Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Says memory full and will not work
dogman33 on Jul 25, 2007
my unit keeps saying the memory is full. It will not work anymore. This is the third Garmin 660 I have had and after a little while the same problem happens.
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Apr 15, 2009
-   thanksssssss works-   Guest
Mar 24, 2009
-   says memory full and will not work-   elmerarevalo
Oct 04, 2008
-   I have Nuvi 250. Suddenly it started to say "Memory full" and "Waypoint memory full". It shows maps but d't routing.
Connected to PC USB I see about 52 Mb free space.
So I saved files from POI folder ( custom POI) and GPX folder (current) then disconnected Nuvi and OFF.
Next step- depressing LOWER RIGHT corner of screen get ON.
I got " Are you realy want to erase all user data?"- Yes
And now problem solved!!
You must again make your settings and copy poi and gpx back.
-   Guest
Aug 30, 2008
-   My Garmin 660 says memory full and navigates to Europe each time.  In a phrase 'its a pile of ****' and I paid £399 for it...sick!-   Guest
Best Solution
posted on Oct 04, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Connected to PC I see about 52 Mb free space.
So saved files from POI folder ( custom POI) and GPX folder (current) then disconnected Nuvi and OFF.
Yuo must again make your settings and copy poi and gpx back.
Solution #2
posted on Dec 02, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Spydee,
Awesome post. Helped me!
Thx!!
/Swede
Solution #3
posted on Jul 27, 2007
Very Helpful)
spydee
Rank: Apprentice
Rating: 97%, 47 votes
Hi dogman33,
This is a common problem with the nuvi 660s with older firmware.
Garmin's solution is to perform a "hard reset" and to upgrade the device firmware.
Upgrading firmware is an easy procedure, just visit Garmin's website (www.garmin.com) and download the software called WebUpdater. Run that and follow its directions.
Here is how you can perform a hard reset to clear all your waypoint memory:
MAINTENANCE MODE:
Step 1. Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer.
Step 2. Place a fingertip on the upper left hand corner of the touch screen and keep it there while turning the unit on, a prompt should read " Do you really want to start in maintenance mode?"
Step 3. Select the yes button.
Step 4. Enter your PIN if enabled.
Step 5. Main Maintenance Mode screen should have 4 selections:
System information
View Diagnostics
Clear User data
Clear Waypoints
Step 6. Choose "Clear Waypoints". After some time the unit should reboot.
Hope this is helpful!
spydee
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Jan 13, 2008
Helpful)
ccbc
Rank: Apprentice
Rating: 91%, 5 votes
Hello is anyone out there that can help me my garmin has a green screen on it after trying to update it for the first time from the Gramin website and it will not shut off or read when it is connect to my computer Pleas HelP!
Was this helpful?
Yes
No
Solution #5
posted on Dec 03, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
THIS WORKED VERY GOOD FOR MEMORY FULL.
Solution #6
Very Helpful)
bikerbear1
Rank: Apprentice
Rating: 100%, 1 votes
go to your trash on your computer or mac and empty it when your garmin is plugged it .it worked for me seemds the unit still thinks files are there even when in the trash
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #7
Not Rated)
graywo
Rank: Apprentice
Rating: 85%, 4 votes
I put Solution #5 w/o login as Guest. If some questions&
Was this helpful?
Yes
No
Related Problems
There is no evidence of any sats beig located when looking...
MY 660 NUVI UNIT DOES NOT STAY CONNECTED TO MY BLACKBERRY...
No data available, can't Unlock Maps and cannot enabling...
Can you Help with these GPS Device problems?
Garmin nuvi 660 in PC Sync mode even...
Solve
Garmin nuvi 660 in PC Sync mode even it is not connected to PC USB or AC power supply. So the GPS is... (More)
helo
Solve
i format my gps ram .haw can i retern my first information than bacikly instaled on it as hiden... (More)
not finding candian address garmin...
Solve
I have a garmin nuvi 680 which have preloaded maps of united staes and canda but for some reson it... (More)
nuvi 265w will not read other states...
Solve
My nuvi 265w will not read othe states maps and addresses. This problem statred when I upgraded to... (More)
Sponsored Links
Describe your GPS problem:
Top GPS Device Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more GPS Device Experts
Top GPS Device Repair
(281) 371-2722
GeoQuip is a "One Stop Trimble Repair...
Gulf Coast GeoQuip
(646) 797-2838
Portatronics
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
