the macine so that the threaded needle drops through the plate. when it comes back up it should pull up the bobbin thread with it. then take the two threads and pull them back and insert your material to be sewn.
I hope this was useful.
Feb 12, 2015 | Brother Sewing Machines
How to put a bobbin shuttle into sewing machine Bobbin case?
It's like one of those peg boards you have to turn your bobbin case round and round until it fits. It should click right in unless you have the wrong size bobbin
Sep 06, 2014 | Brother CS-8060 Computerized Sewing...
Bobbin shuttle doesn't move
Look in your book.
- There is a bobbin (clear plastic) it rotates.
- The bobbin fits into the bobbin case (black), it does not rotate.
- The bobbin case is nested into the shuttle which does rotate.
There is no bobbin shuttle.
Aug 19, 2014 | Brother CS-8060 Computerized Sewing...
When I try to sew, the bobbin bangs around, like it doesn't fit.
Is it the bobbin or the bobbin case that is banging around? If I don't seat my bobbin case properly, it rattles and eventually falls out. Your bobbin case may be damaged, in which case, the bobbin is not going to fit properly. I dropped and stepped on my bobbin case once and the machine had the same symptoms. Then there's the obvious answer, a wrong size bobbin got mixed up with your bobbins. I've had that happen when I've taken a class with others. We all share tools and sometimes the right ones don't get back to their proper owner.
Nov 28, 2010 | Brother XL-2600I
Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Jan 27, 2010 | Singer 7442 Mechanical Sewing Machine
Firstly check that you have the correct bobbin for your machine, there are many bobbins that will fit in the bobbin case and sew ok, but the hole in the centre is what matters. If you do not have an original try putting the bobbin on the winder spindle with a small piece of paper inside the centre of the bobbin so it is tight on the shaft.
If that does not work it usually means the winder rubber on the bottom of the cover is worn or stuck, this part often looks like a large O Ring.
Jul 01, 2009 | Brother CS-8060 Computerized Sewing...
Bobbin case not fitting
541678 is the bobbin case you want.Most sewing machine dealers can get this part for you. The machine was made from 1978 to 1984. Before you spend a lot of money repairing this machine, check,or have someone else check, the cam drive gears in the top of the machine. They frequently crack and cause a lot of noise and some erratic stitching.
Apr 29, 2009 | Brother LS-2125 Mechanical Sewing Machine
I need to rewind a new bobbin
My SE-270D bobbin winder is located on the top of the machine to the far right. From the picture of your machine it looks to be in the same place. The larger spindle is for the spool of thread and the shorter spindle is for the bobbin.
You need to wnd the thread around the bobbin a few times just to make sure it is started properly, and then move the bobbin either forward or backward to engage. (It's different on some machines.) You may also have to move the outer edge of the machine wheel (the large wheel on the outside right) to keep the needle from moving up and down while the bobbin is filling. When the bobbin is full the machine should shut off by itself.
Then you will have to re-tighten the machine wheel to engage the needle.
Hope this helps.
Apr 05, 2009 | Brother Sewing Machines
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
