Question about Honeywell HZ514 Baseboard Heater
Honeywell HZ514 Baseboard space heater
I have a baseboard space heater from Honeywell.
The models specks are as follows.
The UL is listed 6D17
LA is LR95812
It's 120 Volt and 60Hz, 12.5A, 1500W
There are three questions that people would like answered
1. How much power does this draw? Is there a danger for overheating or blowing fuses on a circuit in the case of a commercial building wired for commercial businesses that has refrigerators, vending machines and large cannon commercial copiers?
2. If I accidently left it on low for a few days, what are the fire risks? This model as far as I can tell does not have a timer so I have to remember to turn it off. But what if I forget on a Friday?
Thanks for your time. Please reply with your title and contact information in case there are additional questions.
Regards,
Mary Ann Kaufman
  • 63 Answers
The power draw would be the same as 15 100 watt light bulbs all on at the same time! If this is on a circuit with anything else (ex; vending machine with cooler. )drawing over 7.5 amps it will trip the circuit breaker! does'nt matter if comercial or home! 120 volt receptacle would be on 20 amp breaker. And as for last question... I know there is a thermostat on front, so as long as thats set right, there should be no reason to fear a fire, if in safe location! John
Posted on Apr 06, 2009
  • 478 Answers
T should be fine 12.5 is rating so its probly on a 15 or 20 amp breaker
Posted on Mar 12, 2009
Not heating up... what could be problem....some simple i hope
How about a free replacement heater?
There has been a recall since 2002 on some Honeywell portable baseboard heaters. Check this link, or call Honeywell ASAP. The ON/OFF switch failed (with a burning plastic odor) on my HZ-514.
http://www.cpsc.gov/en/Recalls/2002/CPSC-Honeywell-Consumer-Products-Announce-Recall-of-Moveable-Baseboard-Heaters/
"Consumers should stop using these heaters immediately, unplug them, and contact HCP at (800) 290-8495 between 8 a.m. and 10 p.m. ET Monday through Sunday or log on to the company's website at www.honeywell.com to determine whether their heater is part of the recall."
I hope this is a solution for you, and you are safely warm again in the near future.http://www.cpsc.gov/en/Recalls/2002/CPSC-Honeywell-Consumer-Products-Announce-Recall-of-Moveable-Baseboard-Heaters/ not-heating-up-could-problem-some-gwybjxudtwjfkyidrgix5fxs-4-0.jpg
Oct 23, 2013 | Honeywell HZ514 Baseboard Heater
Need to replace off switch
I hope this is a solution for you, and you are safely warm again in the near future. need-replace-off-switch-gwybjxudtwjfkyidrgix5fxs-5-0.jpg
Mar 12, 2013 | Honeywell HZ514 Baseboard Heater
Off switch
I hope this is a solution for you, and you are safely warm again in the near future. off-switch-gwybjxudtwjfkyidrgix5fxs-5-0.jpg CPSC Honeywell Consumer Products Announce Recall of Moveable Baseboard...
Need a thermostat for model no hz-514
I hope this is a solution for you, and you are safely warm again in the near future. need-thermostat-model-no-hz-514-gwybjxudtwjfkyidrgix5fxs-4-0.jpg CPSC Honeywell Consumer Products Announce Recall of Moveable Baseboard...
Feb 03, 2013 | Honeywell HZ514 Baseboard Heater
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
Honeywell HZ517 Electric Baseboard Heater not powering up
first.... did they work in the past?? if so... you may have a defective thermastat. if not, usually it is a incorrect wiring problem. wiring in two baseboard heaters to one thermastat can be tricky if you do not know what you are doing. baseboard heaters by design seldom go bad.... if wired correctly the problem could be a defective thermastat or safety limit switch.
Feb 09, 2009 | Honeywell HZ517 Baseboard Heater
It says free
Here is a link for a recall of these heaters. I don't know if your problem is related to this, but it may be a place to start.
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02098.html
Dec 10, 2008 | Honeywell HZ514 Baseboard Heater
Loud humming
If this is an electric resistance heater then there is no power supply or transformer. I had a baseboard heater that would hum loudly and I found there's a wire that runs along the bottom to connect the far end of the heat element to the electrical wiring at the supply end. This wire becomes magnetized from the current flowing through it and vibrates in the channel it runs through. I was able to open this channel and squirt a bit of silicone caulk in to keep the wire from vibrating and the hum is gone.
Dec 19, 2006 | Honeywell HZ514 Baseboard Heater
Honeywell HZ514 Baseboard Heater Logo
764 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
