How to seperate a number from a text string in microsoft excel?
In coloumn a i have ta text string that containd a number like ''Ch.No.:906891 is issued to Mr.John'' in coloumn b i need only the number of the cheque that was been issued
    Genius:
  • 1,605 Answers
Highlite the cells you want. right click the mouse. go to format. select text in the first coloumn.
highlite the cells you want for the second column, right click the mouse and go to format and select number and no decimal.
Posted on Jan 29, 2009
Convert numbers to text in excell
  1. Start Microsoft Excel.
  2. Press ALT+F11 to start the Visual Basic Editor.
  3. On the Insert menu, click Module.
  4. Type the following code into the module sheet. Option Explicit 'Main Function Function SpellNumber(ByVal MyNumber) Dim Dollars, Cents, Temp Dim DecimalPlace, Count ReDim Place(9) As String Place(2) = " Thousand " Place(3) = " Million " Place(4) = " Billion " Place(5) = " Trillion " ' String representation of amount. MyNumber = Trim(Str(MyNumber)) ' Position of decimal place 0 if none. DecimalPlace = InStr(MyNumber, ".") ' Convert cents and set MyNumber to dollar amount. If DecimalPlace > 0 Then Cents = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & _ "00", 2)) MyNumber = Trim(Left(MyNumber, DecimalPlace - 1)) End If Count = 1 Do While MyNumber <> "" Temp = GetHundreds(Right(MyNumber, 3)) If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars If Len(MyNumber) > 3 Then MyNumber = Left(MyNumber, Len(MyNumber) - 3) Else MyNumber = "" End If Count = Count + 1 Loop Select Case Dollars Case "" Dollars = "No Dollars" Case "One" Dollars = "One Dollar" Case Else Dollars = Dollars & " Dollars" End Select Select Case Cents Case "" Cents = " and No Cents" Case "One" Cents = " and One Cent" Case Else Cents = " and " & Cents & " Cents" End Select SpellNumber = Dollars & Cents End Function ' Converts a number from 100-999 into text Function GetHundreds(ByVal MyNumber) Dim Result As String If Val(MyNumber) = 0 Then Exit Function MyNumber = Right("000" & MyNumber, 3) ' Convert the hundreds place. If Mid(MyNumber, 1, 1) <> "0" Then Result = GetDigit(Mid(MyNumber, 1, 1)) & " Hundred " End If ' Convert the tens and ones place. If Mid(MyNumber, 2, 1) <> "0" Then Result = Result & GetTens(Mid(MyNumber, 2)) Else Result = Result & GetDigit(Mid(MyNumber, 3)) End If GetHundreds = Result End Function ' Converts a number from 10 to 99 into text. Function GetTens(TensText) Dim Result As String Result = "" ' Null out the temporary function value. If Val(Left(TensText, 1)) = 1 Then ' If value between 10-19... Select Case Val(TensText) Case 10: Result = "Ten" Case 11: Result = "Eleven" Case 12: Result = "Twelve" Case 13: Result = "Thirteen" Case 14: Result = "Fourteen" Case 15: Result = "Fifteen" Case 16: Result = "Sixteen" Case 17: Result = "Seventeen" Case 18: Result = "Eighteen" Case 19: Result = "Nineteen" Case Else End Select Else ' If value between 20-99... Select Case Val(Left(TensText, 1)) Case 2: Result = "Twenty " Case 3: Result = "Thirty " Case 4: Result = "Forty " Case 5: Result = "Fifty " Case 6: Result = "Sixty " Case 7: Result = "Seventy " Case 8: Result = "Eighty " Case 9: Result = "Ninety " Case Else End Select Result = Result & GetDigit _ (Right(TensText, 1)) ' Retrieve ones place. End If GetTens = Result End Function ' Converts a number from 1 to 9 into text. Function GetDigit(Digit) Select Case Val(Digit) Case 1: GetDigit = "One" Case 2: GetDigit = "Two" Case 3: GetDigit = "Three" Case 4: GetDigit = "Four" Case 5: GetDigit = "Five" Case 6: GetDigit = "Six" Case 7: GetDigit = "Seven" Case 8: GetDigit = "Eight" Case 9: GetDigit = "Nine" Case Else: GetDigit = "" End Select End Function
uparrow.gifBack to the top How to use the SpellNumber sample function loadTOCNode(2, 'moreinformation'); To use the sample functions to change a number to written text, use one of the methods demonstrated in the following examples: uparrow.gifBack to the top Method 1: Direct Entry loadTOCNode(2, 'moreinformation'); You can change 32.50 into "Thirty Two Dollars and Fifty Cents" by entering the following formula into a cell: =SpellNumber(32.50) uparrow.gifBack to the top Method 2: Cell reference loadTOCNode(2, 'moreinformation'); You can refer to other cells in the workbook. For example, enter the number 32.50 into cell A1, and type the following formula into another cell: =SpellNumber(A1) uparrow.gifBack to the top Method 3: Paste Function or Insert Function loadTOCNode(2, 'moreinformation'); To enter a custom function into a worksheet, you can use Paste Function in Excel 2000, or you can use Insert Function in Excel 2002 and in Excel 2003. Excel 2000 loadTOCNode(3, 'moreinformation'); To use Paste Function, follow these steps:
  1. Select the cell that you want.
  2. Click Paste Function on the Standard toolbar.
  3. Under Function category, click User Defined.
  4. Under Function name, click SpellNumber, and then click OK.
  5. Enter the number or cell reference that you want, and then click OK.
Excel 2002 and Excel 2003 loadTOCNode(3, 'moreinformation'); To use Insert Function, follow these steps:
  2. Click Insert Function on the Standard toolbar.
  3. Under Or select a category, click User Defined.
  4. In the Select a function list, click SpellNumber, and then click OK.
Apr 01, 2010 | Microsoft Windows XP Professional
In MS Excel, convert a Number in Text formate
Dear,
you've use macro to this.
Press Alt+F11
it will open Microsoft Vsual Basic Editor.
Click on Module in Insert Menu and paste the following codings:
Function ConvRs(ByVal MyNumber)
Dim Rupees, Paise, Temp
Place(3) = " Lac "
Place(4) = " Crore "
Place(5) = " Arab " ' String representation of amount
' Convert Paise and set MyNumber to Rupee amount
Paise = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & "00", 2))
End If
Count = 1
If Count = 1 Then Temp = GetHundreds(Right(MyNumber, 3))
If Count > 1 Then Temp = GetHundreds(Right(MyNumber, 2))
If Temp <> "" Then Rupees = Temp & Place(Count) & Rupees
If Count = 1 And Len(MyNumber) > 3 Then
Else
If Count > 1 And Len(MyNumber) > 2 Then
MyNumber = Left(MyNumber, Len(MyNumber) - 2)
Else
MyNumber = ""
End If
End If
Count = Count + 1
Loop
Select Case Rupees
Case ""
Rupees = "No Rupees"
Case "One"
Rupees = "One Rupee"
Case Else
'Rupees = Rupees & " Rupees"
Rupees = "Rupees " & Rupees
End Select
Select Case Paise
Case ""
'Paise = ""
Paise = " Only"
Case "One"
Paise = " and One Paisa"
Case Else
Paise = " and " & Paise & " Paise"
End Select
ConvRs = Rupees & Paise
End Function
' Converts a number from 100-999 into text *
MyNumber = Right("000" & MyNumber, 3) 'Convert the hundreds place
End If
'Convert the tens and ones place
Else
End If
End Function
' Converts a number from 10 to 99 into text. *
Result = "" 'null out the temporary function value
Case Else
End Select
Case Else
End Select
(Right(TensText, 1)) 'Retrieve ones place
End If
GetTens = Result
End Function
' Converts a number from 1 to 9 into text. *
End Select
End Function
save this as as ConvertRs.xla in Microsoft\AddIns folder
now, you'll have to activate this AddIns:
in your Excel Worksheet select:
Tools\Add.Ins...
Check the ConvertRs option
now this will be used as User Defined Function.
you can insert it from the Function Options or just enter the following command in the desired cell where you want the result:
=ConvertRs(Cell Reference)
Cell Reference means where the number is available, you want to convert.
Try this and then tell me the responce.
Bhasker Kumar
Jul 09, 2009 | Microsoft Computers & Internet
Convert function
BAHTTEXT(number)
The above function will convert a number to text. If you are referring to "figure" as a number than this should work for you.
You may want to try the TEXT(value,format_text) fucntion too but you'll need to supply a number format.
Apr 22, 2009 | Microsoft Office Excel 2003 for PC
How to convert numbers into words in MS excel?
1. Insert a module sheet into a workbook. To do this in Microsoft Excel 97 or Microsoft Excel 98, point to Macro on the Tools menu, and then click Visual Basic Editor. In the Visual Basic Editor, click Module on the Insert menu. In Microsoft Excel 5.0 or 7.0, point to Macro on the Insert menu and click Module.
2. Type the following code into the module sheet.
Option Explicit '**************** ' Main Function * '**************** Function SpellNumber(ByVal MyNumber) Dim Dollars, Cents, Temp Dim DecimalPlace, Count ReDim Place(9) As String Place(2) = " Thousand " Place(3) = " Million " Place(4) = " Billion " Place(5) = " Trillion " ' String representation of amount. MyNumber = Trim(Str(MyNumber)) ' Position of decimal place 0 if none. DecimalPlace = InStr(MyNumber, ".") ' Convert cents and set MyNumber to dollar amount. If DecimalPlace > 0 Then Cents = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & _ "00", 2)) MyNumber = Trim(Left(MyNumber, DecimalPlace - 1)) End If Count = 1 Do While MyNumber <> "" Temp = GetHundreds(Right(MyNumber, 3)) If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars If Len(MyNumber) > 3 Then MyNumber = Left(MyNumber, Len(MyNumber) - 3) Else MyNumber = "" End If Count = Count + 1 Loop Select Case Dollars Case "" Dollars = "No Dollars" Case "One" Dollars = "One Dollar" Case Else Dollars = Dollars & " Dollars" End Select Select Case Cents Case "" Cents = " and No Cents" Case "One" Cents = " and One Cent" Case Else Cents = " and " & Cents & " Cents" End Select SpellNumber = Dollars & Cents End Function '******************************************* ' Converts a number from 100-999 into text * '******************************************* Function GetHundreds(ByVal MyNumber) Dim Result As String If Val(MyNumber) = 0 Then Exit Function MyNumber = Right("000" & MyNumber, 3) ' Convert the hundreds place. If Mid(MyNumber, 1, 1) <> "0" Then Result = GetDigit(Mid(MyNumber, 1, 1)) & " Hundred " End If ' Convert the tens and ones place. If Mid(MyNumber, 2, 1) <> "0" Then Result = Result & GetTens(Mid(MyNumber, 2)) Else Result = Result & GetDigit(Mid(MyNumber, 3)) End If GetHundreds = Result End Function '********************************************* ' Converts a number from 10 to 99 into text. * '********************************************* Function GetTens(TensText) Dim Result As String Result = "" ' Null out the temporary function value. If Val(Left(TensText, 1)) = 1 Then ' If value between 10-19... Select Case Val(TensText) Case 10: Result = "Ten" Case 11: Result = "Eleven" Case 12: Result = "Twelve" Case 13: Result = "Thirteen" Case 14: Result = "Fourteen" Case 15: Result = "Fifteen" Case 16: Result = "Sixteen" Case 17: Result = "Seventeen" Case 18: Result = "Eighteen" Case 19: Result = "Nineteen" Case Else End Select Else ' If value between 20-99... Select Case Val(Left(TensText, 1)) Case 2: Result = "Twenty " Case 3: Result = "Thirty " Case 4: Result = "Forty " Case 5: Result = "Fifty " Case 6: Result = "Sixty " Case 7: Result = "Seventy " Case 8: Result = "Eighty " Case 9: Result = "Ninety " Case Else End Select Result = Result & GetDigit _ (Right(TensText, 1)) ' Retrieve ones place. End If GetTens = Result End Function '******************************************* ' Converts a number from 1 to 9 into text. * '******************************************* Function GetDigit(Digit) Select Case Val(Digit) Case 1: GetDigit = "One" Case 2: GetDigit = "Two" Case 3: GetDigit = "Three" Case 4: GetDigit = "Four" Case 5: GetDigit = "Five" Case 6: GetDigit = "Six" Case 7: GetDigit = "Seven" Case 8: GetDigit = "Eight" Case 9: GetDigit = "Nine" Case Else: GetDigit = "" End Select End Function To use this UDF push Alt+F11 and go Insert>Module and paste in the code. Push Alt+Q and save. The Function will appear under "User Defined" in the Paste Function (Shift+F3).
Jan 19, 2009 | Microsoft Excel for PC
What function can make a text/string BOLD?
Try selecting a cell and right click, Format cells, Font - Bold the text the way you want it to appear in that cell and then let it be the value you want to appear when you select that cell as a solution to a "What If" statement.
I build training spread sheets that let people generate pre-programmed answers to various data entries. Answers appear like magic.
Glad to be of assistance - please rate the posting - I can learn from you.
Oct 26, 2008 | Microsoft Office 2003 Basic Edition...
Excel - Formulas!
I find this site helpfull with Excel problems:
http://www.usd.edu/trio/tut/excel/
Sep 02, 2008 | Microsoft Excel for PC
Unable to Change Dates
I am using MS-2007, i got the solution upto some level only.
i can't say exactly whether it is right or not.
my solution is :
first change the settings in ControlPanel/Regional and Language Options.
Click on Customize button/open the Date Tab and set the date format there.
and then proceed with CSV.
Open CSV in Excel and divide Text to coloumns.
Ur all Date Cells will be in particual Format.
and Select that coloumns and right click Format Celss....etc.
Thanking u.
If u found any Douts, Suggestions ,Plzz let me know.
Jun 27, 2008 | Excel (SS8SATAS5128400R)
Excel Formula Help
Name the list as a range. Copy the list to a different location, eliminate duplicate values, then write the formula next to the newly listed items to count the number of occurrences in the original list range. Thanks for rating FixYa!
Apr 22, 2008 | Microsoft Office Professional 2007 Full...
Excel Loading Problem
try using OpenOffice.org instead of Microsoft Office. It should work and it's free.
Dec 07, 2007 | Microsoft Excel 2000 Step by Step...
When I enter a formula in a cell with the the insert functon device, it does not calculate itself, but shows as text
Is there by any chance a space or any other character before the equals sign? That could cause your formula to display as text.
Dec 03, 2007 | Microsoft Excel for PC
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
