Question about Dell Dimension 9200 PC Desktop
My Dell Dimension 9200 will not power up reliabily.
When it does power up and boot normally it shuts off after about 5 hours and then won't restart until it rests for ~12 hours.
  • davenewport2 Jan 28, 2009
    The computer is sitting in the open with the cover off.
  • omh16 Mar 27, 2009
    i have a similar problem, when i run my dimension 9200 for a while and the cpu is doing something it may shut off randomly and not turn on for a while. i dont not believe the cpu is overheating because after it crashes i open the case and touch the cpu and heatsink which are both cool
What i did was myself i download I8KFanGUI, and turn my fan speed on high, now it has been working without shutting off, plus also I went into the bios and turned "speedstep" on, since i heard windows xp will use it regardless of the bios setting... that may have caused some problems itself causing a switch off. A few times though i could not start the pc, so i opened the case and snapped out the ram (not removing completely, just undoing the insert snaps on 1 side) and start the pc (might've had to unplug and replug a few times to get it to power on)... but i'm guessing i'll rarely have to do that... since i couldnt shut down the pc right 1 time it happened like that. But it is working now!
Posted on Mar 28, 2009
    Scholar:
  • 40 Answers
I may be able to help. Is the computer in a cool venilated space? It seems that after being powered on for that amount of time, it overheats and needs to cool down before being powered up. If possible you may want to consider PC cooling options, google is a good start for choosing a cooling kit-->
http://www.google.com/products?rlz=1C1GGLS_enUS291US303&sourceid=chrome&q=Hard+Disk+Cooling&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
Another option, you can point a fan on the desktop where it is stored. This will help to keep the area around it cool, and essentially the computer.
Let me know if you have any questions.
Thanks, Raph30
Posted on Jan 28, 2009
Dell dimension 9200 does not boot
can you provide more details so that we can make a proper suggestion
Mar 05, 2014 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 9200 does not boot.
remove ram and listen beep codes from the system ......still no beeps from the system .....the problem with motherboard only
Oct 15, 2012 | Dell Dimension 9200 PC Desktop
My dell dimension 9200 is booting and then giving me a Floppy Diskette Seek Failure message. What is causing this to appear and not boot windows 7?
Hi. You computer seems to be booting up using the floppy disk and your floppy disk drive might not be connected properly, not working or not even there. Press F2 to run the setup utility and disable the floppy seek in the bios. It will most likely be in the "Advanced CMOS setup" area, or the 2nd screen depending on your bios. look for "Seek floppy drive at boot?" or, "Disable floppy seek at boot?" or something like that. When you find it, make sure it's not enabled for the seek. Save the change on exiting. :-)
Jun 05, 2011 | Dell Dimension 9200 PC Desktop
Dimension 9200 wont boot in normal or safe mode. Processor fan is not running
The fan probably went out. Did you hear the fan noise for the last 2-3 weeks while using the unit? That was the fan going out. Buy a new fan @ Best Buys or your local computer store. It may work.
If it doesn't , you may have to replace the Processor and /or the system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Jan 21, 2011 | Dell Dimension 9200 PC Desktop
My Dell Dimension begins to boot then sits there as if asleep
It sounds like it's probably the power supply. Computers require more power to boot up than they do to keep running, so if it's fine once it gets going, the power supply may just be dying. If you have a multimeter and know what you're doing, you can test the power supply connectors to see if any of them (especially the ones leading to the motherboard) are not giving the proper voltages.
How old is the computer?
May 27, 2010 | Dell Dimension 9200 PC Desktop
My Dell 9200 won't start up (boot) after 7 months non use
No offense, but you need to plug it in to turn it on.
Jun 18, 2009 | Dell Dimension 9200 PC Desktop
Dell Dimension 9200 keeps shutting down and won't start up
the key issue on the uncommanded shutdown is the POWER LED. If upon shutdown, the power LED Flashes AMBER, then the power supply is suspect.
If no flashing amber indication, then the next think I check is the heatsink (Processor overheating) remove, clean and apply arctic Silver heat transfer paste, see if the issuje goes away
Last but not least if the system is failing to boot, and displays a 3 4 diag LED code, then you may have a RAM module that is bad or may just need reseating. Running diags off of the Rersoujrce CD is something to look at too
Mar 28, 2009 | Dell Dimension 9200 PC Desktop
After rebooting Monitor goes into sleep mode
you have a xpx 9200 and if i am not mistaken thats a system which should be under warrantty
contact the tech support 18006249896
Sep 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell Dimesion 9200
it could be the corrupted OPERATING SYSTEM
to be sure
turn off the system
when you power it on start tapping F2 key
it will go in syatem setup
leave the system and monitor if it turns off or restarts
if it doesn't get your operating system reinstalled
and if it does restarts of shuts down we have to troubleshoot further
provide me your system's service tag located at the bottom pannel of your system, turn it upside down you will find a bar coded sticker which has a 7 digit alphanumeric number
Jun 05, 2008 | Dell Dimension 9200 PC Desktop
Dell Dimension 9200 PC Desktop Logo
708 people viewed this question
Alun Cox
