Question about Dell 1720dn Laser Printer
I have a Dell 1720 and the output sensor light keeps blinking. I have read some of the solutions but would like to actually fix it instead of using tape and a quarter since it is for a customer. thanks
  • 73 Answers
I assume that the solutions are telling you to make sure that the output tray has both of the tabs pushed down. There was an issue with these printers in the beginning with the tabs not going back down after being pushed up. On one of my printers, I removed the tab that was getting stuck and it seemed to do the trick.
Posted on Feb 08, 2009
My ps3 won't turn on and red light keeps blinking,
Read this:
http://www.prlog.org/10506996-ps3-red-flashing-light-causes-and-solution-revive-your-ps3-by-fixing-red-lights-blinking-yourself.html
May 15, 2012 | Sony Video Game Consoles & Games
Dell inspiron 1720 keeps dropping into standby mode when running any application using windows XP
Make use of some antivirus! Or it may because that your internal memory is full...
Jan 29, 2012 | Dell Inspiron 1720 PC Notebook
The yellow light on the front keeps flashing and it wont print
It helps SO much when you include the Model number of the printer you are asking about. If it happens to be a Dell 1720 then simply push the tab down located at the top right of the output bin. that Tab sticks open can cause the light to flash.
Oct 09, 2011 | Dell Office Equipment & Supplies
My dell inspiron 1720 locks up frequently - this problem started just yesterday I've used CC Cleaner and tried to do a complete virus scan using Kaspersky software - computer locked up at 7% into the...
Try running these scans in Safe Mode.
Keep pressing F8 on startup, and choose 'Safe Mode' from the list that appears.
If you still find it locking up during scans, you may have a hardware problem that needs fixing.
Regards.
Apr 26, 2011 | Dell Inspiron 1720 Notebook
I have a Dell 1720 printer and a light is flashing to indicate that I need to remove the output, and nothing I do makes the light stop flashing so I cannot print anything.
On the top where the paper comes out is a sensor. There is a flap with an arm attached that passes thru a photo-sensor. make sure the flap is not stuck in the up position and make sure the little arm is not broke off. You will need look very closely
Aug 18, 2010 | Dell 1720dn Laser Printer
My dell inspiron 1720 keeps rebooting. Pressed
Yes. You'll need to replace the hard drive with that error code.
No matter you can't use that computer without replacing the hard drive.
If you have a warranty for the computer contact tech support for your dell, give them the error code you have
and they will immediately replace your hard drive.
Re seating the hard drive won't fix it.
Hope this helps!
Feb 21, 2010 | Dell Inspiron 1501 Notebook
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
WHERE IS PAPER SENSOR LOCATED
dell laser 1720. don't know where the paper sensor is. flash says "Load paper and Remove output"
Feb 07, 2009 | HP Photosmart 2610 All-In-One InkJet...
Dell Printer 1720
This error is caused by the the flap on the right hand side of the output tray (the tray the paper feeds into once it has printed). It becomes stuck in the up position and sends a false positive error to the printer. One "work around" for this is to tape a quarter to the plastic flap. This keeps the flap in a down position, thus negating the false positive. The other option is to call dell laser printer tech support to get it fixed. <If it is still under warranty>
Jul 03, 2008 | Dell 1720dn Laser Printer
Dell 1720dn Laser Printer Logo
219 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
