Question about Sony VAIO VGN-TX650P/B' Notebook PC
For bootup the VXN-TX650P doesnot start with start button.
The laptop had fallen from my hand at the airport.
It doesnot start with the start button, but was starting with the AV button for some time after the fall. But now suddenly
With pressing the AV button it starts but then stops immediately giving and error message
"The instant mode application could not be found
To recover from this error please restart the system and run recover image"
What to do ?
  • Ramesh Suri
    Ramesh Suri Jan 28, 2009
    I have been to he SONY service centre and they say it is a software problem and they donot look after software problems.
    Know the Sony service centre in Delhi which looks after the software problems, then please send me the contact.
  • Jay
    Jay May 11, 2010
    Your laptop might have detected an error in the hard drive and is trying to recover from this fatal error. But doing so might wipe your hard drive clean and you will loose all your personal data. Better have it serviced so that you can have your data retrieved.
    Novelist:
  • 117 Answers
If you have important docs, remove the hard drive and purchase a sata to usb connector/psu from ebay to recover your docs on another machine, then reload the hard drive and tap the f10 key. this will allow you to restore the hard drive, you will have options to restore follow the one that best suits you and you are home free!
Good Luck!
Ruben
Posted on Jul 19, 2009
Airport sign in keep saying wrong password
Delete Preferred Network(s)
  • System Preferences > Network > Select AirPort > Advanced > AirPort tab
  • Under Preferred Network, use the minus button to delete the network(s) you regularly use from the list
Delete AirPort Keychain Entries (Note: only applies if you connect to AirPort/Time Capsule routers)
  • Launch the "Keychain Access" application located in /Applications/Utilities
  • Click on the "Kind" filter at the top, and look for any "AirPort network password" entries...and delete them.
  • Restart, or log out then back in.
Add Preferred Network(s)
  • Under Preferred Network, click on the plus button to add any preferred network(s).
  • Restart or log out then back in.
Jul 02, 2014 | Apple iBook G3 Mac Notebook
The cpu doesnot detect the HDD. there is a boot failure.
are the cables in right power cable and the ribbon or sata cable in right?
Nov 28, 2013 | Mitac MSC-242 Motherboard
How to change av mode
you can get the instructions on how to change the av mode button from the user manual of you computer. click on the link esupport.sony.com
  • the steps on how to change it is on page 30
Mar 03, 2010 | Sony VAIO VGN-TX650P/B' Notebook PC
I f I connect hotel internet via Apple USB 2.0 Ethernet Adapter to my MacBook Air, internet after few minutes disconnected, to connect again i take out the cable, and then plug in, usually internet start...
Try turning off Airport. Your computer may be finding a wireless network and automatically switching to it, and getting an intermittent signal. Just a guess, but for a good ethernet connection you want to disable the Airport searching feature anyway.
Open the System Preferences application, select "Network" and right on the top left of the resulting window there's a pretty big button that will either say "Turn Airport On" or "Turn Airport Off" - just turn it off if it's not already ...
Hope this helps!
For help with Public Address Systems see my new How To Video, available as a DVD at www.whamuniversal.com
Feb 15, 2010 | Apple USB 2.0 Ethernet Adapter for MacBook...
Acer 4720,when switched on wifi button,the light for wifi is flash and the funcion is worked.But switched off wifi button,the light is still on.How can i switch off the light?
For Windows Based Computers
If the drivers for the wireless adapter contain a setting to toggle wireless radio, it can be located using the
following path: Start > Settings > Control Panel > Right click Wireless Network Connection Icon > Properties >
Configure > Advanced tab
Here you will find a textbox with a list of selectable properties that are populated by the device driver. Once you
select a property there will be a value field with a dropdown box containing configuration options that apply to that
specific property. The name of the wireless radio property may vary because the listed properties are dependent on
each specific device driver. It should be fairly intuitive to determine the correct property if you simply have the user
read all the listed properties to you.
Many laptop manufacturers will place a physical switch on the outside casing of the laptop, so that the user can
easily toggle wireless radio. Sometimes these switches get accidentally turned off, or intentionally turned off and the
end user forgets to switch it back. The best practice in these situations is to ask the user to look for a physical switch
on the case of the laptop, possibly with a symbol of a radio tower next to it. After turning the wireless switch on, the
user will probably need to refresh their network list.
Laptops built by certain manufacturers may have a specific keystroke set up to toggle wireless radio.
Below are some examples of wireless radio software and hardware toggles that we have been able to
document:
Acer (General) - FN,F5
ASUS (General) -The F5R has a toggle switch to turn on and off the WIFI; it is located on the left side of the
notebook
Dell (General) - FN,F2 or FN,F8 or FN,F12
Dell d630 (D6xx?) latitude: toggle switch on the left side towards the front by the PCMCIA slots and headphone
jack
E-machine (General) - FN,F2
Fujitsu (General) - FN,F10
HP/Compaq (General Older models) - Button on upper left on keyboard deck
HP/Compaq (General Newer models) - Button on lower left below keyboard
IBM thinkpad (General) - Most have software switch or button on left hand side.
IBM thinkpad (model not further identified) with wireless switch on front edge of case.
Sony Vaio (General) - switch on front left
Toshiba (General) - FN,F5 or FN,F8 or switch
Toshiba Satelite has a physycal switch on front of case. FN+F8 shows wether wireless communications is
enabled or disabled.
For MAC/Apple Based Computers
MAC OS X 10.4.x (Tiger & Earlier)
Open MAc Hard Drive > Applications > Utilities folder > Set the Configure pull-down to Airport.
Make sure the "Airport Power:" says On. (This is the status or your Mac's Airport card.)
If not, click "Turn Airport On" button.
MAC OS X 10.5.x (Leopard)
Click on the: Apple Icon > System Preferences > Network > Airport > Airport Power - On/Off
Jan 20, 2010 | Acer Aspire 4720 Notebook
Ibook g4 freezes and airport problem
have you gone into airport utility?
are you using an airport extreme? if so, reset it.
then delete the current wireless network, and try setting up a new one in airport utility.
Feb 16, 2009 | Apple iBook G4 Mac Notebook
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Acer laptop bootup problems
Please try and bootup your computer in safe mode by pressing the F8 Button just before windows starts to load. a menu appears and you just need to select the safe mode option and see how it goes from there.
Let me know if this helps.
Oct 27, 2008 | Acer Ferrari 4000 Notebook
Ethernet
I had a laptop that did that too, here's what you do:
go to System preferences>network>then click "ethernet" If the cable is in, then the computer will automatically use that connection. If you are using an airport click "airport" >Assist Me> Assistant. You should also click the button that says "turn airport on(off)" make sure it says turn airport off. This means that you can now connect to your wireless airport. In the assistant you should be able to select a "Use airport automatically" button. Make sure that the button has been pressed, now the Airport will be what it is set to use, instead of Ethernet.
Sep 18, 2008 | Apple MacBook Mac Notebook
Sony VAIO VGN-TX650P/B' Notebook PC Logo
332 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
